Question about Mtd Garden
How do I check an ignition switch (691641) to see if it is bad
It's a 6 pin switch for a garden tractor and there appears to be a burn line from the unmarked contact to the contact stamped G. Other contacts are marked S, M, B, G, L , and this group goes to wiring harness. Unmarked contact has lone red wire to it. Mower blows 20A fuse when starting if mower has to crank for more then 10 seconds. Fuse also blows when I turn the mower off with the key. I have a new starter and have not been able to locate a bare wire yet.
  • Samuel Charles Spriggs May 11, 2010
    The unmarked contact is the hot wire (+), the G contact is the ground (-). There is probably a short which is causing the burn mark. The switch is not causing the fuse to blow. The switch is probably okay, because the fuse is blowing before the switch gets damaged.
    If the mower starts within the 10 seconds, and then runs okay, the problem could be in the starter solenoid/relay -- it could have a (resistive) short which is pulling too much current.
    However, this would not account for the fuse blowing when the mower is turned off. So, we need more info. What does the fuse connect to?
    Loyalty:
    Visited the website for 30 consecutive days.
  • Mtd Master
  • 1,195 Answers
IF YOU TAKE THE STARTER SWITCH OFF AND TURN IT OVER IT IS MARKED + POSITAVE _ NEGITAVE AND SO ON
Posted on Sep 08, 2017
SOURCE: Repair Parts Manual / Book Service Garden Tractor
C I am thanking a lot for dealing with my matter and very much I am counting for your help in getting the list of the spare parts with catalogue numbers of my model of the garden small tractor.
I am greeting Ted
Posted on Nov 25, 2008
KMusselmann
  • 247 Answers
SOURCE: BLOWING FUSES
Ist of all is 10 amp the proper size?
2nd if you bypass and whatever you are replacing the fuse with, is it warm, or hot to the touch?
If it is you have a direct short in you have a direct short in the electrical system. Check for bare wires,wires touching the motor or chassis that don't have a connector.
Hope this is a FixYa
Kurt
Posted on Mar 20, 2009
  • 106 Answers
SOURCE: My riding mower blows fuses once you turn the key.
Sounds like you are on the right path, maybe some wires on the ignition were replaced backward, and you are sending +12v directly to ground? Does it blow right away?
Posted on Jun 04, 2009
mickey813
  • 472 Answers
SOURCE: My mower keeps blowing the 20 amp fuse that is on
ck the wires going to yhe head lites theay could be frad and shorting out
Posted on Oct 01, 2009
mickey813
  • 472 Answers
SOURCE: 24 hp. garden tractor goes in reverse but not forward
SOUNDS LIKE ITS TIME FOR A NEW TRNS AXEL
Posted on Oct 30, 2009
4530 mahindra ignition wont start tractor, but will start by jumping seilenoid to starter
Well it could be several things a safety switch for the seat, mower deck etc not in the proper position. Blown fuse,bad ignition switch, burned out solenoid. if you jump the battery side of the solenoid to the small terminal and nothing happens, it's the solenoid. If it turns over check the other items. Start with the fuse that powers the ignition switch.
Jul 28, 2016 | Garden
5525 john deere tractor keeps buring ignition switch
First you will have to check for a short , next i would check the ballast resistor. if the points also burn chance this is a problem.
If you have the wiring diagram check to make sure every thing is wired correctly Good Luck
Dec 08, 2015 | John Deere Garden
Engine will turn over but won't start checked carburator and fuel filter and they are ok are there any saftey switches that would prevent engine from starting?
Since engine is turning over by using the ignition switch it should not be a safety switch problem,
Sounds to me you might have a spark / coil problem
If you have spark then fuel shutoff selonoid on bottom of carb bowl might be bad and not opening.
which in that case I unplug from harness and unscrew from carb bowl , pull out center pin if connected cut off if not throw it in the trash when I do this I always put a shut off valve in the gas line.
You will need a very thin open end wrench to unscrew selonoid from bittom of carb.
Apr 04, 2015 | Ariens 42" 19HP Lawn Tractor
Why won't my raining lawn mower not start?
Check oil level, take off the spark plug clean it and regap and or buy new one and regap. Take carburator off and clean it. Test coil and ignition switch. Clean gas tank and fuel lines. There could be a lot of other things to check. It could be a safety switch, dirty cables,bad battery or bad wiring. It could just be a loose wire that's not grounded.
Sep 04, 2014 | Murray Garden
Toro groundmaster 325d wont turn off and belt keeps coming off
The won't shut off has to be a faulty ignition switch. The belts coming off indicate a problem the belt pulleys.The bearings may be bad and freezing up, this will cause the belt to smoke and tear up as well as make the pulley wobble . Does it smell like burning rubber ?? If not then you have a pulley out of line and or a pulley that's cracked or broken. Also check and make sure the deck pins are all in place and the locks are down on the quick release on front and side of deck. While the blades are disengaged turn all the blade hubs and pulleys to see if the turn fairly easy. Check for play or wobble in the pulleys and blade hubs(bearings and blade shaft, also known as the"spindle assembly") attach to these pulleys. Also check the idler pulley(also called the tensioner pulley for wear and check to see that they are in alignment with each other).
Apr 28, 2014 | Toro Garden
Rtz50 deck falls while mowing
are one of the rear pins poping out? Check and see if the bracket that the pin runs thru is bent causing pin to be out of line with the arm it pins in to. Saw same problem just the other day. Good Luck
Apr 04, 2013 | Cub Cadet Riding Lawn Garden Zero Turn...
YTH2448 Mower will turn over but will not start. Tried replacing fuel filter, checked fuel lines for blockage. Still will not start.
After trying to start the tractor remove the sparkplug and Check to see if there is any fuel on the sparkplug, if not then the problem is probably ignition related. This could mean a safety switch is not being connected, or the ignition coil is defective. To check if it is a safety switch locat the ground wire from the ignition modual on the engine and dissconnect it and then see if the engine starts be careful because at this point you will have to reconnect it to shut the engine down if it does start. If it starts then one of the safety switches is not making a connection, this could be the seat switch or the transmission neutral switch, or even the pto engagement switch, or there might be another I didnt mention, if it does not start then the problem is most likely the coil has gone bad and needs to be replaced. Hope This Helps Don
Dec 05, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I have a John Deere 317 tractor that does not start. The engine turns but does not fire. The plugs and points are good. I do not get a spark at the points or plug. What should I check next next.
We will be testing for voltage to the points, coil, engine to tractor wiring harness, ignition switch
Tools needed:
volt meter to read 12 volts, or test light
1) with the points open: is there voltage at the connection wire at the points
If yes; adjust points to .020" and try to crank engine and check for spark
*** you may want to determine if condensor is connected to this wire also
if no
2) check point side (neg or - ) of coil for voltage
if yes, engine should start
if no
3) check for voltage at the + side of coil
If yes, coil is bad
if no
4) check wire connector from engine to frame wiring harness
if yes; engine should start
if no
5) check wiring on the back of ignition switch
if no
6) check that ignition switch RED or BATTERY supply wire has voltage
if yes; switch is bad
if no
7) check supply wire and circuit breaker connected to the battery side of the solenoid
if no; circuit breaker could be at fault or wire connector at battery supply
Nov 08, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Have Exmark 52 LazerZ with Kohler ch25 engine. Engine stalled in heavy grass. Tried to re-start; engine turned over several times at lower RPM but stalled almost immediatly (PTO switch disengaged &...
try looking for a broken wire or a wireing harness shorted to ground, the fuse blowing in the harness will lead you to it if you are able to see where the wire goes. you have a short somewhere may be the fuel pump, too
Jul 16, 2009 | Ford Tractor 8n Front Emblem
Garden Logo
139 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
