Onkyo pl-25f - Audio Players & Recorders
2 Suggested Answers
SOURCE: Operating instructions for Onkyo PL-25F turntable
I have the same problem with mine! If i budge the arm by pushing it to the left a bit, it seems to catch. i think the motor on mine is worn out and cannot get started on its own, but with help, it will slowly move on its own to the edge of the vinyl and drop into playing position. If that doesnt work for you, you might need to clean the belt for the arm motor, or buy a new motor.
Posted on Sep 11, 2009
Where to attach external antenna on model hta-25f
For the Hitachi HTA-25F, the balanced wire antenna connections are the row of terminal screws on the bottom - inside the blue highlighted box. If using a 75 Ohm coax (unbalanced) wire connection - use the connector in the top right corner of the blue highlighted box instead.
Jul 27, 2015 | Audio Players & Recorders
Refrigerator icemaker repair
The ice maker does its own thang. All it needs is power and a good water valve to supply the water. Also you paid the water bill helps too. Anywho when the temp in the ice maker mold drops below 25f the harvest cycle begins. The mold heater is activated and loosens the ice. When the ice starts moving the heater shuts down and the motor carrys over and drops the ice. The ice maker then asked for and gets water from the water valve. So what goes wrong? Watervalve solenoid burnt out, water valve dripping like a faucet make a stalagmite in the fill tube blocking fresh water to ice mold. If that is ok then something inside the icemaker went haywire, replace it. When replacing the ice maker replace the watervalve. Note: if temp inside icebox freezer does not get to 25f any ice maker new or existing ain't gonna make ice. Be sure to clean the coils down by the compressor and the kickplate so the maximum amount of airflow is running down there and make sure the cardboard panel back there is in place.
Sep 26, 2013 | Dryers
Water is not going into icemaker
Their are 2 possible things wrong. The water valve or the ice maker. Nothing else in the ice box determines water fill but the ice maker itself. Since the water valve needs to be replaced when you buy another ice maker( their is no way to repair an electronic ice maker) I say replace the water valve first and see if the ice maker starts working. Then if you have to get a new ice maker you already have a new water valve. First before you do anything stick a thermometer in the freezer and verify the temp is below 25F. An ice maker will not function if the temp is over 25F in the freezer.
Jun 07, 2010 | Hotpoint HSS25GDMWW Side by Side...
What percent should it be set at. It is 68F
Hi google the make it will give you the temp setings
Jan 10, 2010 | Aprilaire 550 Humidifier
Onkyo receiver memory power backup not working
How change battery and the battery model
Dec 22, 2009 | Onkyo TX-SR700 Receiver
Mar 08, 2009 | Audio Players & Recorders
25f-m40
i do not know but i at one point had three of theses tv's at once have an extra
Aug 13, 2008 | Sharp 25K-M100 25" TV
Amp Protection Mode
from LANCE P: I fixed it. Be sure that all your speaker connections are perfect. No element frays that can arc, no +/- problems, no single barely connected wire. My problem was volume sensitve and I evidently had one + wire that was loose in the back. I corrected it and ran it all day with surround and good volume with no problems. So diligently check ALL YOUR SPEAKER CONNECTIONS, both in the back of the unit and at your speakers
Feb 27, 2007 | Onkyo TX-SR502 Receiver
94 people viewed this question
 Grubhead
Grubhead
