Question about Sony Playstation 3 (PS3) Console
PS3 HDMI problem
I have console connected to a sharp LCD37XD1E tv for 1080P. Every now and the about 5mins aprox, the picture and sound will go off for anywhere from a split second to 2 seconds during game play, xmb view or film playback, which is annoying. The hdmi cale has been changed (both support 1080P). The PS3 has been changed. The firmware & hdmi board in the tv have been updated but still the problem persists. Anyone else had similar probs. I think i`ll still going down the sharp route for now?
  • 488 Answers
I also had the same problem with my Samsung 1080P.its seems there is a "handshake"issue between the ps3 and the tv.restarting the system helped solve my problem.also insert the cables once again.
Posted on Sep 27, 2007
SOURCE:
When connecting ps3 to Hdmi tv via hdmi lead or av connection ,ps3 is powering up ok but error message appears on tv screen saying game mode not supported.
hello,,when you connect a hdmi you have to into the menu and select hdmi this should give you a 1080p picture mode
regards
shaun
Oct 08, 2010 | Sony Playstation 3 (PS3) Console
I have 2 ps3 consoles one new slim model other is older model both attached to 1080p 120hz tv's one sony one sharp aquos both using top of line $300 monster cable hdmi cables. The ps3 menu screen on both...
did you try going through the settings to configure yur tv with the game console so they could work together properly.also make sure your hdmi cables are good ones.and also try to reset the contrast,brightness etc of the tv.
Feb 21, 2010 | Sony Playstation 3 (PS3) Console
Can't run ps3 1080p to tv, but can to surround sound
dude im sure its ur TV cant be bith 1080i and 1080p not sure that works like that, sorry just stick to what the TV is
Oct 28, 2009 | Sony Playstation 3 (PS3) Console
Problem connecting my PS3 to my Sharp Aquos LC-C3237U LCD TV
Your PS3 set itself above the max resolution your LC-C3237U. Most likely the PS3 is doing 1080P, but the highest the Sharp can do is 1080i. So do this:
1. Connect PS3 to TV (you can use the current cable or analog cable)
2. Turn on TV and set input to port PS3 is on.
3. Make sure PS3 is connected via correct cable.
4. Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
I’m happy to assist further over the phone at https://www.6ya.com/expert/kevin_c38b47f462e94458
Sep 15, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
My sharp LC-19DV22U Will not connect to my PS3
well alex welcome to fixya technical support online.i just read your problems. there is an option to your problem you can use another cables with RCA inputs capable in your PS3 that can works on videos and also you can buy video converter. thanks!
Aug 14, 2009 | Sharp LC19DV22U 19 in. LCD Television
Playstation 3 Flickers when set to 1080P
It sucks to see ALLLLLLL these solutions, when I have the solution. Turn off DEEP COLOR in the video settings. It will immediately stop. If it doesn't, then you don't have the typical snow/flickering problem.
Oct 02, 2008 | Sony Playstation 3 (PS3) Console
Ps3 reset
turn the PS3 off. hold the power button for at least 5 seconds or until you hear another beep.
This should reset all your ps3's settings.  If you have an HDMI connection, wait for a couple of seconds so that the PS3 recognizes and negotiates the right video output for your TV.
Sep 07, 2008 | Sony Playstation 3 (PS3) Console
Major problems with PS3 and viewing Bluray movies
did you uncheek the other options when choseing 1080p or it might be your receiver because you have to set that to make the picture quality as much as the ps3
May 19, 2008 | Sony Playstation 3 (PS3) Console
PS3 not working thru HDMI cable
Same happened to my ps3 one week from new , took it back the the shop and got a refund.
Oct 06, 2007 | Sony Playstation 3 (PS3) Console
Hdmi to dvi
a DVI Connection does not transmit sound, so you will need a seperate audio cable. Have you changed the settings in the ps3 and your tv's input to HD signal or 720 DPI, do not choose 1080i or 1080P as DVI does not support those high settings.
Sep 05, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
232 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
