Question about Emerson 32in Class LED-LCD 720p 60Hz LED LCD HDTV - Refurbished
Can not find a headphone plug on my emerson lc401em3f
Television won't work
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Aug 16, 2016 | Emerson Televison & Video
Can two of these be plugged into an Emerson TV at once?
Most TVs don't have one headphone jack, and definitely not two. The best solution to your problem is to buy a headphone splitter. You can put the splitter into the one jack and then connect two sets of headphones to it.
Feb 16, 2014 | PyleHome PHPW2 FM Hi-fi Wireless...
I need the remote code for emerson lc401em3f
I have the same TV using a Philips universal remote control you need to be directly in front of the power light on the TV and 3 ft or closer to program the right code to work. The company uses funai codes mine worked with code 0520
Nov 26, 2012 | Emerson LC320EM9 32 in. LCD HDTV
Tv wall mount screw size for a emerson LC401EM3F
The instructions say that it calls for M8 x 1.575" (40mm) screws.
Nov 23, 2012 | Emerson Televison & Video
Intenal speaker doesn't turn off when headphones are plugged in
try pushing your head phones in all the way. i didnt think you had to push so hard but apparently you do:/ hope i was helpful:)
Aug 26, 2009 | Emerson Audio Players & Recorders
Can't I use it at work with headphone?
some radios did not come with headphone.
you should see a plug with a picture of headphone to plug in if not take back and get another one that has a headphone jack.
May 14, 2008 | Emerson PD6810 CD Boombox
Emerson 32in Class LED-LCD 720p 60Hz LED LCD HDTV - Refurbished Logo
35 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
