Question about KLH DVZ-2500 System
Need KLH hT200 SPECS - KLH DVZ-2500 System
I have a pair of KLH AV5001 speakers and I have them hooked up, there is sound but it's distorted and there's zero base, an instruction manual or any advice would be great, thank you.
Without knowing what they're hooked up too.. SOUNDS like your uder powering them, OR over powering them. Look at the back of the speakers the wattage is what your looking for, look at your amp, example: 1000w speaker running on 50w amp = not good.
Jul 05, 2016 | KLH Audio Players & Recorders
HOW DO YOU USE A TURNTABLE ON A R3000 KLH
Please refer to user guide specs about your Turntable for the Output type That is MM or MC (Moving Magnet or Moving Coil) then on the receiver look for PHONO input and interconnect
Jun 16, 2015 | KLH Audio Players & Recorders
I DON'T KNOW ALL FEATURES AND CONNECTIONS FOR MY KLH R5100 AUDIO VIDEO RECEIVER.I NEED A MANUAL FOR MY RECEIVER.
I don't have the manual with me. I found KLH R 5100 with user manual in the following link. Tray to contact them.
OK
http://www.ebay.com/itm/KLH-R-5100-Receiver-Hi-Power-/250902259353
Nov 01, 2011 | KLH R5100 Receiver
I have a klh 116615p bg11 12 sub and need to know the watagew it doesnt say
This woofer was taken from a KLH Pro-71 Series. These were the top of the KLH line from ~94-99 when it was still a real company and not just a name. The woofer is rated for 5-350 watts at 8 ohms. Source: KLH Pro Series-71 Spec Sheet.
Apr 06, 2011 | KLH Audio Players & Recorders
I need knobs for the KLH 21 radio
I would check with KLH first but if you have no luck, you might try at Electronic Goldmine who will not likely have the exact knobs but may have some that will work:
Elec. Goldmine
Enter 'knob" in the product search window.
Feb 16, 2011 | KLH Model 21
Need a product manual for a klh 9906 home theater system with 4 satellite speakers a center speaker and a bassbite II
Try the KLH site. I have downloaded (for free) info on KLH products. Not much on technical stuff, but set up info and connections.
Jun 12, 2010 | KLH BB-II Subwoofer
Can't find specs/maker of klh 900b tweeter
KLH 900B tweeter specifications: 6 ohm, 40 watts. By the way, KLH's QC for speakers could be improved. One of my 900B tweeters quit because the spacing for the voice coil was way off reasonable tolerance and the body of the speaker coil base pillar (ie: magnitized part) was off-center - and cauesd the coil to ware and short. I contacted KLH but they did not respond.
Sep 19, 2009 | KLH 900B Main / Stereo Speaker
Need a Manual or help with System
YOU NEED TO HOOK YOUR RCA CABLES FROM YOUR DVD,TV,AND DIGITAL CABLE TO THE INPUT SIDE OF THE SURROUND. HOOK THE RCA CABLES FROM THE TV TO THE AUX SIDE AND THE DVD TO THE VCR INPUT, AND THE DIGITAL TO TH LD SIDE OF THE INPUT YOU CAN SWITCH BETWEEN THE 3 ON THE FRONT OF THE SURROUND.BY MOVING THE KNOB. YOU WILL GET NOISE FROM THEM THEN TO THE SPEAKERS.
May 24, 2008 | Emerson HT200 System
Klh tv codes
Hi my name is Lawrence Harris and i need some codes
for klh universiral remote control.
Thank You....
Sep 21, 2007 | KLH 13" TV
KLH DVZ-2500 System Logo
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
