Need drivers for motherboard/chipset
I'm trying to locate the drivers for the motherboard of a Toshiba A105-S4547. Had to replace the hard drive, now cant connect to internet, get "failed to query TCP/ICP settings of connection" error. I'm missing alot of drivers.
  • 4 more comments
  • k_s_pfield Apr 23, 2009
    I installed WinXP Pro
    Fritzelly- thanks, I'm actually at this site now, but the problem is, I had to install Win XP Pro as I did not have the Vista Cd. Do you think these drivers would work with WinXP?
    Thanks so much for all your help everyone. I will try contacting them. I would much rather figure it out on my own, but it appears I will have to give up LOL
    thanks again!
    Ahh you're out of look for xp drivers, seems to be only Vista
    As for your problem
    Search for tcpip.sys and rename all files found to tcpip.sys_old
    XP should then try and repair them and see if that works
    So I found the one tcpip file. Do you think this will work if I rename even though I replaced the hard drive? This is not even my laptop, it's my daughter's friend who got a virus and I had no choice but to replace. I'm missing alot of drivers according to my device manager.
  • Christian Cabalfin
    Christian Cabalfin May 11, 2010
    What windows do you use?
  • 123 Answers
  • 1 more comment
  • Fritzelly Apr 23, 2009
    Theres dropdowns there at the top of the list to select your OS
    As for your problem
    It should fix the error you described, then onto the next one....
  • 28 Answers
Here is a link to toshiba's drivers for your computer: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1702313&rpn=PSAANU&modelFilter=A105-S4547&selCategory=3&selFamily=1073768663&=1702313
select the operating system you are using from the drop-down menu to make sure you are getting the right ones
Posted on Apr 23, 2009
How to restore original windows on a toshiba satellite a105-s4184
I have toshiba laptop satalite with 2 operation windows 2000 and HP windows running thus slowing the system down consiradably. Idealy would like to delete the windows 2000 professinal. Please help
Sep 26, 2011 | Computers & Internet
I have a toshiba satellite a-105-s2091 and i got the black death screen problem. I have tried to restart and reboot with the f8, the f12 and nothing seems to work... what else can I try please help!!!
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
May 01, 2011 | Toshiba Satellite A105-S2031 A105-S2091...
I have a Toshiba Satellite A105-S101 it was working well then it was left idle for one month then when i tried to update the screen went Blank/black screen, switch is on, no bios set up, no avg out,...
Dead PC
Possibly a RAM issue or errors on the hard drive stopping the display driver from working properly. Remove power sources, remove RAM and hard drive. See if you get a display when the power adapter is reconnected. If you do, remove power source and fit RAM, (if not motherboard may be faulty). Repeat and if still working, remove power, fit Hard Drive and boot again.
Assuming your OS is Windows Based;
Reboot and use safe mode run CHKDSK/F and when finished check the drivers.
Hope that helps.
Feb 04, 2011 | Toshiba Satellite A105 Notebook
System time clock looses time
hello
here is a guide to disassemble the laptop
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
Some motherboards have the battery soldered on ,i am not sure if yours is or not ,the batteries usually look like watch batteries.
you could always get a quote from an authorised toshiba support agent if you are uncomfortable opening the laptop.
The information on the hard drive will not be lost as it is saved on the hard drive itself.
May 11, 2009 | Toshiba Satellite A105 Notebook
Got a new hard drive installed and now there's no sound.
first you need to check your device manager to
see if you have any devices with a "!"
if not when your step dad took it apart
he might have not reconnected the internal speakers.
If you have some headphones handy connect them and see if they produce sound .
Here is a link to various drivers for your laptop
Mar 27, 2009 | Toshiba Satellite A105 Notebook
Black screen problem
you did not discuss how old, check the battery indicator bar,also check the video driver to insure you have a current version. Look in Control/Video.
Jun 28, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105 - S4547, screen goes black when using the battery (not plugged in)
check your control panel/video to ensure device driver is current. use driverguide.net.since when on battery no pic suggests that the battery life span is shortened. Recharge and check how long the battery level lasts when doing normal internet or document reviews. Video playing drains the battery at a high rate, when battery is already low, virtual memory tries to assist.
Toshiba Satellite P25-S5263 Bios reset
remove the cmos battery from the motherboard for 30 seconds.It works i just did it on the a105-s4547 model
Nov 22, 2007 | Toshiba Satellite P25-S5263 Notebook
Computers & Internet Logo
127 people viewed this question
David Payne
David Payne
