Question about GE Dishwashers
Ge profile pdw9000 top rack not cleaning - GE Dishwashers
  • 3 Answers
SOURCE: The top rack is not getting clean.
This is one common possibility
It may be the food chopper assembly. Mine broke last year from a toothpick,
the food doesn't get chopped because the blades are broken, then the filter clogs and water wont spray high enough.
Heres a test--turn on the dishwasher and wait until you can hear water running then open the door really fast and look at how high the water is spraying--there should be alot of water all over the top rack running down
Posted on Jan 31, 2008
SOURCE: How do I remove the top rack on the ge profile built-in dishwashe
FOLLOW THE RODS THAAT HOLD THE BASKET AND AT THE END THEIR WILL BE A PLUG! IT WILL COME OFF AND YOU SLIDE THE RACK OUT THE PLUG USUALLY HAS A LITTLE LIP YOU NEED TO EITHER PUSH UN OR OUT TO REMOVE
Posted on Nov 30, 2008
SOURCE: TOP RACK WILL NOT GET CLEAN
look in the owners manual on how to clean the food particle grate on the pump.....
Posted on Dec 28, 2008
crayzeetrayn
  • 837 Answers
SOURCE: TOP RACK DOESN'T RINSE
I would suggest you buy some CLR and run it through a full heavy cycle with the washer empty. Be sure to put it in all dispenser areas and sprinkle about 1/4 cup into the washer before starting.
Posted on Feb 16, 2009
SOURCE: My GE PDW7880G doesn't clean items in the top
removed the sprayer. the part that spins under the top rack and check that the holes arent clogged.
Posted on Feb 23, 2010
Why doesn't the top rack of my dishwasher clean dishes?
the water tube may be clogged at the sprayer on the top of the basin. probably have to disassemble and clean
Apr 14, 2016 | GE Dishwashers
My dishwasher wont clean the dishes. The bottom rack gets kinda clean and the dishes on the top rack come out dirty and covered in film.
Check whether the top rack spray arm main hose sits firmly into the
machine. If there is a leak in this area water pressure may not develop.
Also check the water pump in the machine!
Oct 01, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
Only bottom rack cleans. Re-plumb or replace?
Do you have a garbage disposal? If I run mine while the dishwasher is running, dishes do NOT get clean!
Jan 09, 2010 | GE 24 in. Profile PDW7800 Built-in...
Dishes in top rack not getting clean
If you live in an area with 'hard' water (having more than 5 ppm) you may require a whole-house treatment system to eliminate the mineral content that will wreak havoc with any water-related system (including your water heater).
If that is not the case I would have a service call to check the upper level service arm, which must be pushed in to a hole in the back of most units in order to get the water to flow in.
Oct 01, 2017 | GE 24 in. Profile PDW9880JSS Built-in...
Cleaning oven racks
new racks. the finish is tarnished.. usually happens when the racks are left in the oven during the cleaning cycle.. steel whool may work but not sure..
Apr 09, 2009 | GE Profile JGS968 Gas Kitchen Range
Feb 16, 2009 | GE 24 in. Profile PDW7800 Built-in...
Nov 30, 2008 | GE 24 in. Profile PDW7800 Built-in...
GE Profile Spectra XL44
the reason they tell you not to do that is so the racks do not warp. I wouldn't do it. I did once accidently leave the racks in and they were fine that one time but I have never done it again or left any thing in. The oven gets up to a high heat and anything in it will retain that heat.
Oct 17, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Dishwashers Logo
32 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
jdthefixer
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
