Question about Panasonic KV-S1025C
Error code 20000000
Communication error. check cables and if no help reboot.
Communication error epson 520
Check your cables are in the correct positions., Turn the printer off and reboot your computer. Check the computer and see if it " finds" the printer. On the PC, press "start" look for and click on "printers and or accessories" Your printer should be displayed there. Click on properties. If the PC cant find it, I would say the cable is damaged or disconnected or the software for your printer has been deleted or failed. You may have to reinstall the software again.
Aug 26, 2014 | Epson WorkForce Office Equipment &...
CODE F9-88
F9-88 is a printer board communication error, either printer board has failed or the memory chip is no longer working. try unplugging printer cable and rebooting machine, or unplugging machine for 10 seconds and powering up again to reset the code.
Mar 22, 2014 | Sharp AR-M317 Black and White Copier
E000747-621b error on printer
This is usually a communication issue between copier and finisher, check connection to copier. Reboot, if error is still displayed you may need to dig deep into copier removing cleaning and re-seating main-controller sub pcb's checking cables ribbon cables ect. however this job is not recommended for anyone other than qualified technicians.
May 31, 2012 | Canon iRC2380i
I got error on printer LBP2900 when connect to my laptop (windows 7) It show communication error but usb connection and software installation no problem. Any idea about it?
Most likely it is a corrupt software installation.
You can try the easy things first: 1) Unplug the USB cable from the computer 2) Reboot 3) Plug the USB cable back into the computer, see if the communication error happens again
If that doesn't work, time to reinstall the software: 1) Go to Control Panel > Add Remove Programs OR Programs (depending on which version of Windows you have) 2) Remove every piece of software related to your printer 3) Unplug the USB cable from your computer 4) Reboot 5) Disable any Anti-Virus or Firewall software that you have running 6) Re-run the printer installation software
Jul 04, 2011 | Computers & Internet
Boot Error 55 on HP LJ-4si
Please ensure the communication cable between the printer and the system is good, if not please have it replaced.
The board may be bad and needs replacement.
Have the cable replaced, shut down the printer and reboot it
Apr 15, 2010 | HP Officejet 5610 All-In-One InkJet...
Ir3170 error code e000732-0001
This error code is a communication error between the Reader Unit and the Copier (Printer Unit). Shut down and un-plug the Copier. Unplug and reset all the connectors on the rear and sides of the copier. One interface cable is responsible for communication between the reader unit and printer unit. This may solve the problem. Possible the cable is defective see if cable or cable socket is damaged.
This error also can be caused by a defective reader controller/DC Controller or Main Controller PCB.
If the simple cable check does not solve the problem a service call by a Canon dealer will required.
Mar 16, 2010 | Canon Office Equipment & Supplies
Problem communicating with the printer
check your cables, remove the USB from it, and reboot, plugging back after reboot. Also check your Device Manager to make sure the printer is not having driver related errors, or the driver is missing for the printer.
Mar 01, 2010 | Lexmark X2600 InkJet Printer
Error system on the display when I rebooted nokia 9500
hi there try this reset code for a nokia communicator phone like your 9500 just enter this code *#7780#
Feb 11, 2009 | Nokia 9500 Communicator
Communication Error
Disconnect from pc, restart printer on it own, same prob then will need firmware reinstalled, hard drive replaced or even main controller, Job for a tec.
Works ok alone then driver issue delete and reinstall driver check cable too.
Dec 11, 2007 | OKI C5200n Laser Printer
Panasonic KV-S1025C Logo
57 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
