Question about Home Security
How do you replace the NICD built-in battery in an E70 ELSAFE?
I am receiving a code either ser or 5er i opened my safe and some how it locked and the lock it out so it wont close
here is elsafe cust. support email address:
Elsafe support by email: noram@vcegroup.com
Dec 23, 2015 | Home Security
Tip
TalkAbout Distance Charging & Battery Options
The Motorola TalkAbout Distance and Distance DPS radios have a rechargeable NiCd battery pack (HNN9056 and/or HNN9044). Use of this battery pack is the best method for powering the radio. This type of battery pack has a 18-24 month life expectancy. You can determine the age of your battery from the date code on the back of the battery above the stop sign. The first digit is the year and the next two are the week of the year. Ex: 919 would read 2009 the 19th week.
The DPS model came with both a NiCd battery tray and an Alkaline battery tray. While the NiCd battery pack is the best option for fully powering your radio, along with being the most economical option, in a pinch or when charging is not available the 6 Alkaline batteries will power the radio for up to 18 hours. Note: Replacement battery trays are no longer available, it is advisable to keep both trays. If one fails, you will have the other as a backup.
The TalkAbout Distance is a repairable radio. The consumer replaceable parts are the NiCd battery pack, belt clip, antenna and charger.
on May 06, 2009 | Motorola Talkabout Distance DPS (10...
My Elsafe battery died (S30-705) and I can't open it! I wasn't given any type of key or anything!!!
You need someone to connect an Elsafe Servicing Unit to supply external battery power via the connection cable to power up the device so that you can unlock the safe. The servicing unit attaches to a 9 volt battery to rescue failed safes due to battery problem. Once the safe is open, you can replace the safe's dead batteries.
Option 2: Get someone to drill the safe open.
Jul 08, 2015 | Home Security
My elsafe is showing an "ser" error
My Elsafe is showing an 'ser' error. Pls Hepl! TQ!
Feb 27, 2011 | Safe International Sk-23 Digital,...
What charger should I get for my Evader EXB
I show your car uses 8 “AA” batteries, 6- or 7-cell NiCd or NiMH battery.
Radio Shack or The Shack will have a replacement and the store people should be able to guide you to the correct plug and polarity. NiCD and NiMH batteries are easy to work with, buy, replace and charge. If you use 8 AA batteries, that is 8 X 1.5 (volts) = 12 Volts DC. NiCD and NiMH style batteries should deliver about the same but dont expect to get performance from a NiCad battery as they dont offer enough power.
Apr 09, 2010 | DURATRAX Evader Exb 1/10 Electric Buggy...
Need new battery and I have a NiMH battery replacement. Can I use it on my phone? I have model number 25838GE6-A.
NiMH is a universal replacement battery. It will work in place of nicad and other types of rechargeable batteries, and will work with virtually any charger
Dec 22, 2009 | Uniden Cordless Phone
One of my Ryobi 18v battery packs (1400672) won't charge, the chargers red and yellow lights stay on. How can I trick it into charging?
Use
AC / DC Power Adapter Replaces Ryobi One+ Batteryhttp://lcdpayless.com/ryobi_one_power_adapter.php
Oct 22, 2009 | Ryobi Drills
Defective Ni-Cad Battery
Try Re-Conditioning the battery first. Full procedure at: ysuusy.com/easybatteryfix.html
"Cordless Power Tool Batteries and other batteries that contain Nickel Cadmium (NiCd) Cells can be Re-Conditioned to perform as well as new or even better than new. Proper maintenance after the procedure will insure years of usable life.
The First and most common procedure for Re-Conditioning a NiCd cell is by using a Technique called "VOLTAGE SURGING". Over time the crystals within a NiCd cell begin to combine and get larger. This causes them to loose capacitance and also break through the inner seals of the cell.
Surging the NiCd cell using a higher voltage causes the crystals within the NiCd cell to shatter and become smaller. These smaller crystals have a greater surface area and therefore contain a greater capacitance for energy. "
Jan 17, 2009 | Batteries.com 8148 Nickel Cadmium 2-Way...
Motorola t5000
I'm assuming you're using the NiCd batteries. NiCd batteries do not last forever and need to be replaced when they show a resistance to beign charged. To optimize the life of these batteries you need to let them fully discharge before attempting to charge them. This is impractical most of the time.
You have two choices:
1. Purchase a NiMH charger and AA batteries and use that INSTEAD of the CHARGER STAND and NiCd batteries. This type of battery can be recharged without the problems discussed earlier and will last longer... or
2. Purchase another NiCd battery pack.
Oct 24, 2008 | Motorola T5000 Two Pack 2-Way Radios with...
Home Security Logo
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
