Question about Refrigerators
Old Montgomery Ward refrigerator came with home purchase and works fine, but rece3ntly I found a 1 inch hole melted in the floor of the (top)freezer. The hole has its edges curled UP (pointing toward the freezer's roof!)When it comes on, I can see the defrost element inside the floor of the freezer through the hole. What caused this? Is it a fire hazard? Can it be fixed?
  • bricescre156 Apr 25, 2009
    Despite a fairly detailed description of the hole with "edges turned UPward"- the expert thinks someone poked a hole through the freezer's bottom. How could the hole have upturned edges then? Wouldn't those edges be downturned if someone "poked a hole" through the bottom? Duh! Obviously heat from INSIDE the floor of the freezer made that hole. Any items placed directly over the hole are melted- like plastic freezer bags, etc. But it's "NOT a fire hazard," he says. OK. We're keeping the hole UNcovered just in case. I am pretty good at most easy repairs and can use epoxy. Do you recommend I take a box cutter with fresh blade and trim those upturned edges, then push some kind of fireproof insulation through the hole but still in contact with the upper floor of the freezer, and then epoxy a thick piece of plastic over the hole? Since asbestos is outlawed, what kind of fireproof insulation would you recommend? Any other fixes? No, I can't see hiring anyone to do this. I just can't afford a new refrig right now.
    Thank you very much for your opinions. You say "there is no way this melting was done by an element," meaning the defrost element my wife and I have seen glowing red under the freezer compartment's floor. Hmmm. Gotta wonder WHY this red hot element isn't capable of causing such melting! Of course we believe it DID melt the floor of this freezer compartment. The question I pose to all of you (I didn't realize this was a forum until your earlier response....sorry,) is WHY did this happen? COULD it happen again after I patch the original hole? That hole was NOT a "service hole" and it had no manufacture's made "plug." It is right in the front of the freezer's floor, 4" in from the lip, AND the hole is smack dab on a structural plastic rib in the bottom of the freezer, not a place to put a service or drain hole.
    OK, I am starting to believe no one here has ever encountered such a mysterious hole, melted with UPTURNED EDGES in the bottom of a freezer compartment. Fine. I Googled it and could find absolutely nothing out there.I can accept that, but I sure don't like it.
    Ya see, I was led to believe that by paying $10 I would be answered by a refrigeration "expert" who had experienced this problem previously. If this is a public forum for helping fix various things, I'm all for it! I belong to a forum very simalar to this for Albin boat owners. We help each other out all the time, an invaluable resource. But this, frankly, was misleading. They offer you four levels of membership, one of which was email forum answers for free, and another was the $10 "professional expert opinion" level, THEN THEY SWAP THEM ON YOU? Don't take me wrong, I do appreciate ANY answers on such a RARE question, but where is the "refrigeration expert" I paid for? DOES ANYONE OUT THERE UNDERSTAND MY SITUATION HERE?
    Thanks again-
    Mike
    President:
  • 1,263 Answers
Yes the element can cause the melting but only if in the defrost cycle. this would pose a great problem if the temp coupler was defective allowing the cycle to not shut down. re apllying a patch will cover the hole but not solve the issue of why it was there in the first place. I understand that getting a new frig is out of the question right now, but you have to repair the fault in the defrost cycle. most likely you have a faulty temp sensor for your freezer . replacing this will not only solve the main issue but is quite inexpensive as well then you can patch the hole.
Posted on Apr 25, 2009
  • Refrigerators Master
  • 3,866 Answers
Let me see whats going on here and try to provide you the asistance you need. The hole your discribing on this model had a plastic plug on it originally? or did you notice any plug on it at first. This is wht they called the service hole in lamons term as there is no way it could have been melted in that fashion by any element. You would have to take a torch to it literly to make this type of hole your discribing so thus it makes me beleave it is a service hole to make sure the element is working so they do not have to play guesswork when fixing it later on. Also the deforst element would have to get so hot that it would have melted like you said this 1 inch hole and there is not way this could have happend as they do not get that darn hot unless there was a constant heat going on in the bottom of this refridge witch make me think it was plugged at first and it was smaller then that and then it got bigger over time and you did not notice it until now. This can be fixed "Yes" you can buy a plug to put over it from Home Depo you need to file down the edges tho so the plug will fit and if it happens again you are going to need to have the defrost element fixed, i would recommend a good cleaning under the unit as well. If this information help you out in any way please rate it this helps us help you and keeps this site alive! Use the Fixya rating if you think this solution help you in any way and Thank you for allowing me the chance to help you today and I am sorry for the experience you have look me up here I will love to help you again.
  • Grand Canyon Tech
    Grand Canyon Tech Apr 25, 2009
    Use no installion at all just buy a plug flie down the edges with a file. You can buy these plugs at a home depo or any home DIY store, please do not shove anything in the hole this will cause more issues. You can use anything that does not melt do not use plastic.
  • Grand Canyon Tech
    Here is some more infromation to help you out, There is a foam sealent from homedepot that is fire resistent you can shoot in there then plug it up, please do not use plastic use metal plug again they sale these at a DIY stores like Home Depot.
    Again Thanks For using Fixya I will be looking forward to your nice rate-ing for this solution and you can do so if you feel this information is a help to you.
    Thanks
    Rulds2008
    Brigadier General:
  • 3,614 Answers
it could be because of hard object accidentally push into it that why it has this hole. if its a fire hazard. NO. it can be fixed by patching the hole, or disassembling the compartment area. better call a repairman in doing this, you need someone to help you patching/fixing that hole.
Just let me know for further assistance.
Posted on Apr 23, 2009
Is there a manual for a Montgomery Ward compact mini freezer with this model license # 8113.07 and serial # 54020? SL?
This information is usually readily available direct from the MANUFACTURER and/or ON-LINE. If you don't have access to a computer just see your local store or give the manufacture a quick call ...
  1. Montgomery Ward Refrigerator Support ' ManualsOnline.com
    kitchen.manualsonline.com > ... > Refrigerator Support
    Montgomery ward refrigerator product support information from ManualsOnline.com. Find montgomery ward refrigerator user manuals, instructions, and free ...
Sep 20, 2014 | Refrigerators
Freezer is working fine-but refrig is not cooling. Refrigerator is about 15 years old, side-by-side.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 25, 2011 | Montgomery Ward Refrigerators
Where can we get a thermo coupler for a floor furnace Ward Model 570EDR.
Most floor furnaces use the millivolt gas valve and need a pilot generator to operate correctly. These generators are bit more than a standard thermocouple.
Ebay has one for less than $20
Apr 26, 2011 | Heating & Cooling
2.0 Cubic Inch Montgomery Ward gas chain saw, 10 inch cutting bar
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 3 months old use up in a 4 cycle engine. HTH
Lou
Oct 26, 2009 | Garden
Melted plastic floor in Freezer
The refrig is possibly a Magic Chef . This refrig has the coils AND defrost heater , under the freezer floor . If the defrost thermostat sticks , the heater will eventually burn thru the aluminum coil cover and melt the freezer floor . However , with the freezer floor burnt thru , the freezer fan is not pulling the complete air flow , over the coils , which in turn , a lot more electricity is being used , to try to keep the complete refrig cool . To repair , you would need 1 ) defrost thermostat , 2 ) freezer floor , 3 ) foil coil and heater cover , 4 ) a few hours or days ( if not done before ) .
So , no , not an easy fix .
Oct 05, 2009 | Refrigerators
Freezer compartment runs continuously
icemaker running continuously but producing no ice
May 03, 2009 | Maytag MTF2156GEB Top Freezer Refrigerator
Water accumulating in top shelf of refrigerator
Get yourself a thermeter and see what the tempeature is in the freezer. It should be "0" degrees or colder. If it is hanging around 30 degrees +/- you may have a compressor or control problem. You may have a drain tube clogged that takes the water out of the freezer. I am not familar with your model but many freezers are similar.
Mar 15, 2009 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Freezer not freezing
I am not sure if know what you are talking about,but if this like a refrigrate,then I would check under the bottom to see if the condsener is clogged.Check to see if the fan is running.
Mar 14, 2009 | Montgomery Ward Melitta (ME17WFP)...
Refrigerators Logo
219 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
