Question about NorStar M7324 Telephone
I cant seem to programme the meridian m7324 when i put in the password **23646 it does nothing it wont even go to the password bit just freezes and does feature time out , i cant change the names or the times or anything and i need to do this as everything is set wrong...please help x
  • lotte_tottex Apr 23, 2009
    no i have tried both it wont do anything, think i need to set the passwords or something is there a way i can do that?
  • 192 Answers
Actually, you have to press the:
-> FEATURE button first
-> then type in * * 2 6 6 3 4 4 (**CONFIG)
-> the password is 2 6 6 3 4 4 (CONFIG) -or- 2 6 3 4 3 (ADMIN)
What are you trying to do in programming?
Just to let you know, once in the programming, and you start to make changes - document the changes.
Because if you change something and your system doesn't work anymore, you then can change the settings back -or- call in a Norstar Technician, you can give that person your notes on what you changed to fix your issue.
Posted on Apr 25, 2009
    President:
  • 2,992 Answers
I think you need to enter the password **266344 (CONFIG) first, then **23646 (ADMIN). The first is the password that gets you into programming mode and the second is the password for the programming level you want.
Posted on Apr 23, 2009
Trying to change the time/date
Did you try 23646 (admin) for the password too?
Mar 11, 2015 | NorStar Lands Phones
Cannot acces AdminSystem using **23646 what can I do? I do NOT want **266344, I need ADMIN SYSTEM. HELP!!!
Have you tried (F)**ADMIN ?
What specifically are you trying to do? (F)**CONFIG usually gives access to everything including the lower levels like Admin, Time, etc.
Feb 10, 2015 | NorStar Meridian M7310 Phone
Code for date & time
Depends on which system you have. M7310 is just the phone model which is compatible with all norstar meridian systems.
The easiest way (which only works on one of the phone system models) is to dial Feature ** TIME
and use 23646 as the password. If feature **TIME doesn't work for you, it might be best to do it with someone over the telephone since it can be slightly tricky.
May 10, 2011 | NorStar Meridian M7310 Phone
Unable to change the time on the phone
If feature ** 266344 with a password of 266344 didnt work you can also try feature ** 266344 with the password of 23646 or the password of 727587.
Also, on some versions you can try feature **8463(time) with the password of 23646.
Mar 20, 2010 | NorStar M7324 Telephone
Meridian M7324, Mailbox locked, feature 983 not available, #120000 is invalid. Help
Feature 983 defult password is 120000 for 2digit locals and 1020000 for three digit locals and 10020000 for four digit local > Don't use # key
Nov 24, 2009 | NorStar M7324 Telephone
Norstar 7324 time change
Programming should be done from the M7310, M7324 or the T7316E set. Administration access code: Feature * * 266344 which also is Feature * * config.
If asked for a password enter 23646.
When in programming2.gif just press the next button(lower right arrow) until you see what you want to change. Then press show ( top right arrow) ,then change if you want to change it. If you pass it, just press back (lower left)
Example: To change the Time & Date Press next until you see Time & Date. Then show Then change Then change again, change it if you need to, Then next again until you see what you need to change. For example; only the hour needs to be changed for day light savings time. Just press next until you come to the Hour. Then Change it. Then press release RLs when your done.
Sep 21, 2009 | NorStar Meridian M7310 Phone
How can I change the name display on my Nortel M7324? F**ADMIN is not programmed...now what?
There is another way, do a FEATURE * * 2 6 6 3 4 4 Password is ADMIN (23646)
Then you will need the template:
You should see TERMINALS&SETS: Press the Enter SHOW SET:___ enter the extension Press the Enter Keep hitting NEXT till the name shows up and press change Type in the new name and press NEXT to save the change Hit RLS to exit programming
Aug 11, 2009 | NorStar M7324 Telephone
Handset STILL wont ring
Pretending that you have the right System Admin code and are using a CICS, here's the chart. If you don't have the right password, you won't see the prompt.
http://public.carl.airpost.net/Nortel/CICS_Programming.pdf
Carl
Jul 03, 2009 | NorStar Meridian M7310 Phone
Change name on a Nortel M7324
1. Press the Rls button then ** FEATURE 266344 (CONFIG)
2. Password is 23646 (ADMIN) The display reads Terminals & Sets
3. Press SHOW ans enter the Extension for which you want to enter a name.
4. Press SHOW, again
5. Press the NEXT key until the display reads NAMES at the top left corner.
6. The bottom right corner reads CHANGE, press the far right soft key.
7. To move from one letter to the next use the far right and far left soft keys or the # key.
8. When you are finished Press next.
9. Press the HEADING key to get back to TERMINALS & SETS and start again!
Navigation Keys: Line 1 = HEADING Speed Dial = SHOW
Line 2 = BACK Last No. = NEXT
This can only be done from the main handset and only one at a time. The Soft Keys are the three small buttons right bellow the screen.
Jan 28, 2009 | NorStar M7324 Telephone
Trying to set time
try using password 266344
Dec 09, 2008 | NorStar Meridian M7310 Phone
NorStar M7324 Telephone Logo
284 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
dan4261
Level 1 Expert
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
