Question about Toshiba Satellite U205 Notebook
Satellite toshiba u20 c660 driver - Toshiba Satellite U205 Notebook
Heifentrixx
  • 220 Answers
SOURCE: Can I Download toshiba satellite C660 driver?
Here is the link.
http://www.all-driver.com/notebook-driver/toshiba-satellite-c660-drivers.html
you can download all the drivers you need for you laptop for Windows XP and Windows 7 Operating System.
Goodluck Hope i help you. Please rate my solution. Thanks.
Posted on Jun 30, 2011
  • 5370 Answers
SOURCE: Satellite C660-2DL won't turn on
Toshiba Satellite PC Notebook will not turn ON:---For this problem click the link below:---http://howtobyme.blogspot.in/2012/02/toshiba-satellite-notebook.html
---------This will help.Thanks.
Posted on Feb 22, 2012
technolust
  • 340 Answers
SOURCE: need to update bios toshiba satellite c660,using ubuntu live dvd, will not boot hard drive, all normal recovery options used up
Hi There,
There are currently no easy ways to update a bios through linux at all - including live cd's. Your best bet is to make a bios update USB stick (or floppy depending on the age of the computer)
Here's a link to those instructions:
http://www.biosflash.com/e/bios-boot-usb-stick.htm
Alternatively, speaking from my own experience with a similar situation, you can take the hard drive out, use it in place of the usb stick, boot from it, update your bios, and go from there.
Posted on Jun 06, 2012
Testimonial: "Matt, exactly what I have been searching for, I am well advanced in years so will take me a while to configure this, I found the update OK but was a problem choosing the utility. WELL DONE & MANY THANKS Jim"
Geekman
  • 32281 Answers
SOURCE: toshiba satellite c660 motherboard not power
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Posted on Sep 05, 2012
gauravkumar6
  • 560 Answers
SOURCE: how do i restore to
First restart your Toshiba laptop. Press either "F1," "0," or "F8" to be taken to your computer's hard drive utility screen. The key command differs depending on the model Toshiba computer that you own.
Select "Restore Original Factory Image" from the list of options in System Recovery. Verify that you want to continue the process by clicking "Yes," then click "Next".
Restart the Toshiba laptop once the factory restore process has been completed. You will be prompted to enter information such as the date, time and language preferences.
Feel free get the reliable technical help at http://www.vtechsquad.com/toshiba-support/ for troubleshoot all kind of Toshiba PC(laptop and desktop).
Posted on Sep 20, 2012
I have a toshiba satellite c660 and i want to restore it to factory settings and i want to know if i will loose some drivers
If you restore it to factory settings all the drivers will be set as well. Like the day it came out of the box. All updates must be reinstalled.
Nov 28, 2012 | Toshiba satellite c660
Need manual for c660 laptop
Toshiba Satellite C660 User Guide
Download Here
Mar 18, 2012 | Toshiba satellite c660
I want c660 sound driver toshiba plese quick
Please click the respective link to download the sound driver for your Toshiba Satellite C660:
Drivers for Windows XP OS
Drivers for Windows 7 OS
Sep 19, 2011 | Computers & Internet
Here is the link.
Jun 30, 2011 | Toshiba Satellite Laptop with Intel...
Toshiba satellite c660-1el drivers download for windows 7
Check out this link @ http://za.computers.toshiba-europe.com/innovation/download_drivers_bios.jsp?service=ZA
Make your selections for your download as below from the link above:-
Product type : Notebook
Family
: Satellite
Product series
: Satellite C Series
Model: Satellite
: C660
Short Model No
: PSC0SE
Operating system
Driver type
: All
Country
Language
: English
Hope it helps.
May 27, 2011 | Computers & Internet
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Nov 22, 2007 | Toshiba Satellite A135 Notebook
Toshiba Satellite U205 Notebook Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
