This often happens when you step up several versions at one time. A suitable workaround is to load your old version, EXPORT the data from the unsupported version and then IMPORT into the new version. Individual Software, the manufacturer of the package has great technical support--if this doesn't meet your needs, please contact them directly! http://www.individualsoftware.com/support/
just opened up a atw-t51 transmitter. (carefully prise apart the two halves of the case with a sharp blade). The aerial is soldered to a terminal post on the circuit board, so anyone competent with a small sodering iron should be easily able to swop the aerials for you.
The copier will inform you when it's out of Staples. To check the staples, open front cover of the finisher (device on left that catches copies) There should be a pictorial diagram on how to remove/install cartridge on inside surface of cover. Page 7-12 of the Copier Reference Guide if your finisher has 3 trays. Page 7-38 of the Copier Reference Guide if your finisher has 1 tray. Hope this helps.
Sorry for the delayed response, I just found this one...
The issue with depth is usually one of 2 things:
1) Insufficient pressure (bad regulator on compressor or incorrect setting).
2) Bad seals within the gun.
When was the gun last serviced? Have you looked at the O-rings for any signs of damage? All it takes is a little leakage of pressure and the plunger won't have enough thrust to set the staple as expected.
It is very difficult to find the Motorola F3c. The F3 sold by Best Buy does not work on Verizon because it is a GSM phone. However, I have found that there are quite a few F3c phones for sale on Indonesian cell phone websites. Although I have not tried it myself, you could buy one from a seller in Indonesia and hope that it works in North America.
My PaperPro Prodigy stopped firing staples. Examination of the hammer mechanism was fine. (apparently sometimes an internal part can break) Check with stapler opened and no staples. Hold the safety lock pin down with a fingernail or sticky tape so you can check operation of the hammer mechanism. Should withdraw to clear staple compartment and then fire. If this looks good, examine the roof of the staple compartment. Mine had a little lump of brown grunge in the roof of the staple compartment next to the hammer - stopping the staples from sliding up into firing line. Scraped it out and works fine again.
