Dvd will not record using guide or timer.''unit must be in stop mode'' is mentioned in instructions several times but is not explained anywhere.
4 Suggested Answers
SOURCE: Magnovox MWR20V6 will not begin recording when it should.
This is more a work-around than a solution, as the unit is failing to function normally; however, having the identical problem I observed that the unit is failing to power on at 2:00 minutes before beginning recording, a necessary step to record to DVD.
My work-around is the following:
1) Set up the timer, inputting necessary date, time, etc. as normal. With the unit still powered on, start the timed recording mode by pressing timer set, as normal. You will see the red clock icon and the DVD logo iluminate on the VFD.
2) Press the Standby-On power button. This will power the unit on in VCR mode. You should at this time be unable to switch from VCR to DVD mode since the DVD is still in timer mode. LEAVE THE UNIT POWERED ON in this manner. The timer will function and the DVD will record normally.
I have no clue why my unit suddenly forgot how to power up on its own in order to record to DVD. If anyone has an answer for that one please post!
Tom Gee
Posted on Dec 03, 2008
supertech6
  • 513 Answers
SOURCE: Is third time a charm. Again several years ago I
Here is the owner's manual for your DVD machine. This is a VHS recorder but not a DVD recorder. To record VHS tapes to DVDs, you will need a DVD recorder.
You will plug the yellow video out connector on the VHS to the yellow 'Video in' connector on the DVD Recorder. Do the same for the red and white audio connections, out on the VHS, IN on the DVD Recorder. Connect your TV to the DVD recorder so you can see the picture you are recording.
Posted on Mar 31, 2010
Testimonial: "Thank you for you help, I thought we bought a recorder both ways but aparently we didn't. If we can get the manual I will be eternally grateful. "
  • 1156 Answers
SOURCE: Toshiba dr7 DVD recorder. Using timer recording
Hi, thanks for posting your Question.. This problem might be can be due to a writing error problem on bad media. What's more, this error is 'non-critical', and can easily be cleared in most cases by the user.
Press 'DISPLAY' button (should be on remote); this should clear it. Also check to make sure the recordable DVD media is 4x - 8x write speed. Recommended media brand: Verbatim DVD-R/RW if you can get it, or Kodak will work.
Discard any discs you previously used in this machine which may have triggered the error.
Or you can try the below step.
Unplug the unit from the wall AC outlet for two hours to reset .. If it doesn't reset, Turn on unit, select Hold channel up and play buttons on front of the unit for 5 seconds..Unit should reinitialize and work better..
Good luck to you..
Posted on Jul 13, 2011
DVD side wont respond
I had this problem as well after recording a DVD. player might be in timer mode. press SET TIMER buttom to cancel timer function, press DVD to use player.
Jan 04, 2013 | Toshiba DVR620 DVD Recorder/VCR
Just purchased a Magnavox dvd recorder MWR10D6 and hooked it up. The power light comes on but it won't let me use setup or timer
Try disconnecting from power and connecting back, if it does not fix it bring it back, it is faulty.
Apr 08, 2008 | Televison & Video
Is there a way to record something on a dvd from the tv?
Which model do you have? Some of the GoVideo DVD/VCR units are only DVD players so you can only record to the VHS tape. If you have a DVD writer version, you may find it tedious but doable. First load the blank DVD and set the Disc Record mode (you will see an on-screen prompt) for VR (this lets you do more editing of the video) or Video (this choice is compatible with more players). Then set the REC Mode by pressing that button repeatedly (SP (2 hours per disc), LP or XP(1 hour per disc). For one-touch recording (recording the current program that you are receiving on the device), select your Channel and Audio track then press REC. If you press REC several times, you will set when the recording stops. Otherwise it will not end until you press STOP.
For timed recording, press Timer Record. Then go through all the items to set the DVD recording information. Record mode, Channel, start and stop times. The left and right arrows let you change menu sections and the up down scroll through the settings. Press Enter to save the programmed recording. Then press Return. Make sure blank media (or with enough room for the programmed item) is in the machine. On some units, you will need to turn off the machine for the Timed Recording to work.
For recording from external sources, press Input instead of Channel.
For any recording, leave a bit of extra space on the disc to Finalize the DVD if you will want to play the disc on other players.
I hope this helps.
Aug 15, 2010 | GoVideo Go Video DVD/VCR Combo
Using a Sylvania DVR90VF, how can I record from a VHS tape to a DVD?
OK here's what the user manual has to say on it!
PS If you need the user manual I will E-Mail on request.
Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
Note for recording to a disc:
• Make sure that the disc is recordable.
Hit [SETUP].
Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
proceed to step 3.
Using [
K / L], select “Advanced Setting Menu”.
Hit [ENTER].
Using [
K / L], select “Recording”. Hit [ENTER].
Recording menu will appear.
Using [
K / L], select “Dubbing Mode”. Hit
[ENTER].
Option window will appear.
Recording
Auto Chapter 10 minutes
Timer Programming
DVD-RW Recording Format Video mode
Auto Finalize
Dubbing Mode VCR DVD
VCR DVD
Recording
Timer Programming
Auto Finalize
DVD
VCR
DVD-RW DVD-R
VR
DVD-RW
Video
Note
For VCR to DVD duplication:
• After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction.
5
Using [
K / L], select “VCR DVD”. Hit [ENTER].
6
Hit [SETUP] to exit.
Make sure to select a recording speed using [REC SPEED].
7
Hit [PLAY
B].Then hit [PAUSE F] at the point you
wish to start recording.
• Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
when selecting the starting point.
8
Hit [DUBBING].
VCR to DVD duplication will start.
9
Hit [STOP
C] to stop the
recording.
When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically.
• Dubbing Mode is available only if the videotape or disc is not copy protected.
• You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
• The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
May 12, 2010 | Televison & Video
Mar 31, 2010 | Televison & Video
I'm thinking of buying this VCR/DVR combo - Toshiba DVR670 -- but first I want to know if you can program the VCR recording timer using time span information -- not just those codes for programs you find...
Usually, depending on the source, or channel, timer recording can be performed on a VCR; even this model.
The short answer is YES - you can record cable times or set manual scheduled recordings on this VCR. It depends on the channel(s) available in your area, and/or the source (such as cable receivers/set top boxes, etc.) which are intended to be recorded.
Feb 09, 2010 | Toshiba DVR670 Player
Need manual for Funai SV2000 Model#WV20V6
Visit www.funai-corp.com and under manual type your model to download pdf.
Jan 06, 2009 | Funai TruTech DVDVCR Dual Recorder
Tom Gee
May 03, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Recording from guide plus
Recording from the guide requires that the unit be off to receive guide info regularly and copy it to the HD. If your reception is poor or your DVD on time is too great, the guide will not have any info, and the recording be nameless, except for channel and time info. You can force the EPG mode by removing the power plug from the back of the unit, but only do this after you have turned the unit off! While copying the guide to the HD, the display shows EPG while th unit is off, and you will hear the HD cycling.
Jul 19, 2007 | Pioneer DVR-530H-S DVD Player/HDD Recorder
Dvd recorder won't record on DVD-RW disc.
CLEANING THE DISC LENS ? If this unit still does not perform properly although you refer to the relevant sections and to ?TROUBLESHOOTING GUIDE? in this Owner?s Manual, the laser optical pickup unit may be dirty. Consult your dealer or an Authorized Service Center for inspection and cleaning of the laser optical pickup unit. FROM EWR20V5 OWNERS MANUAL FUNAI-CORP.COM
Dec 16, 2006 | Emerson REWR10D4
Televison & Video Logo
71 people viewed this question
Top Televison & Video Experts
