Question about Frigidaire Kitchen Ranges
DCS-RG 364 oven door hinge broken (little hook for removal broke off)
  • 2920 Answers
SOURCE: Oven Door Hinge Squeaks
try wd-40
Posted on Sep 06, 2008
SOURCE: Please help me!??? We have oven door hinges which
open the door all the way, unhook the little hooks. Then close the door
Posted on May 08, 2009
  • 3 Answers
SOURCE: Oven door hinges
It is tricky, it takes two people to hold door in place, put hindges into slots then fold downward towards the floor, the hinges will open all the way and it will snap back in.
Posted on May 29, 2009
  • 222 Answers
SOURCE: dcs oven door unhinged
easy to install the door,before to remove check it how exactly the position of the door its a clip typr,or get the manual to see the procedure,open the door,pull open then if u see the hinge we have small lock in the hinge u psh it up the lock then slowly close the door,be care bcoz the hinge is powerfull,if u close the door see the hinge how to remove the door.
tnx gerbee
Posted on Jun 23, 2009
  • 8 Answers
SOURCE: Changing the main hinges on the oven door
Contact the britannia Service team on 01253471111 option 3. Someone there will be able to talk you through or they could do it for you.
Posted on Jul 20, 2009
Putting door back on but hinge wont release to put back on
Hi Susan, this is AP! Thank you for your post.
I understand you are having trouble putting the door back on your Frigidaire wall oven. Without knowing exactly how you removed the door I cannot say with certainty how to reattach the door. However, when removing the door did you pull up the lock located on both hinge supports and engage it in the hinge lever hooks? You might have had to apply a little downward pressure on the door to pull the locks fully over the hinge lever hooks. Then grab the door by the sides and pull the bottom of the door up and toward you to disengage the hinge supports. If so, then to reattached the door grab the door by the sides; place the hinge supports in the hinge slots. Open the door to the fully opened position. Disengage the lock from the hinge lever hooks on both sides. Make sure the hinge supports are fully engaged before unlocking the hinge levers. Then close the oven door. There are instructions with images to remove and replace the oven door in the owner's manual. I hope this information proves helpful for you.
Mar 14, 2014 | Frigidaire FEB30S6D Electric Single Oven
Emerson microwave door latch
I have an Emerson MW8999RD that all of a sudden yesterday wouldn't latch. I don't think you have to, but I took the door off (three screws hold the case on which needs to be removed to get at the top hinge). Then I took off the inner plastic picture frame - pretty easy with a thin blade to move the fragile tabs. Then I removed the metal frame that has the little microwave blocking holes. This was the hardest part because the plastic retaining tabs are even more fragile and I broke one. Then I found the loose spring due to broken plastic hook as described above. I was able to make a new hook by simply looping a small zip tie where the old plastic hook tip broke off. Now works great!
Aug 22, 2013 | Microwave Ovens
Apparently a spring on my oven door is broken (DCS-RG-4844GG). On the large oven door, the left hinge has no tension in it. I can latch the hinge to remove the oven door for cleaning. However, when I...
spring is broken on the side that is 'slacked' without return tension. may be necessary to get underneath the stove chassis. move away from wall, carefully disconnect the gas fitting after turning off the gas spigot. Pull away far enough from wall to 'tilt' the whole chassis rearward to access the underside. Technicians use a 'jack' to raise stove....
Dec 02, 2017 | DCS RGS-484GG Gas Kitchen Range
I removed the oven door and took out the hinge to clean. When I tried to put the hinge and oven door back the hinge will not close it is stuck. How do I unlock or hook the hinge so my oven door closesI
You will have to pull the oven dorr up and out again, it might be a little hard to pull but the door didn't went in straight and it's preventing the hinge from closing. go to repairclinic.com for an ilustration on how the door and hinges fit in place.
Jan 14, 2010 | Ovens
Dcs oven door unhinged
tnx gerbee
Jun 23, 2009 | DCS RGS-305 Professional Gas Kitchen Range
Broken inner glass on Model # NGSG3PZAQA
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Mar 17, 2009 | Frigidaire FGB24S5A Gas Single Oven
Oven door zbf360x zanussi
Open the door half way, grasp it firmly and pull as hard as required using a slight side to side motion to release the hinges which are attached to the door.
There are then to nuts on the bottom of the door which when removed allows you to split the door in half.
The hinges have a little lever on them such that they can be jammed open against the door. Once the hinge hook is in the oven housing simply turn the latch the other way, stand back and have a beer.
Feb 14, 2009 | Zanussi ZBF360X Electric Single Oven
RG 364 6D DCS gas range
Call 888-281-5698.  Parts ship from California, available next day.  I've had immediate, good, intelligent response.
Nov 29, 2007 | DCS RGS-486GD Gas Kitchen Range
Kitchen Ranges Logo
82 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
