Question about Husqvarna Garden
Macculoch M3540PD petrol lawn mower & black smoke & flame
We have a macculoch M3540PD petrol lawn mower and it throwing out black smoke and a flame what can it be and how do I fix it
Thanks for reading
Kelly
  • Frank
    Frank May 11, 2010
    no much, time to get a new one!
5 Suggested Answers
SOURCE: My lawn mower doesn't start and when it does, smoke comes out of exhaust
I used my mower two weeks ago. Now it won!t start, I check the air filter,change the gas, check the
spark plug and it was soaked with gas. I clean the plug and set the gap and it still won!t start. It
sound like it wants to start but it will not start.
please answer me fast
Thank you very much
Posted on Sep 17, 2008
  • 77 Answers
SOURCE: Brand new weed eater lawn mower blowing white smoke.
Pull air filter see if theres any oil in it,make sure the oil isnt overfilled. Push mowers usually smoke like that if theyre overfilled,or tipped on thier side,if there is oil in filter simply take filter off,drain oil to correct level,and run it till smoke goes away. If none of this is the problem rings are probably shot. Weedeater is a cheap brand and theyre made cheap too,not made to last.
Posted on Aug 12, 2009
  • 68 Answers
SOURCE: Murray 4.5 hp Q lawn mower runs rough and smokes.
White smoke indicates that it is burning oil. The smoke would be black if it was running rich. So probably the rings will need to be replaced eventually. These mowers are prone to problems but the carbie is least likely to be the problem. So before you adjust the carbie take the cover off the top and give it a good clean and check that all the hoses are connected and are not cracked. Then make sure the airfilter is clean, blow it out with an air compessor or better still get a new one. Then try it out agian. If this doesn't help there is two screws on the carby marked L and H. Turn these only 1/8th of a turn at a time and note or make their current position. Start with the H scew with the mower at full revs. Turn anti clockwise untill you get max revs then turn it back a bit. Running too lean will over heat the motor and damage it. Then if needed adjust the L (or Low)screw. If you get black or grey smoke when you push the throttle up from idle to full its too rich so turn clockwise. If if slows before it picks up to full revs turn anti clockwise.
Posted on Sep 06, 2009
  • 3 Answers
SOURCE: Webb Diplomat 350 Petrol Lawn Mower stops running 10 minutes
The 'DIPLOMAT' series of WEBBs is bad news, its NOT a WEBB! Webb were swallowed by qualcast-atco-suffolk, who dunped Webbs tooling, & dressed up punches & commodores in thin disguises, dumped the briggs & stratten engine for their own alloy job, & charged a rip off premium for the Webb decals!
The qualcast suffolk alloy engine suffers from a WIPAC electronic ignition unit. As it gets old, it fails, sometimes completely, sometimes as it warms up. Once cool, it works for a while again.
Not too hard to replace, but hard on the wallet, £69 genuine, £40 fake! On the whole its not too bad an engine if cared for & oil changed often. better to look on ebay for a cheap used HONDA engine & transplant! R-E-L-I-A-B-L-E !............I did! ( £35 honda gc series, 5,5hp! )
Posted on Apr 02, 2010
Testimonial: "Thanks very useful information.....Many Thanks"
I have a Rover Push lawn mower. Type 02031, Serial Number 0254990, Briggs and Stratton Quantam40 XTRA. My son has put two stroke petrol mix into this 4 stroke mower. Is this a problem?
Your mower is likely to throw out clouds of blue smoke, just as a 2 stroke engine does.
The spark plug may become oily and fouled, misfire and splutter/stall.
However, it's not a really serious problem and you're not going to cause any permanent damage. The easiest solution is to get a tube and syphon the 2 stroke mix out of the mower's fuel tank.
Mar 03, 2017 | Briggs Garden
Starts, but halve the power
Has the mower been tipped on its side since you used it last?
are you using fresh petrol ( less than 6 weeks old!?)
does it smoke much when running?
If you could answer these 3 questions I maybe able to help!
Jan 17, 2014 | Electric Lawn Mower
Petrol mower starts with smoke pouring out run ok for a while then peters out then it will not start again.
you have way to much oil in lawn mower check oil level and remove some until you see the marks on the dipstick
Aug 05, 2013 | Garden
Mower will start but runs rough & stops
Is the carb flooding?is there black smoke coming from exhaust when running, if so it could be the carb over filling with fuel. Is there petrol leaking out of the carb? If not check the fuel pipe is in good condition
Jul 22, 2013 | Briggs & Stratton Lawn-Boy Insight Series...
I have a task force electric push mower and while mowing my lawn it started to smoke and shut off.. now it wont turn back on what could the problem be
it probably burn up if it smoked throw it away get a new one not worth sinking money into it to fix it
May 26, 2013 | Garden
Sovereign 35 classic white smoke
White smoke usually means there is water getting into the cylinder head. If your mower is not water cooled then there might be some water in the petrol. If the mower is water cooled then the cylinder head gasket has gone and needs replacing. Good Luck. George
Mar 29, 2013 | Garden
Oil and smoke shooting from the muffler. Please help!
check the oil to see if it smells like gas if so a carb problem was it stored other than flat?
Jul 07, 2012 | Garden
Lawn mower throwing oil from muffler
If the mower has been tipped it will have sent oil up the breather and into the back of the air filter box, this will soak the paper filer and smoke badly, remove the air filter cover and filter, run the engine with these removed until the smoking stops, now replace the filter with a new one, when tipping the mower only tip it back on the handles, not from either side.
Jul 07, 2012 | Briggs & Stratton Garden
Craftsman 6.75hp self propelled mower starts and turns off
I think that this is a 4stroke engine and runs on neat petrol.Have you been putting oil in with the petrol like a 2 stroke engine needs because this would account for the smoking.If not the check that you havn't overfilled the gearbox oil.
Jun 12, 2009 | Craftsman Garden
Garden Logo
180 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
