Unable to view DVD on TV
I am trying to connect a new Toshiba DVD Recorder/Player to my analog GE Television Model 20GT370 Made in Aug. 1991. Toshiba and I have been unable to get the Video Input or AV Input on screen so the Toshiba unit can be recognised, therefore I am unable to see the set up instructions on screen for the DVD unit.
  • emarr Apr 24, 2009
    Thank You, but we found that the "Input" was channel 91. Thank God we found it by His guidance.
  • 3,866 Answers
Here is a solution buy a coax to RGB converter they run from $20- $30 at radioshack this will shore up that problem as it will use channel 3 as the input of choice.
Posted on Apr 23, 2009
  • Grand Canyon Tech
    Grand Canyon Tech Apr 23, 2009
    Why would this not be a helpful solution it will work!?!?!
New DVR67)KU toshiba DVD video recorder/VCr recorder Problem: Cannot get on-screen display to set up new DVD machine. Both DVD and TV are Toshiba
unplug everything lets start over.....the TV is set on Ch 3..........and is working.... the new DVD machine should have red, white and yellow RCA cable.... connect these to the correct DVD outlets ........now connect it to the TV (digital IN)..... this is to view........ now to record using the F connecting cable plug this into the DVD (rear top right hand corner) this should be coming from your sat/cable out ........... now from the DVD F connector out .this goes to the TV...........note to record from another DVD player use the front jacks.........turn the power on and enjoy that movie(s)
Jan 27, 2011 | Toshiba Televison & Video
I'm having trouble hooking up Toshiba DVD, HD cable box and TV.
first is this DVD recorder? its not okay plug the wires from DVD to tv (left / right and video -digital in or av1 in) cable box is connected to tv (red/blue/green) tv should be on component (source)...to view dvd switch to av1 or digtal1.......if this is a recorder get a coaxial cable and connect from cable box out to DVD in (the TV setup stays the same as above) DVD set up should be on CATV/ch 3..........the out connection is the same as a reg player (see above)
Aug 28, 2010 | Toshiba Televison & Video
Can get analog stations recorded but not hi defination
Hi, unless the VCR/dvd recorder is hi def then you won't be able to.
Hdmi connection is hi-def, I think you can have a hi-def signal through composite, but it's your recorder thats the problem, it cannot read the number of line a hi-def signal has.
I have just found this.
http://www.brighthub.com/electronics/home-theater/articles/48499.aspx
I hope this helps.
Regards - Anthony
Feb 09, 2010 | Toshiba Televison & Video
Sony bravia-unable to tune in video channel via dvd
thethe wires have to run out of your cable box into the dvd recorder then back out to the tv,try rehooking it up
May 19, 2009 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
DIGITAL ANALOG CONNECTION
if the tv is showing the same worse quality without connecting any external device.then its the tv problem.and new tv is much advisable.
Nov 23, 2008 | Televison & Video
Ilo DVD player/recorder
> jfthr - Tv convertor boxes transfer digital signals into ANALOG. So when it goes to the dvd recorder it IS ANALOG. I have my antenna hooked to my convertor box, the converter hooked up to the ILO (A/V connections) then, the output on the ILO to the input of my analog tv. (Video selection on my tv). It works great to watch tv and/or record. I switch to the "DVD SOURCE" to watch dvds. Maybe you have the conv box hooked to the tv then the outs on the tv to the dvd. That would explain why you can get a picture but not watch dvd? The ILO has to go between the box and the tv in order to watch dvd.
Aug 07, 2008 | iLO DVD Recorder DVDR05
Toshiba RD-KX50 HDMI freezes the recorder.
Press the standby button for about 10 seconds and will reset the HDD you may lose what you have on the HDD but will fix it.
May 07, 2008 | Toshiba RD-KX50 DVD Recorder/HDD Recorder
Grundig TV - Tuning DVD & VCR
Hi there!
If the DVD recorder has an RF out then you should be able to tune it on UHF bandwidth. The cable should run from the RF Out on the recorder to RF on the TV. Switch the recorder on, put in a DVD and press play before tuning. Some DVD's require a disc before a Menu appears. Good Luck, Regards, JUS004
Mar 23, 2008 | Grundig GF70-600 TV
Hooking up a DVD player to a LCD TV
Typically, there is no video out from TV. You would have to connect the satellite receiver output to the DVD recorder input and connect the DVD recorder output to the TV. Word of warning - digital signals (DTV coax or HDMI) from the satellite receiver carry copyright info embedded, which may limit what it will allow you to put on a DVD. Typically anything can be recorded on the hard drive of the recorder, but programs from subscription channels may not go to a DVD.
Jul 08, 2017 | LG 42LB5D 42 in. LCD Television
Televison & Video Logo
181 people viewed this question
Top Televison & Video Experts
Electro Med Services...
