I need instruction foe whirlpool wwdc 4406 where does the red inlet go
2 Suggested Answers
  • 957 Answers
SOURCE: Why does my whirpool wwdc 7410 not start cycle?
you may have a bad door switch. I would check that the wires are still connected to the switch and that they are not broken or damaged.
Posted on May 13, 2014
What does LF mean
LF generally means "long fill error," which is generated when your washer is not getting the correct amount of water. This could be because of a clogged inlet screen, a leak which is causing low water pressure or a faulty inlet valve. You may want to contact Whirlpool for instructions on checking or replacing your hose, or cleaning the inlet screen.
Jun 29, 2016 | Whirlpool WTW6400SW Cabrio Washer
Whirlpool wwdc 9940 , it's one in the 6th sense range. I believe my washing machine is stuck in demo mode and I cannot get it back to being usable. Help!! I have so much washing to do!
I don't believe there is a demo mode in a washing machine. You would either do a wash or not do a wash. The internet seems to know nothing about it either. Contact the dealer.
You do have the water switched on?
If you have used the machine normally before, you have a fault and need to call a repair man.
Aug 16, 2015 | Washing Machines
May 12, 2014 | Washing Machines
Need a garage kit foe whirlpool EV181NZTQ freezer
My name is steven akehurst ring this number ds suplies on 01782-625551and ask for chell.
Aug 16, 2012 | Whirlpool EV181NZTQ Upright Freezer
I want (but don't know if it is possible) to set the whirlpool machine to accept a lower water inlet pressure as I only have about 10 feet of head and the machine stops when I am at work and m/c i
STEPHEN FARRUGIA, we would like to inquire further about your review with you. Please email us at Whirlpool_Reviews@Whirlpool.com with your name, phone number, street address, zip code, model & serial number and date of purchase on the appliance along with a brief description of your concern.
Oct 27, 2017 | Whirlpool AWM5104/1 Front Load Washer
Washer said to not pump when given to me.found the two red wires coming from the motor to harness chewed in two . need to know or see wiring diagram.also i get power to controls can not get door to open.i...
The wires should be color coded with a stripe on one or the other reconnect them with the dryer unplugged then plug the dryer in to see if the door will unlock. If it foes not then wait 5 minutes for it to cycle then try.
Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do you locate cold water relay
There is no cold water relay. There is a water inlet valve with a cold water solenoid on it, though. If you have no cold water, any of the following could be a cause:
1. Clogged sediment screen on the cold water inlet. You will need to shut off the water and remove the fill hose from the back of the washer and check the inlet screen on the cold water inlet on the back of the washer. Clean if necesssary. NOTE: This can be a common problem if you have hard water or use well water. Cleaning with a 50/50 solution of distilled vinegar and water using cotton swabs can dissolve most accumulations of rust and sediment.
2. Poor electrical connection on the cold water solenoid on the inlet valve. Locate the electrical connection for the cold water solenoid (usually color coded BLUE for cold water, RED for hot water) and unplug. Check the electrical contacts for any signs of corrosion. Clean the contacts if necessary.
3. Bad cold water solenoid. With the electrical connection removed and the washer unplugged, take a resistance reading on the solenoid contacts. They should read something around 600-800 ohms if good. If bad, you will need to replace the water inlet valve.
4. Kinked or clogged fill hose.
NOTE: Make sure you UNPLUG the washer before servicing.
If you determine the water inlet valve to be defective, the following link explains how to access and/or replace:
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
The part number for the inlet valve is 285805 and can be purchased at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
Prices will vary between these sites, so shop all of them for the best price.
If you need a diagram to assist you, the first three websites mentioned usually have excellent exploded view illustrations that accompany their parts lists. You can use these as a helpful reference. The water inlet valve is listed as item 18 under the "Control and Rear Panel Parts" heading.
If you have any questions, please let me know. I hope this helps you.
NOTE: Roper is manufactured by Whirlpool, and use Whirlpool parts, so these instructions will apply.
Oct 08, 2009 | Roper RAB5232E
My washing machine has had a high-pitched noise when it fills with cold water ever since we moved to a new house. This doesn't happen when it is filling with hot (or even warm) water. We've tried turning...
Are you sure you have the hot pipe on the hot inlet and the cold on the cold inlet ie red to red black to black (easily done), please check carefully. if OK then I think you have picked up some dirt in the inlet filter and this will need to be removed and cleaned,remove lid and follow pipes inside to plastic tank at top near drawer, filter housing can be seen there.
Aug 24, 2009 | Whirlpool Washing Machines
Washing Machines Logo
81 people viewed this question
Top Washing Machines Experts
