Question about LG 24 in. LDF 7811 Stainless Steel Built-in Dishwasher
Dishwasher LG mod, LD - 2031SH guaranty expired
I live in Chile, I have a LG dishwasher, which was working fine until started to stop with error code E1,and dripping water from under, we looked on the back, checked the hose, nothing... called the service and they told us to change the engine which we think is working just fine... (here service is not very professional) we do not know what to do, how can we access the back of the machine, my husband had done many repair around the house, and I am sure if it is not something extremely complicate he could do it. Could you help? Mara Orsi
  • 4 Answers
You have to pull the dishwasher out from the opening to access the pump.sounds like a possible seal in the pump,leaking supply line, or where the water drain is at the pump.the problem with lg is you only can get parts from would pull out the dishwasher and while it's out,try to run it to isolate the leak.good luck
Posted on Sep 26, 2007
I need an LG DISHWASHER LD-14AWZ schematic diagram
For a wiring diagram, contact LG directly.
Dec 19, 2017 | Dishwashers
LG dishwasher LD-2120WHU I get the
This happens to my LG dishwasher every 6 months or so. It also makes a groaning sound as if the system is starved for water. The resolve the problem by removing the dishwasher and laying it over on it's right side. I then remove the two plastic assemblies that are on the left side and I remove them from the dishwasher (you will need a vice grips to remove the hose clamps from behind them, you will also need to remove the round circular water intake plastic disk that is on the inside of your dishwasher on the left hand side right in the middle of the left wall) and clean them. Once the water can run freely through these plastic parts you will get a good water flow and you should be fine. Until you have time to do this I recommend putting a few quarts of hot water into your dishwasher once you start to hear the groaning problem. This solution should be very easy for anyone who is comfortable doing their own oil change. Oh, and turn off the power supply first.
May 26, 2010 | Dishwashers
I have the same problem !!!
I have the same thing happening to my dishwasher what do I do
Aug 18, 2009 | LG 24 in. LD-12BW5 Free-standing...
Error OE
thats a drain problem , blocked drain hose , drain pump stuck or burned , last case scenario electronic control
Jun 18, 2009 | LG 24 in. LD-12BW5 Free-standing...
Error Code OE
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
Good Luck!!!
May 02, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
I have a lg dishwasher ld-14aw1over flow
On an LG LD-14AW1, three is a float sensor on the left hand side of the dishwasher, behing the water outlet port.
It is the sensor that tells the dishwasher to stop filling just before the wash or rinse cycle begins.
A service call is needed or post back here is you want help replacing it.
Apr 09, 2009 | LG 24 in. LD-12BW5 Free-standing...
Stopped Working Mid-Cycle
blockage in outlet pipe
Lg durban
Jan 29, 2009 | LG 24 in. LD-12BW5 Free-standing...
OE fault in Dishwasher model LD-14AT2
suggest you take the drain pump motor out and inspect. either a blockage or its defective.
Jun 15, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
E1 Error Message
agreed all LG d/w with E1 is the wash motor faulty.
take care.
Jan 12, 2007 | LG 24 in. LD-12BW5 Free-standing...
LG 24 in. LDF 7811 Stainless Steel Built-in Dishwasher Logo
121 people viewed this question
Top LG Dishwashers Experts
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
