Question about Pioneer PD-R555RW CD Recorder
No i am looking for a operating instrution book for Pioneer PDR 555 RW CD Recorder.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 5 Answers
  • afecu Jan 15, 2010
    The above link no longer works, but I found the manual at diplodocs.com aka safemanuals.com. A direct link ishttp://safemanuals.com/user-guide-instru...
    Also look athttp://safemanuals.com/annexe_annexe%201... for the complete manual - sorry, my above comment just gives an appendix and I don't see a way to edit it.
I have a Pioneer PDR 609 CD recorder. I put a disc in and it says Pro disc din unlock.
This is nearly always due to cable problems. I think the cheaper optical cables can get 'kinked' quite easily, which would stop the signal coming through properly. So, first check your settings to make sure the correct cable type has been selected. If that's OK, try replacing the cable with a good quality one.
Jan 02, 2014 | Pioneer Computers & Internet
Disc does not spin
First do a lens celeanup, just in case.If it does not work It may be the motor. But before opening it I suggest to check if it is under guarantee.
Feb 24, 2008 | Pioneer PD-R555RW CD Recorder
My Pioneer PDR 555-RW keeps reading Mon1 or Moni when I try to record my CD from my mixing board. I need to send this wedding music, and it is trapped in my board. HELP!
That's just a MONITOR indication. It means you can SEE the audio from the selected input on the record level meters for adjustment or other reasons. It won't prevent you from recording. Set your levels then hit RECORD, let it set itself up and calibrate to the disc, start your source and hit Play or Pause to start recording to the disc.
May 14, 2011 | Pioneer PD-R555RW CD Recorder
CHECK message on Pioneer PDR-555RW display
have a Pioneer PDR-555RW with blinking CHECK message on display after repeatedly open/close operation. I cleaned ... - posted in CD Players
Jul 17, 2010 | Pioneer PD-R555RW CD Recorder
Can't get it to record
I experienced this problem a long time ago, i believe that it was because i tried to use a normal data cd-rw but the unit only reads audio discs. It has to be a cd-rw for audio only (will say cd-rw audio on the disc, whereas if it is a data disc it will simply say cd-rw.) Hope this helps..
Mar 13, 2009 | Pioneer PD-R509 CD Recorder
Wont record on blank pc disks!
I had the same problem and found that I was using the wrong type of CDs. If you look on the CD you have to use the CD that says Compact disc digital audio Recordable or Compact disc digital audio Rewrittable. After I used the Digital ones I could record on it. I then tried the CD on the PC and it worked. You can look on the top of the unit and see the information if you still have it. Hope this helps you.
Feb 23, 2009 | Pioneer PD-RW839 4-Disc CD Recorder
Looking for instruction manuel for old pioneer cd burner
DDownloadfrom this link
https://www.manualslib.com/download/585528/Pioneer-Pdr-L77.html
Jan 09, 2018 | Pioneer Computers & Internet
Pioneer PDR-W839 Disc Changer Jammed
look for a small pinhole and insert a pin while powered up to reset the device
May 26, 2007 | Pioneer PD-RW839 4-Disc CD Recorder
Pioneer PD-R555RW CD Recorder Logo
297 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
