Question about LG 42PX5D 42 in. Plasma HDTV
No Power 'LG 42PX5D 42IN.
No Power at all. Everything is plug in the 10amp - 125 v power cords. Does really make a difference frm the original power cord 7am - 125v? Is this the reason why is not turning on? No sign of life at all
sandrew
  • 2961 Answers
SOURCE: SCREEN FOR LG 42PX5D 42 in.
I have dealt with Lg in the past regarding screens and they are unable to sell them as a spare as they are so expensive, they are only used in production and a complete new HD TV is cheaper to buy than a screen. for example LG37LP1D £900.00, a replacement screen £1500.00
Posted on May 04, 2007
SOURCE: LG 50PC5D 50 Plasma Won't turn on
If you check underneath the t.v there may be a button that you need to push. then you can use the remote to turn it on. took about 2 hours before I found it.
mine is located on the bottom left, right underneath the screen.
Posted on Dec 31, 2007
  • 86 Answers
SOURCE: My 42"LG 50 TV will not turn on
One important step to see if you are having an internal problem is to perform a power drain.
1. Unplug the product's power cable so that the device is not grounded to the house. Do not simply turn off the power-bar if one is in use.
2. Press and hold in the products power button for 1 minute to release the retained electricity from the capacitors and circuit board. 3. Plug the product back into the wall outlet rather than a power-bar to rule it out of contributing to the problem and turn the device back on.
If this does not work but you are still seeing a LED lit up, there is probably a problem between the TV's power supply and the mainboard and service maybe required.
Posted on Oct 14, 2008
SOURCE: LG 42PC3D-UE Turning on, clicking, then turning off & repeat
replace the power supply it is a simple fix if you can hear the relays click 2 times or more replace the power supply board you can order them from UNION Electronics ask for kyle when you call ,,if the power supply isnt the problem then it will be the control board located below the power supply board I have repaired a few of these the voltages are marked on the power sullpy board conections be careful there is a VERY HIGH AND DANGEROUS VOLTAGE FEEDING THE X AND Z BOARDS DONT REMOVE THIS WITH SET PLUGED IN IT IS HOT ENOUGH TO BURN A HOLE IN YOUR SKIN AND EVEN DO MORE DAMAGE TO YOU if your not sure what to do Call LG they have a good support theam there
Dave
Daves Tv
Posted on Jul 24, 2009
toolkits
  • 1099 Answers
SOURCE: My LG 42"tv shuts off by it self
hello, The best way to fix this is by opening the back cover of the television set.
The power light may be flashing or if you are runing with a series light bulb it may be cycling on and off continuously. There may be a chirping or clicking sound from inside the set. (Note: using too small a series light bulb load during testing for the size of the TV may also result in this condition.)
If there is a low voltage regulator or separate switching supply, it could be cycling on and off if the horizontal output, flyback, or one of its secondary loads were defective.
Does this TV have a separate low voltage regulator and/or switching power supply or is it all part of the flyback circuit? For the following, I assume it is all in one (most common).
Some simple things to try first:
Verify that the main filter capacitor is doing its job. Excessive ripple on the rectified line voltage bus can cause various forms of shutdown behavior. An easy test is to jumper across the capacitor with one of at least equal voltage rating and similar capacitance (make connections with power off!).
Use a Variac, if possible, to bring up the input voltage slowly and see if the TV works at any point without shutting down. If it does, this could be an indication of X-ray protection circuit kicking in, though this will usually latch and keep the set shut off if excessive HV were detected.
Posted on May 20, 2010
Lg ibm multinet i tower allows power to the motherboard but wont start up, what should i do?
remove the power cord, remove the bios battery, short the two contact together in the battery holder for a few seconds, replace the battery and power cord and try again.
if that doesn't work, start removing items/plugs (not the big 20/24 pin one) from the motherboard until you get beeping noises.
if still nothing then put everything back and try a different power supply.
if that doesn't work, your motherboard is probably dead.
Apr 18, 2014 | Computers & Internet
No power.
Check and replace the main power supply regulator board as card basis. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 21, 2014 | Hitachi P50H401 50 in. Plasma HDTV
Clicks over and over like power wants to turn on but just clicks
The power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jul 14, 2010 | LG 42PX5D 42 in. Plasma HDTV
50" lg plasma tv will not power up
The problem with the set is bulged electrolytic capacitors in the power supply.
May 16, 2010 | LG 42PX5D 42 in. Plasma HDTV
My LG 42Px5D Plasma; when I turn it on, it is blinking for a couple of minutes, then it is normal again. It started happening only a couple of months ago. What's wrong? Thanks
THERE WILL BE A CAPACITOR GONE FAULTY IN THE POWER SUPPLY,,
IF U OPEN UP THE BACK LOOK ON THE TOP OF THE CYLINDER TYPE CAPACITORS THAT STAND UP THE ALLOY ON TOP SHOULD BE FLAT ON THEM ALL ... IF ONE IS BULGING AND TOP HAS BURST OR READY 2 BUST THEN REPLACE WITH A SOLDER IRON,, THIS WILL FIX THE SLOW START UP AS THE CAPS NEEDING TO GET WARM TO FIRE UP THE PSU,,
Feb 21, 2010 | LG 42PX5D 42 in. Plasma HDTV
LG LDS5811BB power cord is good, however the dishwasher is not getting any power. No lights no nothing.
There is a fuse on power unit, that should be tested first, check also a different outlet.
Aug 09, 2008 | LG Dishwashers
Dec 26, 2007 | LG 42PX5D 42 in. Plasma HDTV
Transparent horizontal bar
disconet the ground on the power cord of your tv will fix the problum. or the subwofer power ground .
May 14, 2007 | LG 42PX5D 42 in. Plasma HDTV
LG 42PX5D 42 in. Plasma HDTV Logo
229 people viewed this question
Computer Repairing
Computer Repairing
