Question about Philips 32PW6506 32" TV
Philips tv i,ve a philips tv picture is fine but the sound keeps going down try,d disconnecting the manuel volume buttons but stil the sound keeps going down
  • Anonymous Mar 16, 2014
    The sound on the tv keeps making a popping noice
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
It seems that there is a problem in your sound section. it seems that there is no proper supply to sound section or some capacitor might be faulty.
Posted on Oct 01, 2007
SOURCE:
Volume at max and won't go down
This sounds like a common problem on these TVs. Try a factory reset:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
3. A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
6. Run channel auto-scan to regain the picture.
Aug 12, 2012 | AOC L42H861 42 in. LCD TV
Volume keeps turning itself up philips lcd tv
this is due to surface mount capacitors going faulty on the side buttons panel. You can simply disconnect the cable from this board and use you remote to control the channels and volume. if you want it fixed you will have to replace the side button control panel which is a cheap part.
Jan 29, 2011 | Philips 37PF5521D 37 in. HD-Ready LCD...
Philips 32pf9986 has no sound after being moved from our house to parents house. Oddly the sound menu only has as a setting for headphone volume.
Tries tv unplug,replug it back about an hour later,by letting the tv resetting itself back to the factory setting.Now,tv is on goto tv memu to PICTURE go down reset to reset the entire tv Tuner signal board.Then goto SOUND Setting,go down to resetting.This process are resetting everythings.The tv sould have sound now.
Jan 03, 2011 | Philips 32PF9986 32 in. HDTV-Ready LCD...
Samsung TV - have sound/auto volume set to on. When TV is turned off and then on, tv volume is extremely low. Go back to sound menu, it shows "on" but if you go back and act like you are turning in on, the...
Hello Blindrid,
What I would suggest you do is Press your MENU button on the tv remote, Then down to SOUND and then Turn the AUTO VOLUME to OFF. Then come out of the menu screen.
Just to check that it has all work correctly. turn you volume upto a certain number for example 25
Then turn your TV off the turn it back on. Wait until it is displaying a picture then press the volume button Once either up or down and you should see that it will go to 24 or 26 depending on what button you pressed for the volume. This will keep your volume set to whatever you had it on before you turned the tv off.
Hope this Helps Please leave a thumbs up.
Cheers
Little Dish Fitter
Oct 06, 2009 | LG 37LG30 37 in. LCD HDTV
Tv sound wont work
Make sure that all scarts and sockets are plugged in tightly. Try different inputs, try connecting a DVD player or another piece of equipment to the sockets in turn. Also, if you`ve got a sky box, remove the scart plugs one at a time and reconnect it immediately so that you know where you took it from. Check if there`s a switch on the back for external speakers, Make sure it`s switched to internal. Some of the TV`s have the switch for internal and external speakers in the menu`s. Make sure that any switches whether mechanical or electronic are switched to internal. Ian
Jul 24, 2009 | Philips Televison & Video
Philips 20PF4121 LCD tv no picture but flashing error codes
I had exactly the same problem When the TV was switched on all I could see was a flashing green light. After cheching the TV internals and not seeing a problem including the power supply unit which looked and checked normal. Here is what I did to get M TV working again.
Disconnect it from the power supply. Hold down all the buttons simultaneously i.e. the on/off, the volume, the programme, menu buttons, all of them simultaneously and Plug it into the power supply again.
Lo and behold My TV jumped back into life after an absence of about 4 weeks.
Try it yourself exactly as above.
Best of luck.
Irishfreethinker
Jul 09, 2009 | Philips 20PF5120 20 in. EDTV-Ready LCD...
Computer does not recognize model sa5285/37 philips mp3 player
Make sure the hold/lock is not engaged
Try another USB port
Reset the player
If that fails:
Download the newest version of the Philips Device Manager:
www.usasupport.philips.com - change your country/language as needed
Enter in your exact model #
Click on the link for your exact model #
Click on the Software & Drivers section
Click on "Firmware Upgrade Software"
Install the new Device Manager
Open and run the "Repair" tab
If still nothing:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
If these methods fail, call Philips to see if you are still in-warranty.
-Tha Mp3 Doctor
Mar 22, 2009 | Philips Audio Players & Recorders
Power button changes channels and volume does not work
bad solder connections. front control panel.
Nov 23, 2008 | Philips 27PT543S 27" TV
Philips sa6045
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 25, 2008 | Philips GoGear Flash MP3 Player
The volume will not go up or down
make sure theres batterys in the controll.
try turning it up from the buttons on the tv.
else i dnt no
Feb 15, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips 32PW6506 32" TV Logo
178 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
