Question about Car Audio & Video
One day my sony cdx gt34w just locked up only thing that works is source and the volume wont even eject a cd. All the screen says is either cd failure or fm failure. Ive reset it many times and checked my connections and its still not working.
2 Suggested Answers
SOURCE: CDX-S2000 Volume, Source, and Mode buttons not working????
Hey jshaff, try taking off the detachable front, and you will see a reset button, press and hold in for 10 secs, this should solve your problem. if it doesn't work first time keep trying. you must have power to the head unit for this to work. you will hear the cd make a noise and that should be that, try and let me know.
Posted on Oct 04, 2008
Sony cdx-gt610ui buttons won't work
Guys,
I have a CDX GT610, the issue is that is not possible to change stations, even if I try with the push buttons to record the stations, it remains on the same station (number 3 in my case), besides the volume gets high if I want increase the volume, any suggestion about it??? please let me know
Best Regards,
Marco Hernandez
Feb 26, 2013 | Sony CDX-M630 CD Player
Sony CDX-S2250s has worked great until recently when it just went totally goofy & now it wont do anything. The screen illuminates with random stuff but no buttons will work not even the cd eject &...
hello, if all the wiring and battery voltage levels check out fine then, try resetting the unit by using the microswitch behind the face unit. if this does not work then make sure that ALL the switches on the face have a definite "click" feel when pressing them down. those for "volume" and "track up/down" are known to collapse, and thus cause the microcontroller to become "confused." to solve this problem you will have to replace these microswitches. lastly an internal power supply fault or a circuit fault can also cause these problems. cheers!
Jun 07, 2012 | Sony Car Audio & Video
I have a Sony CDX L480x fitted in my car, this radio has worked fine since i got the car, unfortunatly when i put the face back on it the other day, none of the buttons will work, volume, source...etc. All...
It sounds like the volume button may be jammed or the volume up switch may be bad. If the switch is open just enough to let some voltage through it locks up the microprocessor. Unless you have a multimeter and know how to check resistance on a switch you would be better having a professional repair person check it out.
Sep 29, 2011 | Sony CDX-L480X CD Player
I've had my Sony Xplod CDX S2010 Radio/CD player in my Jeep for years and it has all of a sudden locked up on me. The CD player will play and eject CDs, however it doesn't allow me to adjust volume or skip...
i'm not sure if there is a flexible cable that goes from the face to the motherboard. if there is, that could be the problem. it could also be a bad switch.
Aug 25, 2010 | Sony CDX-S2010 CD Player
Sony CDX M730 won't operate manually, remote doesn't work either
my sony wnt flip down so i can change cds its stuck
Feb 16, 2009 | Sony CDX-M730 CD Player
Need to fix the time
I have the the sony cdx gt 400 and the manual is of no help but I figured it out. You have two options...option 1 is wait until 1 o'clock and hit the small reset button on the radio behind your detachable face, or option 2 is a even better option. Press and hold the volume button in and options will appear...then by tapping the volume button you will cycle through the various options until you find "clock adjust" then press the small "display" button below the volume knob and also right next to the "source" button...the hour will flash turn the volume knob to desired hour then tap the volume knob or display button and the minutes will flash then turn the volume knob to the desired minutes, and you are done...hopefully this helps
Nov 14, 2008 | Sony CDX-GT400 CD Player
How do ya work this thing?
Press the SOURCE button "Bottom left of Row"
Aug 30, 2008 | Sony CDX-R3300 CD Player
Sony CDX-M630 CD Player Problem
Mine did the same...it will stop working all together soon...repace the ribbon you should be fine
Apr 22, 2008 | Sony CDX-M630 CD Player
Please Help
check face plate maybe contact dirty if not well our in trouble sometime it not worth to repair it cheers
Jan 08, 2008 | Sony CDX-S2010 CD Player
Car Audio & Video Logo
199 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
