Question about Garden
Replace starter pull cord on Earthquake WE43 Edger
sleprocks
  • 147 Answers
SOURCE: starter rope pulled out and wont retract on
remove the starter cover and try to wind the starter rope manuly. the rope may have to be replaced if worn or broke..
Posted on Oct 22, 2009
  • 1206 Answers
SOURCE: I have this Toro trimmer/edger.Can't pull the starter cord
you must take apart the cord recoil and rewind the pull string,inspect string make sure its the same thickness through out if not replace it, not too hard i believe you can do it.
Posted on Apr 26, 2010
  • 5 Answers
SOURCE: pull cord broke on my craftsman gas push edger. I
It sounds like you did not properly rewind the spring that is behind the spool that the cord would around, that spring is what rewinds the cord after pulling the cord.
Posted on May 06, 2010
  • 11 Answers
SOURCE: HOW DO YOU REPLACE THE PULL CORD ON A 3.5 BRIGGS
you remove the bolts on the cover or w.e and take your new one and wind it around the wheel, there maybe a hole or w.e where the string attaches to ? Maybe a knot at the end .. that should work
Posted on Sep 23, 2010
richard_l419
  • 12 Answers
SOURCE: my edger tipped over briefly, now the starter cord is hard to pull and it won't start.
Try removing the spark plug and squirting some carb cleaner or starting fluid in the cylinder. Pull the starter cord several times for the piston to drive out the oil. Clean the plug and replace it. Try to start as normal. If you have starting fluid squirt a shot in the air cleaner to help make it easier to start the first time.
Posted on Jul 10, 2012
What do i do to put new pull cord in husqvarna Lawn edger
Remove pull starter off and wind on the new cord then wind up the spring tension so it recoils.
Aug 31, 2014 | Husqvarna Garden
Why does the fuel pour out of the air filter and floods the engine?
air breather pipe on side of engine blocked, or inlet valve stuck open,
Jun 04, 2014 | Ardisam Inc Earthquake Mini Cultivator
Pull cord stuck
remove starter assembly and check the spring and pulley.
Oct 23, 2012 | Ardisam Earthquake - 7055C - Gear-Dive...
My edger tipped over briefly, now the starter cord is hard to pull and it won't start.
Nov 25, 2011 | Mtd 25B-520D200 CA Gas Lawn Edger
My Poulan Pro 150E pull cord will not engage to start the weed eater. The rope comes out adn retracts back with no problem, but there is no pressure on the clutch to cause the motor to start. There is...
Sounds like the starter dogs are broken. They are little plastic teeth that engage to turn the engine when you pull the cord. You'll need to replace the whole starter assembly to fix this.
Aug 26, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
How to replace the pull cord on model featherlite 71188
how to remove and replace the starter pull cord on a palen100 , 16''
Jun 11, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Replace pull cord
Go to smalleng.com they have video on how to do what you need. Check it out awesome website! The cord you can buy at any local home center. or repair shop.
Jun 08, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
Apr 26, 2010 | Troy Bilt Tb70ss Gas Trimmer
How do I replace the pull rope on the TE 475 weedeater? I went to start it today and pulled on the rope and it all came out.
How do I replace my pull cord on my weed eater TE 475? I have the parts diagram, I need to know where the cord attaches and what the steps are to rewind the pulley and attach the cord.
Oct 19, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Garden Logo
60 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
