Question about Panasonic TOUGHBOOK CF-18 Tablet PC
HOW TO INSTALL MEMORY ON TOUGHBOOK 18
I FOUND WHERE U INSTALL THE MEMORY BUT CANT GET THE MEMEORY IN TO INSTALL IT... DO U HAVE TO TAKE THE HOLE BOTTOM COVER OFF TO INSTALL?
  • jayjec Apr 23, 2009
    MODEL CF-18JHU80TW
  • 6 Answers
On the Panasonic CF-18 the memory module is under the speaker assembly. You have to remove all six screws, unplug the speaker from the main board then remove the chrome plate to access the memory.
Posted on Mar 23, 2010
  • Panasonic Master
  • 3,866 Answers
Unfortunitly yes yo hvae to like dysect the thing just a little but this type of upgrade should be done by someone experienced to advoid damage to the unit.
Posted on Apr 23, 2009
  • 28 Answers
You need to be able to access the socket, if you cannot access that yet then yes, you have to remove another layer.  Everything i can find online about the toughbook is that there is only one slot available, which would mean you have to remove the old memory to put your new memory in but if you can give me your model number it might not be the case.
I need to the Panasonic cf-18 drivers for a sounds, video and gps and touch screen os
Go there :
http://pc-dl.panasonic.co.jp/itn/drivers/d_menu_en.html
or there :
http://www.panasonic.com/business/toughbook/computer-support-search-downloads.asp
Choose your model, OS, language.
Select Category=All Drivers.
From the list, download and (re-)install the driver and utility related to your device.
Don't forget to comply with the Install Instruction (beginning of the list) :
it indicates the correct drivers installation order.
Jul 13, 2011 | Panasonic TOUGHBOOK CF-18 Tablet PC
How do you install the memory stick on a toughbook 18
It's under the speaker. Pull the speaker off and you will see it.
May 19, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
Panasonic TOUGHBOOK CF-18 Took out HD to reload windows as it would not load but stuck at the safe / last known good config etc. Loaded XP onto HD via an ACER laptop and reinserted it into ToughBook -...
I think your actually having issues getting it to run on the toughbook because it uses different drivers for everything from the Acer computer. If you press F8 while booting up you can choose the option "Disable automatic restart (of system errors or something)". Then when the machine boots up you should get a blue screen giving you an error code like "IRQ_EQUAL_TO_OR_GREATER_X Error: 0x0000005f. You could try to see what the message is trying to tell you to resolve it but the error msg would likely point to the driver that its trying to load that's most likely different from the toughbook you have. I'd suggest getting an external cdrom/dvdrom and install windows from a disc onto the toughbooks hd while its in that toughbook machine.
Dec 21, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Can I install windows 7 on a panasonic toughbook cf-18 tablet
I don't thank they have it out for tablet yet. Wait a bit and they should.
Nov 11, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Where can I download a Toughbook CF-18 Tablet PC Recovery Disk, mine disappeared. rc
Finding a complete recovery disc is prooving difficult. i have found a couple of alternatives to getting a complete install on disc, but they do take a little bit more time.
if you have a copy of the windows which you wish to run your system on. which nowadays arent hard to comeby, then you can use this link as a driver and compac software restore disk
http://www.user-guides.co.uk/cddownload/Panasonic/PanasonicToughbook/Panasonic-Toughbook-CF-18-XP-Driver-CD-Recovery-Restore-Disk-108878.html
however these downloads / cd'a have to be purchased. i really wouldnt bother with it. drivers and apps for compac arent a must have and usually just do things to make the GUI fancey or easy to use. most drivers will be picked up on windows install and the rest wont be hard to track down. a standard windows install is surfice for most things and runs quicker than an install full of tosh little programs.
Aug 14, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
HOW TO INSTALL WINDONS XP PRO ON TOUGHBOOK CF-18
XP can not be installed from usb as the bios does not enable it. Plug the ide hard drive into an older desktop system and install from boot on cd. Once all files are copied over then you need to copy the i386 folder over from the cd. Reinstall the hard drive into the toughbook and carry on the install from there.
Jun 09, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Need a memory module for toughbook cf-18bhazxft
You can go to a website like kingston.com; crucial.com; tigerdirect.com; newegg.com & use their memory finders to find out what type of RAM your computer uses & what they have available for purchase. Hope this helps & please rate this solution as fixya. Thanks.
Feb 03, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Trouble booting!
You could attempt to boot to safe mode, and run the Start> System Recovery > PC Recovery Application.
Otherwise, I'd boot to safe mode, select start, run, type: msconfig, select the startup tab, remove any unwanted startup items that may be causing the system crash.
Hope this helps.
Jan 08, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Panasonic CF-18 screens
Maybe you should try re-installing the drivers.
Here's a link
Jun 16, 2008 | Panasonic TOUGHBOOK CF-18 Tablet PC
Panasonic TOUGHBOOK CF-18 Tablet PC Logo
5,103 people viewed this question
Top Panasonic Tablets & eReaders Experts
Paul Wang
Are you a Panasonic Tablet and eReader Expert? Answer questions, earn points and help others
