Question about KitchenAid KBRS19KTMS Bottom Freezer Refrigerator
Ice keeps building up at the bottom of the bottom freezer compartment. Where is the drain located on a Kitchenaid kbrs19ktms? Thanks
  • 306 Answers
SOURCE: ice build up under rolling tray in freezer
Yes you are right there is a drain tube in the middle of the coils. You need to remove the back panel and you will see the coils of the evaporator (freezer) and right underneath you will see drain tube. Now more then likely it is plugged with ice so take some regular table salt and two or three teaspoons on the top of the tube opening will break it loose and start draining. Take some regular tap water and pour down just to flush the tube and inspect the bottom collection pan under the fridge and see how much water is coming out. Be sure to have unit turned off when you do this cause the fan will run inside the freezer compartment other wise. Hope this helps you. ken
Posted on Jan 11, 2009
sodeep
  • 3267 Answers
SOURCE: freezer is not cold and ice is building up on the bottom back
Since this model is frost free and u are finding ice in the bottom back the problem may be due to either or both of these:
  • Low refrigerant coolant gas(freon/CF4)
  • The fan & heater *** blower assembly could have malfunctioned. To check put ur hand near the outlet of the bower outlet to feel if the fan is operational.
This may be the first things to check and post ur reply as comment for us to help find the exact problem..........................sodeep
Posted on Jun 02, 2009
woodchuck789
  • 4059 Answers
SOURCE: water leaking/freezing in bottom of freezer
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help
Posted on Jul 12, 2009
  • 1218 Answers
SOURCE: Freezer repeatedly accumulates ice on the bottom.
Good day,
Although you covered it, it is important that the drain be cleaned and flushed properly. Using only hot water, pour enough into the pan and wait for five minutes or so.
Remove water with a basting tool, and repeat as often as necessary until open.
Never use a heat gun or hair dryer since it can melt the plastic behind the metal pan, and create additional problems.
When done, water should flow freely(not slowly) to the drain pan underneath. If in question the line needs blown out. Service techs use compressed air tanks with a hose or nitrogen tanks with a hose to complete the cleaning process.
If your handicapped in this area, a weak solution of bleach and extremely hot water is a second option.
Kitchenaid is a product of Whirlpool. The metal pan below the coil can build ice up underneath it where it cannot be seen.
Thus, when going thru a defrost cycle, the water drips as it should onto the pan, but the pan remains too cold and refreezes the water.
Solution.
Unplug the machine, and with a floor fan dry out the freezer compartment for 6 to 8 hours. I know. Ugly time.
Note: One other item that can cause this problem, is the feed tube to the ice maker leaking when filling. It runs down the back wall and causes this situation.
To test, shut off the water supply to the machine for an extended period, but that does not mean to skip any of the steps above.
Very irritating problem, with patience being your most useful tool.
Jack.
Posted on Dec 11, 2009
mrbobfixit
  • 259 Answers
SOURCE: I have what appears to be a water leak of some
Check to be sure your ICE door chute is closed or closing properly! I have encountered many of these units that have had the flap break off the mounting tabs inside the dispenser opening. If the flap appears to be intact, I would next guess that your ice maker timing is allowing the ice maker to over fill and spill water into the ice bucket.
You can confirm this problem by looking at the ice maker and seeing if the ice cubes in it are filled right up to the center bar that drives the cubes out of the mold.
Let me know if you have any more questions!
Thanks, BOB
Posted on Aug 18, 2010
The freezer section of my refrig has a LOT of "snow". Any fix?
KitchenAid KBRS19KTMS Owner Manual
see page 16, moisture buildup
consider:
draw not closing tightly enough or not closing all the way
bad gasket allowing moist air into freezer compartment
defective defrost cycle
Aug 14, 2015 | KitchenAid Kitchen Aid - KBRS19KTMS...
Discovered ice build up on bottom of freezer in side by side KitchenAid Superba. Figure it is a defrost drain clog.... How do clear the clog?
I have ice in the bottom of my freezer section also in an older one of these, but I have traced it down to some sort of leak in my ice maker line. It only occurs when the ice maker is making ice, and not when the ice tray is full. Mine also leaks through the front door seal and into the floor if I don't keep scraping out the ice from the bottom (to clear out the "reservoir" that holds the water till it turns to ice).
I came on this site looking for a way to locate the leak and get to it. You might try scraping out the ice and turning off the ice maker for a while and see if the ice no longer forms at the bottom. Then at least you have localized it a little!
Feb 09, 2011 | KitchenAid Superba KSRG25FK Side by Side...
We have a Kenmore Elite side by side refrigerator, model no. 53209, purchased in 2003. Recently the drain hole/hose to the drip pan beneath the freezer compartment has been freezing up, apparently during...
Good day,
It's become a common problem on newer machines with less frequent defrost cycles and for a shorter period of time.
The following clip, as you scroll down will see the most exotic procedure. You may not have to go that far.
Using a length of #14 bare copper wire, and wrapping it around the heater and inserting it into the drain hole will usually work. You will need to remove the heater to perform this process properly, and I prefer to wrap the copper close together, each wrap touching the last one. Your call.
kitchenaid-top-mount-refrigerators/" spwrap?>kitchenaid-top-mount-refrigerators/">http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
Your machine is a product of Whirlpool which makes many brands, all of them with the same basic system.
Oct 19, 2010 | Kenmore Refrigerators
My freezer compartment is full of ice and frost on kitchenaid ktra22emss
if a no frost frig is frosted then the defrost system has failed . look at the heater / and defrost terminator . and the aditive defrost control as any one of these will cause the problem. . on some models the drain in the freezer is pluged and needs cleaning . this will cause ice build up on bottom of freezer .. ( clean drain with hot water & turkey baster ....hope this helps mm
Oct 09, 2010 | KitchenAid KTRA22EMSS Top Freezer...
Drain keeps freezing
The problem may be the freezer drain heater has failed, locate the drain inside of the freezer compartment and check to see if it is warm, if not you may need to replace the heater.
Jun 30, 2010 | Woods Upright Freezer MU07W
ICE BUILD UP ON THE BOTTOM OF MY FREEZER BELOW THE LAST TRAY
clear ice and with hot water pour into the drain hole till open and drains ,, take back panel of freezer out and wrap a piece of thick cooper wire around the heater and drop into the drain hold about 1in and it will keep drain open / thanks
Jan 14, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Ice build up under rolling tray in freezer
Jan 11, 2009 | KitchenAid KTRS22EM Top Freezer...
Ice build up on bottom of freezer
remove back panel inside freezer. you will see drain tray at bottom with a drain hole in the middle - this is blocked usually with ice. melt off with a hairdryer and follow up with hot water till water flows away freely
Sep 25, 2008 | Maytag MSD2732GR Side by Side Refrigerator
Ice build-up in freezer - Kenmore Model C978-66795-2
don't know this appliance but for guidence:
some appliances have the evaporator in a compartment at the top of the freezer and the drain comes out of the back and runs externally to the drip tray. there should be a grill in the compartment so just peer into it and see if there is ice build up.
wherabouts is the freezer ice forming?
Sep 04, 2008 | Refrigerators
Drain plugged in freezer
First of all, is it ice or frost? If it is ice, I would say you have a leaky water valve to icemaker, running down evap. coils. Replace water valve. If you have frost-find out why it is not defrosting(defrost heater, defrost thermostat, or defrost timer.
Jan 17, 2008 | Refrigerators
KitchenAid KBRS19KTMS Bottom Freezer Refrigerator Logo
87 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
