Question about GE SpaceMaker Microwave Ovens
Control panel touchpad does not work; push buttons for Vent, etc. are ok and clock is working. Sometimes when I press the Vent button, I get a message saying the charcoal filter needs replacing. I looked through the vent and there is no charcoal filter present. Any ideas why the control panel touchpad is not working
    Top Expert:
  • GE Master
  • 12,223 Answers
Follow this steps and fix it. God bless you
  1. Controller is confusedA power surge or random non-reproducible action of the universe may have resulted in the controller's program ending up in an infinite loop. Pull the plug for a minute or two to reset it.
  2. Defective Interlock switchesThis can result in the controller thinking the door is open and ignoring you.
  3. CleaningCleaning solutions (spray cleaner) may have gotten inside and shorted out the touchpad or controller. If this happens remove the touchpad, let it air dry for a few days, and then attach it back on the microwave.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#4#ixzz2hVdoScpK
Posted on Oct 12, 2013
2 Suggested Answers
  • 6771 Answers
SOURCE: Control panel on GE Profile Spacemaker microwave not working
You are right the control panel is very expensive, you can try the filter to see if you can get it working, but I must admit a new microwave oven sounds appealing.
Posted on Jun 26, 2012
Only three buttons on the touchpad work,#1,7 and clock
try e spares for replacement pad e spares.com
Apr 20, 2015 | Microwave Ovens
Buttons on microwave
testing every step and fix it. God bless you see the diagram attached
Microwave Buttons Don't Work
Touchpad and Control Panel
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad
If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board
If the microwave buttons don't work the user control and display board are most likely defective and will need to be replaced. If some of the buttons work and some don't, it is more likely a touch pad problem and the touch pad will need to be replaced.
Main Control Board
If the microwave buttons don't work the main control board is most likely defective and will need to be replaced. If some of the buttons work the touch pad is likely the problem. If none of the buttons work the problem may be in the main control board.1_24_2013_5_23_47_pm.gif1_24_2013_5_24_54_pm.jpg
Jan 24, 2013 | Goldstar MV-1501 Microwave Oven
The touch pod on my microwavw 9je635 wont do anything when i press the boutos for timing fuction
follow this steps and fix it. God bless you
Touchpad
Main Control Board
If the microwave buttons don't work the main control board is most likely defective and will need to be replaced. If some of the buttons work the touch pad is likely the problem. If none of the buttons work the problem may be in the main control board.1_24_2013_5_54_53_pm.gif1_24_2013_5_55_10_pm.jpg
Jan 24, 2013 | GE JE635 Microwave Oven
In oven the start button is not working
see the details and fix it. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Nov 15, 2012 | Whirlpool Microwave Ovens
My microwave keypad wont work the light is on and the reading says please touch clock and set time of dry
SEE THIS CAUSES AND FIX IT. God bless you
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Oct 01, 2012 | Kenmore 80809 Microwave Oven
Maytag microwave keypad
see this causes and fix it. God bless you
Oct 01, 2012 | Maytag MMV4205 Microwave Oven
Microwave oven touch pad problem
The keypad very well could be worn from use and be working intermittently. Replacing the keypad (and the keypad face if it is a separate piece) is the most logical solution.
Aug 22, 2012 | GE Microwave Ovens
Jun 25, 2012 | GE SpaceMaker Microwave Ovens
Hi there, I've just moved into a new apartment and the Samsung Timesaver microwave seemed to be working fine yesterday, but it has been beeping at odd times for no reason. I turned the power off to stop...
Hi, this is usually a bad touchpad. The way to tell for sure is to kill power to the unit, take the control panel down and unplug the ribbon connector that connects touchpanel to the clock. Put it back together and reapply power. The clock will just sit there blinking and, obviously, the buttons won't work, either. if the beeping stops, then the touch panel is bad. And If it still beeps, then you have a bad clock.
Apr 03, 2011 | Samsung MC5694 Microwave Oven
The display works (clock, mode, etc) I can push
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Apr 27, 2010 | Whirlpool GH9176XM Microwave Oven
Microwave Ovens Logo
240 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
