Question about Kirby Generation 3 Bagged Upright Vacuum
Ran over cord and the vacuum shut down, won't
I have a Kirby G3 vacuum. The last time I used it, I accidentally ran over the cord and the machine shut off by itself. There's no damage to the cord. The vacuum won't start now. Am I right that there's some kind of safety switch that goes off when you run over the cord? Is there a reset button somewhere? Thanks a lot!
  • 490 Answers
Sounds like it might have broken a wire in the cord and may have to replace the cord unless you can find the broken wire and splice it back together
Posted on Apr 23, 2009
Kirby Vacuum Cleaner on/off switch won't stay switched on
If the motor turns on turns off in the course of the vacuuming, check the cord or the switch This is how you replace your cord on a Sentria vaxuum.
Jan 15, 2013 | Kirby Vacuum Cleaner Switch For G3-Sentria...
I have Kirby sentria that shuts off while using the rug attachment and won't start until I change to the hose attachment. I have had it in Kirby repair store 5 times, cord replaced. Took it back t
power switch faulty, slow speed terminal inside switch is burnt,hence
intermittent fault, hose uses second speed different lever inside switch
Oct 12, 2012 | Kirby Vacuums
My Kirby G3 diamond series won't turn on
Hi There, The most common problem by far is that the cord is faulty. This is a pretty easy repair to do at home. If your machine was randomly cutting out before it stopped altogether then the cord is likely the culprit. If however it stopped all of a sudden with no warning then it is possibly a switch or motor issue which is a much harder repair to achieve for a novice.
The kirby cords are not terribly expensive (and I have linked a how to video showing how its done) so if you need a new one I would say DIY is the go, otherwise spend the $25 get a pro to take a look.
May 22, 2012 | Kirby Generation 3 Bagged Upright Vacuum
Ok, my kirby just stopped working. I had someone helping with my vacuuming, so maybe they ran over the cord or something. I can see a recent scuff mark on the cord.??? Also last time I pulled the...
When was your Kirby made? If you have an older Kirby, inside where the motor lies is a single or double magnet with a spring coil attached to it. Within that coil is a filament wire held together with a shiny disk at other end. This filament does go bad from time to time and needs to be replaced. This usually is not a do it yourself job. If you can find the proper filament, you might but usually there are several types and sizes, let your local distributor change it for you.
Apr 04, 2017 | Kirby Ultimate G Bagged Upright Vacuum
I accidentally ran over the cord and then machine motor slowed down and stopped running. It wouldn't turn back on
get a new cord. It was stretched and ripped apart under the outer rubber cords housing insulation
Sep 01, 2010 | Kirby G4 Bagged Upright Vacuum
My Kirby G5 has stopped working, last few times it was used it kept cutting out everytime the handle was moved??????????
This definitely sounds like your cord is bad. The reason that I specifically think that it's your cord is because the cord is actually connected into the handle, and is attached to the handle in the back. This would make sense why the machine was cutting off every time the handle was moved.
Also the cords are notorious on Kirby's for going bad, and are usually the only thing that goes bad on a constant basis.
Here's how you can check to see if your cord is bad or not:
Greetings from GoVacuum.com,
Unfortunately there is no fuse on a Kirby Generation model. In my 10 years of repairing Kirby's as well as other vacuums2_bing.gif I will tell you that 9 times out of 10, when a Kirby Generation doesn't turn on, it's the cord that needs to be replaced. This is by far the most common problem that we see on Kirby repairs.
The Kirby motor is very well built, and usually has a life of 30+ years (G3 is about 12-15 years now). The only other problem it could be on the Kirby would be carbon brushes, or the switch assembly.
I would first try testing the power cord, I think this will solve the problem for you. To test a cord on a Kirby Generation (all Generation models are the same machines, just different colors) first follow where the cord goes into the Kirby at the bottom. To access this cover easier, first remove the "boot" at the bottom of the outer bag. This is the plastic part at the bottom of the outer bag that connects onto the Kirby. You will see that there is a plastic cover over the cord. You will need to remove the screw that holds this cover on.
Now after you have removed the cover, pull the plug out of the machine. Once you have the cord disconnected from the machine, you can now test it to see if there is a short somewhere in the cord. You will need to purchase an inexpensive continuity tester from Home Depot, Radio Shack or most other electronic stores. This will tell you if there is power running through the cord, or if the cord is bad. With the continuity tester, plug the cord into the wall outlet, then put the positive, and negative testing rods into the female end of the cord that plugs into the machine. You will then be able to tell if the cord has continuity going through it. The tester will indicate if there's continuity or not.
The picture here shows that the cord is good. If your tester does not light up, or indicate that there is continuity, you'll simply just need to purchase a new cord. As I stated earlier, this is the most common reason that a Kirby won't turn on.
If however your cord tests OK, this indicates that the machine either needs a new motor (or carbon brushes in the motor) or it needs a new switch.
Chris Jones
GoVacuum.com
Apr 14, 2010 | Kirby G5 Bagged Upright Vacuum
I was vacuuming my car and the Kirby G4 just stopped
Greetings from GoVacuum,
Unfortunately there is no fuse on a Kirby Generation model. In my 10 years of repairing Kirby's as well as other vacuums I will tell you that 9 times out of 10, when a Kirby Generation doesn't turn on, it's the cord that needs to be replaced. This is by far the most common problem that we see on Kirby repairs.
Now after you have removed the cover, pull the plug out of the machine. Once you have the cord disconnected from the machine, you can now test it to see if there is a short somewhere in the cord. You will need to purchase an inexpensive continuity tester from Home Depot, Radio Shack, or most other electronic stores. This will tell you if there is power running through the cord, or if the cord is bad. With the continuity tester, plug the cord into the wall outlet, then put the positive, and negative testing rods into the female end of the cord that plugs into the machine. You will then be able to tell if the cord has continuity going through it. The tester will indicate if there's continuity or not.
Please feel free to email me if you'd like instructions on how to diagnosis the switch or carbon brushes, or if you need to purchase a cord for your G3. Also I can send you a parts diagram of the Kirby should you ever need any other part for it. I have all parts for Kirby in stock, and we are the cheapest price online.
If the cord tested ok, then there are a few other things that may have gone bad. I'd be more then happy to try and help you diagnosis the Kirby further. Please just request a repair clarifiaction here on Fixya with further details.
If this helped you figure out the problem, please rate my repair as helpful. I really do appreciate it, thank you.
Chris J.
Mar 15, 2010 | Kirby G4 Bagged Upright Vacuum
Our G3 Kirby will not power up?
Either the cord or the switch is bad. The cord is simple. Take the tab screw on the back of the machine off and the screw holing the cord cover off. Pop off the cord cover un-plug and remove then reverse steps to replace. If it is the switch that is better left to proffesionals so call your local vacuum shop.
Apr 10, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Hi! I'm interested in purchasing a G3 model ; however , the seller says that the machine was working perfectly and then when switching power on a while later , the machine was " dead " . Other...
Unfortunately there is no fuse on a Kirby Generation model. In my 10 years of repairing Kirby's as well as other vacuums, I will tell you that 9 times out of 10, when a Kirby Generation doesn't turn on, it's the cord that needs to be replaced. This is by far the most common problem that we see on Kirby repairs.
Chris Jones
GoVacuum.com
chris.jones@govacuum.com
Oct 15, 2008 | Kirby Vacuums
How to send g3 sweper to factory for refurish
Absolutely!! If youre the original purchaser of the machine, the rebuild program is available for your kirby for as long as you own it.
here's the site for more information
http://www.kirby.com/Portals/0/rebuild_program.html
Its quite a warranty on Kirbys...wish my car had the same sort of warranty
Jan 06, 2008 | Vacuums
Kirby Generation 3 Bagged Upright Vacuum Logo
160 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
