Question about Saeco Incanto Classic Espresso Machine
Push ok to start boiler
Saeco primea ring, just got the machine and displays: Push ok to start boiler filling I do that and it says cycle interrupted and starts all over again " Push ok to start boiler filling" Not sure what do do at this point. Cold water comes out where the coffee normally dispenses.
  • Ernest R
    Ernest R May 11, 2010
    Try opening the steam valve that might vent water circuit.
    Problem Solver:
  • 8 Answers
Try opening the steam valve before pressing ok.
This will let water into the boiler before the heat element comes on.
Posted on Jun 24, 2009
Hi, I have a Saeco Primea Touch Plus, in the display it says error 5. What ca I do? Regards, staffan
I had that error too, the very first day after i received my Saeco Primea Cappuccino Touch Plus from Germany. The curiosity is that the machine was able to prepare a cuple of cups and suddently died with 5 in screen. Going to the service, they said that error 5 is about a lack of pression in pipes, probably due to the unprotected transport to Romania. I don't know if they fixed alsi some jonctions, but i had to pay for few rings. Everything took a day in service, but now is working fine. Hope it was usefull and my english enough inteligible.
Apr 17, 2011 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea Ring stuck on warming up
Hi
I had the same problem and could solve it but i had take the machine apart.
Under boiler you have 2 thermo fuses that can be resetted. After reset i have checked if boiler get 220volt, It did for a short while but the fuses goes off again.
That means boiler is ok, it gets hot but fuses goes of due to temperature reach over 170 degrees celcius. That means that the power is olways on to the heater and doesnt stop to heat.
In diagnostic i could see that the temperature sensor does show the high temperature. That means that temp. sensor is ok which leads to the controller of the power to boiler. On the board i found big heatsink and a triac atached to it. I soldered it out and measure that it was spoiled.
Ordered new one for 3 euro. Soldered new one on the board and the problem was solved.
Original was BTA16-700CW but they didnt have it so i replaced it with BTA16-600CW, difference is that original one can handle 700volt the new one 600, but there is only 220volt it will controll anyway so that was ok.
I atach a picture.
Regards, Pawel
Nov 18, 2008 | Saeco Vienna Espresso Machine
Coffee stopped coming out of nozzle
The problem with your machine is the connection where the brew unit connects to the dispensing head is broken. This is why the machine is leaking into the dump box. I wish it was an easy fix, but it is not.
You will have to get the machine serviced.
If you would like to have your espresso machine serviced please visit the service page of our website:
http://cerinicoffee.com/Espresso_machine_service.asp
Cerini Coffee Services
Authorized Saeco Service Center
Nov 14, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Machine won't stop descaling cycle
MAKE SURE YOU DO NOT SHUT DOWN YOUR ESPRESSO MACHINE WHILE IN THIS MODE OR IT WILL INTERRUPT THE CYCLE. BE SURE TO CAREFULLY UNDERSTAND WHAT THE MACHINE IS ASKING FOR AND USING THE MANUAL MAY HELP YOU WITH THIS PROBLEM. WE HAVE NOT SEEN ANY OF THE PROBLEM YOU ARE SUGGESTING, BUT THERE IS ALWAYS A FIRST. IF YOU NEED SUPPORT AND YOUR MACHINE IS LESS THAN 1 YEAR OLD CONTACT SAECO AT 800-933-7876.
IF YOUR PRIMEA IS OLDER THAN ONE YEAR YOU CAN CONTACT CERINI COFFEE @ 718-584-6120 OR VISIT OUR WEBSITE AT WWW.CERINICOFFEE.COM
Oct 30, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea Cappuccino Ring--stuck on "boiler filling" mode!
Hello, I had the same problem, therefore the machine has gone to a repair centre. The problem is caused by a mechanical switch in the machine, that doesn't work properly. To repair it you've to open the machine completely, but that’s not easy. Because there is nothing broken you’ll should have warranty because it is a production failure. The solution in my case was to heat up the switch and push it a little together so that the contact works properly. It is the switch that you hear when you turn on the machine.
Oct 29, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Water filter initiation failed
Did you this steps?
Fill the tank with fresh water.
Let the filter soak for 30 minutes.
After 30 minutes discard the water in the tank and refill with fresh water.
Place a container under the spout.
Press the cup button in the middle.(Filter on, yes)
Press the cup button again.(press ok, initialisation)
The machine initialises the filter.
Press the cup button again.(done initialisation)
Then press MENU repeatly. When the "exit" message is displayed, press the cup button. In this way, the machine ends the start-up phase.
Best regards
/Mirran
Sep 24, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Walter initiation failed
Did you this steps?
Best regards
/Mirran
Sep 24, 2008 | Saeco Vienna Espresso Machine
Saeco Primea RIng - Cycle interrupted - only a few drops come out
Hi
Have you found a solution yet?....we have the exact same problem....
Mar 16, 2008 | Kitchen Ranges
Saeco Incanto Classic Espresso Machine Logo
267 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
