Question about Epson Stylus Office Equipment & Supplies
100000E0 CPU address error (load misalignment)
Message is Service call error 00010014 I have an Epson Stylus pro 9800 and I am getting a message saying: Service call error 00010004 error 00010004 SERVICE CALL 00010004DescriptionFailure of ...
Epson Stylus Pro 4400/4800/4880 Error Codes
Maintenance Request Codes:
• 0002 - CR Motor near end of life - Replace carriage return motor ASAP
• 0006 - Battery shut off - Replace RTC back-up battery
• 0040 - Cleaning unit near end of life - Replace cleaning unit ASAP
• 0080 - Date not set - Set the date through the printer control panel
• 0088 - RTC backup battery not installed - Install RTCbackup battery
• 0100 - RTC backup battery pressure is temporally low - wait for a while
• 0200 - The number of ASF paper feeding has reached predetermined value
• Service Call Codes
• 00000101 - CR Motor reached end of life - Replace carriage return motor
• 00010000 - PF encoder check error
• 00010001 - PF motor is out of step
• 00010002 - PF motor overcurrent has occured - Replace PF motor
• 00010003 - PF motor out of postion time-out error
00010004 - CR encoder check error - ensure enoder strip is clean & dust free
• 00010005 - CR motor out of step - click here for more info
• 00010006 - CR motor over current
• 00010007 - CR motor out of position time-out error - Replace the board assembley, main
• 00010008 - Servo interupt watchdog time-out error - Replace the board assembley, main
• 0001000A - Carriage home position detection error
• 0001000C - PG home position detection error
• 0001000F - CR motor PWM output faulty
• 00010010 - PF motor PWM output faulty
• 00010012 - CR overload (high sensitivity) error
• 00010013 - PF overload (high sensitivity) error
• 0001001B - Head Driver (TG) temperature error
• 0001001D - CR servo parameter error
• 0001001E - PF servo parameter error
• 00010020 - CSIC reading/writing error
• 00010022 - Ink type error (setting on printer body side)
• 00010023 - RTC analyzing error
• 00010025 - SCIS ROM communication error
• 00010026 - RTC communication error - click here for more info
• 00010028 - Head error - replace print head
• 00010029 - Unidentified NMI
• 0001002A - CR ASIC ECU error - Reinstall/update firmware
• 0001002B - PF ASIC ECU error
• 0001002D - Cleaning unit has reached end of life - replace cleaning unit
• 0001002F - 360 DPI writing time-out error
• 00010030 - Multi sensor error
• 00010031 - ASF phase detection error
• 00010032 - ASF drive switch error
• 00010033 - Eject phase detection error
• 00010034 - Eject movement error
• 00010035 - Pump phase detection error
• 00010036 - Type-B board installation error
• 00010037 - Head thermistor error - Replace print head
• 00010038 - Transistor thermistor error - Replace board assembley, main
• 00010039 - PG adjustment value incorrect overwrite error
• 0001003A - PG adjustment value outside range error
• 0001003B - Cutter installation error 1
• 0001003C - Cutter installation error 2
• 0001003D - Cutter installation error 3
• 00020000 - NVRAM error - Replace board assembley, main
• 00020002 - SDRAM error - Replace board assembley, main
• 00020003 - Boot program SUM error - click here for more info
• 00020009 - Flash memory SUM error
• 0002000A - Program load error
• 0002000B - The internal memory is insufficient
• 100000E0 - CPU address error (load)
• 10000100 - CPU address error (store)
• 10000180 - CPU reserved command code exception error
• 100001A0 - CPU slot undefined command exception error
• 100001C0 - The AC power is shut off
• 100005C0 - CPU DMA address error
• 10000xxx - CPU error
• 0003xxxx - Debug orode
• 0Dxxxxxx - An error code for debugging
• 0Exxxxxx - A time-lag of the RTC timer
Mar 24, 2018 | Epson Office Equipment & Supplies
Haier HWD 1600, error 7
I had this washer for almost 2 yrs and you'll end up fixing things here and there. Well after some heavy research this error was supposedly the control box or some computer chip/loose connection. After taking apart all the pieces and reassembling, still err7 comes up. Turns out our daughter liked to open the door and pull down on it, causing a misalignment. There's lock that 'clicks' when you start a load to lock the door and I'm guessing there's a sensor that takes 5 seconds to detect if the door is closed properly. Our door was misaligned so the sensor tripped the circuit after 3 seconds of the water starting. I just press the door more with my knee and start the load. After 5 seconds I let go and all is well.
Apr 21, 2014 | Haier 14.3 lb. Washer/Dryer Combo
Error: "Intel CPU uCode Loading Error" - "Press F1
This could have been a RAM issue or a BIOS issue. Check your RAM first and reset your CMOS. If possible upgrade your BIOS version from the manufacturers website. but be very careful if you do so. a wrong move may spoil your Board completely.
Sep 18, 2011 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
(1)cpu fan error (2)chassis intruded (3)fatal error.....system halted
The reason for this error is Overheat! Please replace the CPU Fan with a new one and add additional Fan for the CPU Cabinet in order to cool the CPU. Then, reset the BIOS to default value by pressing the F2 Key or Delete Key at the Startup and select Load Optmized Defaults or Load Fail Safe Defaults option. This should resolve the issue.
Mar 02, 2011 | Computers & Internet
Intel cpu ucode loading error
does your cpu?boot up?try to go at the cmos!!then load bios defaults?
Jul 14, 2009 | ASUS P5VD2-MX SE Motherboard
Paper load error.
check rollers for free operation and anything that maybe causing it to misalign!!! :) maybe something foreign stuck in it ive had that happen!!!!
Jul 06, 2009 | Office Equipment & Supplies
Service call error 100000E0 epson 7800
service call error 100000e0 printer no 9800
Jun 10, 2009 | Epson Stylus Pro 9800 InkJet Printer
Cpu fan error on monitor. Fan still spins. Replacement fan generates same error
try going into ur BIOS and select load failsafe defaults...save and exit and it should be fine...if it works LEAVE UR BIOS ALONE...
May 27, 2009 | HP Media Center M370N (DM163A#ABA) PC...
Intel uCODE loading error
problem for all ASUS PC Desktops Intel uCODE loading error button1-share.gif
May 18, 2008 | ASUS Computers & Internet
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
