Question about AT&T 8925 Tilt Smartphone
HTC Tilt (Trouble Reading SIM Card)
When I put my SIM card in it just says sim card is missing. Sometimes it will recognize it, sometimes it won't. "The SIM Card is missing. You can still make emergency calls if your service provider supports it." HTC 8925
The phone worked fine for about a year or so, with this same SIM Card. I have cleaned the SIM Card contacts, and verified it is installed correct.
  • 2 more comments
  • Anonymous May 01, 2009
    I have the same problem. Mine worked for a year and a half and randomly stopped working. I tried doing a hard reset and it still doesn't work. I even changed out SIM cards.
  • anonyuser125 May 15, 2009
    Just posting incase it helps others to figure out how wide spread a problem this could be. I have an 8925 that is about 9-12 months old and it developed the exact problem, reporting no SIM was installed. I've flashed the ROM to 1.62, tried numerous SIMs, cleaned contacts and card. Nothing has helped.
    I even tried a trick I had to use on an older different phone. I opened the SIM door, flipped the tiny switch to the closed position so it doesn't think the door is opened. Put downward pressure on the SIM during the entire boot process, but that didn't help either :(.
    It works sometimes, maybe 1 out of 50 boots. I confirmed the SIM works in a different unit every time.
  • Anonymous May 19, 2009
    Different, yet same problem.... I get the same Sim Card missing error, but ONLY when my Tilt is closed! If I leave it open during boot, it sees the Sim card, and I can make calls. If I close it, the signal disappears and eventually the Sim card symbol shows up. If I RE-OPEN it after it can't find the card, goto Wirless Manager, put it in Airplane Mode, then back into phone mode, it will find the Sim, and reconnect my signal. I just tried the paper in b/w the metal brackett trick to no avail. Anyone have any ideas or clue to what I should do? Thanks in advance!
  • phatphreakk May 19, 2009
I posted a little too early. There was one other trick I've used and I guess I should have started with that. The problem is indeed related to the SIM not getting enough downward pressure on the contacts to be recognized.
So I took a small strip of paper, about 3/8" by 1 1/4". I folded it three times. When you fold it one end will be closed and the other end will have the two edges of the paper that can open up. Using the open end will make it harder to slide under the bracket. So you will want to take the closed end and gently side it above the SIM card underneath the silver metal bracket that holds the SIM in place.
I used a post-it note as the paper but anything will do. It was working with just a double thickness but I wanted to be sure so I moved up to three layers. Depending on the tolerances of your phone you might be able to only do double layer and still be able to slide it in. Or you might need to go to four layers.
I hope this solves it for you.
/text for Google's indexes so others can find this: HTC Kaiser 8925, Cingular 8925, AT&T Tilt 8925, SIM Card is missing,
Posted on May 15, 2009
  • 4 Answers
Yep I agree with the paper trick. My SIM card was not being recognized so after resetting my phone AND getting a new SIM card I finally folded up a small piece of tissue and pushed the cover down until I heard a little click and locked it as much as I could. Seems to work now! Hooray! Simple, but seems like a common problem with this phone.
Posted on Jun 04, 2010
Thanks for your post, anonyuser125.
I've found this thread using google, after my Samsung SGH-D830 started continuously setting itself to SOS-mode when the tilt is (was?) closed. Also, as it was laying on the table next to my laptop, I sometimes noticed how it was sort of resetting itself (rebuilding it's connection).. One time it showed a SIM-card reading error :P
Hopefully your paper-fix will work here as well! :)
Posted on Feb 02, 2010
I have an unlock code for my HTC Tilt 8925, but when I put in my Net10 sim card to unlock the phone, it doesn't recognize there is a sim card inserted. is there a way around this?
i think your phone is locked to your provider. you need to unlock it to use it with other provider, you can unlock it using codes. codes are safe and simpler way in unlocking a phone. i unlocked my phone through codes from this site. WickedUnlock.com check it out.
Jun 09, 2011 | HTC Tilt 8900 Smartphone
I have problem with my htc touch diamond its showing sim card missing error
Hi there, Sometimes a SIM card can come loose in the back of the phone. Take off the back of the phone and take out the battery. Locate the SIM card. It's normally white and rectangle. Pull it out and then push it back and and make sure it is tight. Put the battery back in and let it boot up and see what happens. If it doesn't work, it sounds like you need a new SIM card, so you will have to go to your carrier.
Jun 06, 2011 | HTC Touch Diamond Smartphone
"Sim Card is Missing"
This is not a big issue, what you need to do is to just upgrade the OS of your handset, actually your current OS is corrupt either due to some malfunctioning or due to some file you have tried to download from the web. Just simply check the latest OS available and replace it with your current one. I hope your issue will be resolved after doing this.
Feb 21, 2010 | HTC Tilt 8900 Smartphone
I have a problem with my Tilt too.
you might need to replace the SIM card connector. you need to disassembly the unit and replace this connector with its flex cable.
you can find this part on eBay for about $15.
if you need directions for disassembly your device, you can find them here:
HTC TILT/KAISER service Manual
Aug 29, 2009 | HTC Tilt 8900 Smartphone
No SIM card inserted
blow the hole of the slot theres is probably dust and dirt blocking it from going through
Jul 27, 2009 | HTC Tilt 8900 Smartphone
clean the contacts on the sim card
Feb 28, 2009 | HTC Tilt 8900 Smartphone
Sim card missing for htc touch p3450
its a hard ware issue try putting a piece of paper over ur sim card to press it against the pins on the phone sometimes it gets loosen and does not detect sim cards or try restting the device as follows else go for service centre help but try these solutions first
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
Feb 16, 2009 | HTC Touch P3450 Smartphone
HTC Tilt When I put my sim card in the phone it tells me "Sim Card Missing" and When I put the sim card in another phone it works fine.
when i put my sim card in a at&t tilt phone it tells me to enter a sim block code. when i enter my puk number it tells me its invalid. what code should i enter
Sep 12, 2008 | Lands Phones
Open Questions:
AT&T 8925 Tilt Smartphone Logo
3,770 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
