Question about Universal Office Innovera 15971 Large Digit Commercial Calculator - Ivr15971
How to change the tax rate on a innovera calculator ivr-15971
After changing the battery on my innovera mini optical mouse IVR 62204 it is no longer connected to my computer
Are you sure that the new battery was a good one? If it is ok, change USB slot. If still not working, you've got some problem with USB dongle or the mouse. Generally, "mice", even wireleess are "disposable". If you have warranty, should take it for "service" and they shuld check problem and replace part. If no warrant, your only choice is to get a new mouse.
Oct 09, 2014 | Innovera Computers & Internet
How do I stop my IVR-16010 from rounding off my answer?
This makes zero sense, but you must press the "tab" button. Also I know this is two years too late, but no one has answered this question online and someone might find this helpful.
Aug 16, 2014 | Innovera 16010 16010 One-Color Printing...
I have an Innovera IVR 16015 calculator and need instructions on how to change date and time
I have an IVR-16015 calculator on my office desk. I too was looking for instructions on how to set the time and date and found this site. The previous information is wrong. I just discovered how to set it... The switch needs to be set to "ON", then press and release the blue "TIME" button to toggle between displaying the TIME or DATE. Depress and hold the "SET (=)" button for about 3-seconds to enter edit mode then use number keys to modify the displayed value. Depress the "SET (=)" button to save input and exit the edit mode. Pretty simple when you have the correct instructions, huh? By: The Fox
Mar 21, 2011 | Office Equipment & Supplies
Purchased new Innovera IVR-61020 and the Driver CD is bent and won't load. HELP
It doesn't seem like Innovera has a website or support of any kind. If you have Mac OSX or Windows 7, the Operating System may find and install the driver for you. Hopefully you have another mouse to use in order to do that. I wouldn't trust googling it and using a driver website download.
Mar 02, 2011 | Innovera Mini Wireless Optical Mouse...
How change percentage (tax) rate on Casio-1100TV?
FINALLY figured out how to change the tax rate! Press AC. Press and hold the Rate Set (%) button UNTIL THE CURRENT TAX RATE IS DISPLAYED. Enter the new rate you want (such as 7.5). Press the Rate Set (%) button again.
Mar 05, 2010 | Casio Office Equipment & Supplies
How do I program the calculator tax+ Tax- buttons?
1. How to set/ change "Tax Rate"
(1) If "Rate set" is printed above [%] key with your calculator,
1. Press [AC] and hold [%] for about two seconds.
2. Input Tax Rate and then [%].
* You can check Tax rate by pressing [AC] and then inputting [TAX+]
(2) If "Set" is printed above [%] key with your calculator,
2. Input [TAX+].
3. Input Tax Rate and then [%].
2. How to calculate Price-plus-Tax and Price-less-Tax.
(1) How much is Price-plus-Tax of 100?
Press [AC], and input 100 and then press [TAX+].
Calculator will display 105 if tax rate is 5%
If you press [Tax+] again, it will show the tax amount..
(2) How much is the Price-less-Tax of 105?
Press [AC], and input 105 and the press [TAX-].
Calculator will display 100 if tax rate is 5%
If you press [Tax-] again, it will show the tax amount..
Jul 29, 2009 | Canon LS-100TS Calculator
Mouse freezes up periodically (several times per day)
Have you tried changing batteries?
or check the current drivers.
Apr 24, 2009 | Innovera IVR62100 Mouse
Casio fr-2650 plus calculator
SETTING YOUR TAX RATE
you hold your set % button down for three seconds until set shows again, then hit tax rate button it shows your tax rate, change your tax rate then hit set your tax rate should be set.
cliff notes:
hold set% button
hit tax+ button
change the desired %
hit set done
Do rate the solution.
Apr 05, 2009 | Casio FR-2650Plus Calculator
Change the tax rate on calculator on MS-8TV
cliff notes:
hold set% button
hit tax+ button
hit set done
Mar 23, 2009 | Casio Office Equipment & Supplies
Universal Office Innovera 15971 Large Digit Commercial Calculator - Ivr15971 Logo
245 people viewed this question
Top Universal Office Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an Universal Office Office Equipment and Supply Expert? Answer questions, earn points and help others
