Question about Kenmore Refrigerators
Kenmore model 79852990 leaks water inside the refrigerator
SOURCE: frigidaire refrigerator leaking water inside refrigerator
There is a plastic panel inside the frigidaire looking at the underside of the freezer inside the refrigerator compartment which holds the thermostate dial and the light fixture. remove the four 1/4 in hex head screws holding the assembly. pull the panel toward the front. you will expose the drain hose connection you can let it dangle from the plug wires or remove the panel completely, I worked with mine in place. look at the back funnel shape drain. just in front of that see a rectangular styroform collar which should be snug fit to match the underside. clean and dry all. there is a divider between the two funnel compartments, mine was separated between the plastic and the styroform. I used kitchen and bath tub caulking to seal the gap. and a little around the rectangle shape that fits to the underside. plug the wire back in if disconnected. reassemble the panel. that may fix it. good luck.
Posted on Jun 17, 2008
rylee_smith
  • 8619 Answers
SOURCE: water leaking inside the refrigerator
Hi
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section ( not on all models, but this is the most common way ), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system. For some reason Whirlpool has found a need to "hide" the drain hose inside the walls now ( Whirlpool makes many of the Kenmore branded refrigerators ) on there top freezer refrigerators. This makes accessing the drain hose to flush it out more difficult, no cup inside the fresh food section, no hose down the outside back wall and the only access is inside the freezer section behind the back false wall and under the evaporator coils.
Please do rate the solution as FixYa if found useful and revert for further assistance.
Thanks
Rylee
Posted on Apr 17, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: fridge is leaking from freezer to top shelf
This is the drain tube that runs in the back of the freezer on the bottom is pluged. Take a sprayer with some hot water in it and flush out the system. Remove the food so that you dont get any of the stuff on it.
Posted on May 21, 2009
SOURCE: kenmore coldspot model 106: top freezer leaks
Have you tried adjusting the freezer temperature to a higher level? This worked for my Kenmore. It will take a couple of days to quit leaking.
Posted on Dec 19, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: My Kenmore Elite bottom freezer
rewrwer
Sorry to hear about your problem. Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues
Here is a list of some things that can go wrong.
In addition, your drain tube maybe clogged
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Posted on Dec 27, 2010
Water leaking inside the vegetable drawer
What is your model number? Also what year, series etc.
Apr 30, 2014 | Kenmore 20.6 cu. ft. Top Freezer...
Water leaking from top of kenmore refrigerator model 253
Almost certainly a blocked drain hose. Hose can usually be accessed from the back, it drains to a catch pan, usually on top of the compressor/motor. Best unblocked with a blast of compressed air if you have a compressor otherwise feed a long piece of whipper snipper chord or similar up from the bottom to dislodge the blockage (and/or down from the top if you can access the drain hole from where the leak appears inside the fridge). Good luck, hope this helps.
Nov 15, 2013 | Kenmore Refrigerators
Kenmore elite 596.735 .water leaking from rear of water filter unit.
What is the complete model number of your unit? Look inside the refrigerator section.
Oct 21, 2012 | Kenmore 73502 / 73504 / 73509 Bottom...
I have a problem with my kenmore refigerator. model number, 79852990 top freezer. For a while water wud fill the top left drawer. Now, the water ends up on the bottom of the fridge. Where does all this...
The defrost drain is plugged if you do not see a drain cup in the fresh food section then remove the back wall of the freezer and see if the drain trough is iced up.
Nov 22, 2010 | Kenmore Refrigerators
My Kenmore side by side refrigerator model 106.5686*601 is leaking water from the ice maker inside the freezer.
Icemaker leaks are common and cannot always be solved. May need a new Icemaker. Ofter you can obtain a kit from Lowes (use a Whirlpool kit.)
Aug 23, 2009 | Kenmore Refrigerators
I have water leaking heavily from the inside top of refrigerator,
Water is leaking inside the refrigerator from a bottom vent from the freezer. What is causing this?
Feb 27, 2009 | Kenmore Refrigerators
Refrigerators Logo
96 people viewed this question
Top Kenmore Refrigerators Experts
John Tripp
John Tripp
minguy15
Level 1 Expert
mike cooper
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
