Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Hi I did a tune up ,changed and checked every thing I done ..too I changed the oil ,oil filter ,gas filter air filter ,got a new battery changed the plugs there new too...even a new belt new key ...but my mower wont start it cranks and that's it help please its a 54 " rtz cub cadet, zero turn ridding mower modle #17A12ack056
    Problem Solver:
  • 5 Answers
Spark and gas??? Must have both. Pull spark plug wire and check for spark. If you have spark, check gap on spark plug. Check the bowl on carburetor. loosen bowl screw to see if gas is coming out. If you have gas coming out, carb needs to be taken off and cleaned or rebuilt.
Posted on Apr 29, 2014
SOURCE: I HAVE A CUB CADET GT2542 RIDING MOWER. I CHANGED
There is no way to reset it. It will stay on until the hour meter reaches 102 hours and then the light will go out
Posted on Jun 13, 2009
  • 8 Answers
SOURCE: cub cadet 2140 wont start or turn over
check the cilanoid or the stater , you may also have a lose conaction, try cross jumping the cilanoid
Posted on Aug 16, 2009
  • 10 Answers
SOURCE: Trying to put on mower deck belt for cub cadet
Visit this web site http://www.partstree.com/parts/
you can pull up your Cub
Posted on Oct 18, 2009
redbeard00
  • 957 Answers
SOURCE: my cub cadet tank stops running 5-20 minuts after
Yes you may need a carb kit. It is not good practice to by-pass the fuel filter. The orifice in the jet is very small.
But anyways, There Could still be a blockage inside the carb, a small leak at the manifold, or the jet is worn out.
Let me know how it goes.
Posted on Apr 28, 2010
vincob
  • 718 Answers
SOURCE: I need a mower deck belt diagram for cub cadet
Go to this website, upper right hand corner and do a parts look up. Search for your model and that good stuff they ask of you and then choose mower housing should be there, browse the site it's really cool and has a lot of info.
http://www.jackssmallengines.com
I did a sample search for generic riding mower deck and found great diagram of belt routing. Give it a try you will find same results Good Luck! Don't forget the thumbs!
Posted on Aug 14, 2010
My 99 navigator 5.4 engine runs rough when accelerating
Check fuel filter and air,could be tune up,bad wires.
Jan 21, 2015 | 1999 Lincoln Navigator
What causes co & hc readings to high
HC is raw or un burnt fuel. CO is incomplete combustion meaning the air fuel is burnt but not burnt completely. check O2 sensors for operation, fuel pressure, gas in oil or how long has it been since an oil change. check engine timing, dirty injectors. when was the last time a tune-up was done plug/wire condition is the air filter clean. just some things to check
Sep 05, 2014 | Volvo S40 Cars & Trucks
I took my car to get an expection and the only thing i needed was a tune-up.My ford is overheating and I changed the alternator,and put and new battery in it. For some reason the collant pump that runs to...
You need to have the water pump replaced-while that is being done, replace the thermostat, and have the cooling system flushed. That should cure your overheating problem. A Tune Up involves a new distributor cap, rotor, plugs and plug wires-goo idea to have the throttle body cleaned when this is done, new air filter and maybe an oil change/filter and a new fuel filter. While this will cost a decent amount (about $300 to $400), if the car is in reasonably good condition, it will give you another 50,000+ miles before it will need much else besides oil changes. The most important thing, though, is to get the overheating under control-if you overheat the engine, it might be fatal to the car period.
Jul 20, 2011 | 1989 Ford Crown Victoria
My car has hit the 200,000 mile mark a little while ago. I like doing the stuff myself, but am not sure what all goes into the tune-up. What all should be changed/done for a 200,000 mile tune-up?
the wuggles, A complete tune-up should include: spark plugs, wires, PCV valve, fuel filter and air filter. Change the oil and filter and add some injector cleaner to your gas tank. Also, check all of the vacuum hoses for any deterioration and replace any that look bad. Also, when is the last time you changed the transmission fluid and filter and your coolant? It's good to hear from someone doing preventative maintenance for a change instead of waiting for problems to occur. My hat is off to you. Good luck with this.
Jun 20, 2011 | 1996 Chevrolet Cavalier
What does a major tune up for a 2004 chevy impala consist of? What should be done and needs to be done?
New spark plugs, oil and oil filter, transmission flush and fill, fuel filter, air filter, coolant flush and fill, clean throttle body plate and bore, clean the MAF sensor, replace any loose or cracked vacuum lines, PCV valve, new air filter, new battery.
99% of the time all you should ever need for a tune up is new spark plugs, and a clean air filter and throttle body. But since your inquiry indicated "major" I gave it more critical thought.
Feb 18, 2011 | Chevrolet Impala Cars & Trucks
What can cause a car not to get power and speed?
Here is a list. Bad timing,dirty air filter,cheap gas,old spark plugs,bad spark plug wires,bad fuel pump,bad fuel regulator,bad exhaust system meaning full of holes,dirty oil and oil filter,dirty fuel filter.
Feb 17, 2011 | 1995 Ford Taurus
Starting problem
Hard to say depending on when the last complete tune up has been done. It coud be related to the ongoing maintenance or to a specific problem.
Generally speaking, in preparation to the winter, with a car of this generation I would replace spark plugs, wiring, distributor cap and rotor, air filter, gas filter, oil. I would check and clean battery terminal connections and have the battery check (check under load). Check is the engine temp is ok and replace thermostat if needed. But once again it's by prevention and you will get your money back saving trouble and saving on gas. This is the first thing I'll recommend anyway.
Hope it will help
Dan
Dec 23, 2009 | 1995 Honda Civic
2002 ford focus is geting poor gas milage
Tune Time.
1)new spark plugs properly gapped.
2)new air filter (check every 35000 miles)
3)new fuel filter (every 35000 miles)
4)1 bottle of STP fuel treatment (red bottle) 4x a year.
5) oil and filter change (castrol or another good quality oil every 3-4000 miles.
6)proper air pressure in tires (check every 2 months
7) service transmission every 40000 miles or less.
New oil and filter
8) new plug wires every 80000 miles.
Nov 07, 2009 | 2001 Ford Focus
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Poor gas mileage, no power in engine
Your problem could be caused by numerous things, how well was this car maintained? A good tune-up should rectify your problems, oil change, air filter change, tranny fluid and filter change, plugs and wire's, coolant flush, timing belt, thermostat, fuel filter are all things that you should have done if they haven't been done recently. Let me know what you have or haven't done on the car and I can try to diagnose further.
Hope this helps
Jun 25, 2008 | 2001 Hyundai Elantra
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
168 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
roeb
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
