Question about New Home L-372 Mechanical Sewing Machine
New home L372/L373 when I increase pressure on the foot pedal to speed up the machine the zig zag and other decorative stitches begin skipping. The machine has not been used in several years. Any ideas?
4 Suggested Answers
RickE1
  • 202 Answers
SOURCE: Machine is skipping stitches
First be sure you have a new needle in. A dull needle will cause this.
Also a burr from the needle having hit in the slot of the needle plate can catch the thread occasionally as well as a burr on the hook behind the bobbincase. With some very fine crocus paper or what is called a green stick these burrs need to be polished off. Or have them replaced. Check everywhere the thread touches. Otherwise it may be the timing is slightly off.
Posted on Oct 18, 2008
  • 1116 Answers
SOURCE: I nees a walking foot for my machine and do not
Most newer models of sewing machines are low shank.
You can use this chart for comparison, just to be sure - http://www.clotilde.com/pages/which_foot.html
Posted on Mar 01, 2010
SOURCE: New home 692 sewing machine will not sew zig zag even with knobs in correct position, any clues?
the cam or gear that controls the zig zag could be damaged or
worn, I suggest the machine be checked
Posted on Nov 07, 2012
I have a Singer S18, stitches perfect. Attempted to use Zig Zag stich and decorative stitches, These are not working, It will make a few stitches then keeps stitching in place. Any Suggestions? Thanks
You probably need to widen the stitch width before it will let you sew. Or change the pressed foot to accommodate the movement of the needle when making decorative stitches.
Nov 20, 2016 | Singer Sewing Machines
Model 930.Why is presser foot not lined up correctly?
Is your needle position centered? The round dial on the top right is a combination zig-zag stitch width selector and the center silver dial selects the needle position. If it is pointed at the #2, then the needle should be centered and something (probably the needle bar) has been knocked out of alignment on your machine (which would probably mean repair service).
Also, if the needle is hitting the presser foot, you probably have a straight stitch foot on your machine which requires the needle be centered. To do any decorative or zig-zag stitching, the presser foot needs to have a wide space for the needle to swing back and forth. The zig-zag foot is marked with a zero.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&ved=0ahUKEwiP-OL76L7JAhWG9x4KHZ-6AgsQFghDMAM&url=http%3A%2F%2Fberninainstitches.com%2Fpdfs%2FBernina_Presser_Feet_Guide.pdf&usg=AFQjCNFihfp9MHOUl_6HmXxRrC8t3N32TQ&cad=rja
Dec 03, 2015 | Bernina Sewing Machines
My Kenmore 19233 refuses to zig zag stitch past 2mm wide. At 2mm it is a reliable stitch, moving toward 7mm it is a straight stitch with one or two zig zag blips.
Do you have it on zig zag or maybe it is in one of the hem stitches. Make sure you have not selected a special stitch. Sometimes with a small width setting it looks like no zig zag, then when you increase the length you see it is not.
Oct 20, 2014 | Kenmore 19233 Computerized Sewing Machine
Can I go from straight stitches to zigzag stiches and back in the same seam?
Hi Susie,
I can't tell whether you mean straight stitching and then turning your work 180 degrees to stitch atop the straight stitches in zig-zag, or continuing around the corner of your straight stitched side using zig-zag. But you can do either. You can mix up straight and zig-zag stitching at will.
Just ease up to a stop, ensuring the needle is positioned down inside the work when you stop.
Lift the foot.
Adjust to your desired stitch setting.
Lower the foot.
Turn the wheel toward you manually to ensure the stitches will be placed where you want them, and
Slowly engage the power again (via foot or thigh lever).
Hope this helps.
May 14, 2014 | Singer 3116 Simple
Zig-zag settings
you probably shouldn't be using a zig zag for that application. But the multi-stitch zig zag.
Please look at page 40 of your manual for information.
As for needle breaking check to make sure your need is the correct one for the thread and fabric. Also make sure your pressure foot is the one recommended for the stitch. Consider this... most thicker fabrics require a longer stitch.
Aug 21, 2012 | Singer Confidence 7463 Computerized Sewing...
Can lint get up inside the shaft that raises and lowers the needle?
the needle bar is not hollow,
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
May 01, 2012 | Singer Confidence 7463 Computerized Sewing...
What foot should I use for basic stitch or zig-zag stitch?
a all purpose foot or a zig zag foot will do both straight stitch & zig zag
Dec 16, 2010 | Singer Sewing Machines
I cannot get my tension adjusted correctly. I have lost my manual. Can you give me some help. Also, do I need a separate foot for the zig zag stitch.
usually a tension of 3 or 4 is good
only if the presser foot not is not made for zig zag--all the presser foot's that I've seen on new machines do straight stitch & zig zag,, if the opening in the foot is large then manually try a zig zag stitch to see
Nov 22, 2010 | Brother XR-65t Mechanical Sewing Machine
Ingenuity-needle hits pressure foot when zigzag stitching
Reduce the width of the zig zag as a short term fix, but it seems that you either have the incorrect foot attached, or the ZZ width setting needs adjusting.
If, when the needle is set to be centred, is it actually slightly off-centre ?? You may do worse than have a service done, explaining the issue you face as well as a general go over.
As this was posted some time ago, I hope it has been resolved for you.
Mar 17, 2008 | Singer 7436 - INGENUITY
New Home L-372 Mechanical Sewing Machine Logo
19 people viewed this question
Top New Home Sewing Machines Experts
Tally Girl
Tally Girl
Nava Hirshenson
Nava Hirshenson
Level 1 Expert
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
