Question about Dell (PS-5251-2DS) (M0148) 250-Watt Power Supply
Power supply seems to shut down during computer boot up
power supply is only putting out 11.9vdc with no load. The 5vdc seems to be fine
  • Dick
    Dick May 11, 2010
    11.9 v is fine too. There is a 5% tolerance on the voltages, often things will function with a 20% variance.
  • 600 Answers
11.9 is fine-no problem with that
Posted on Apr 23, 2009
Why is PC cutting out when graphics under load
Hello, I am the technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya, Smayson.
You computer system is quite substantial. It needs a solid, stable power supply. One that can output high loads for a continued period of time.
I would say you need a power supply of at least 850Watts form a good Power supply manufacturer. Corsair or Cooler Master. 80+ efficiency if possible.
It is also a good idea to take your computer system into a computer store for testing. They could connect a good power supply and check that it solves your problem, before purchase.
Take care!
Dec 23, 2011 | Gigabyte GA-EX58-UD3R Motherboard
HI I have a D865 PERL m/b. The CPU overheated, due to a load of dust blocking the heatsink fins. I have cleaned it all up and the heatsink should be fine now, but when I try and boot I get a message...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
Also you might try
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
hope this helps
May 14, 2011 | Intel D865PERL Motherboard
Hi, i have a Sony vaio and it was working fine until I shut it down overnight, the next morning I tried to turn it on which started out fine but as soon as the windows emblem started loading, it didn't...
or
Also you might try
hope this helps
May 01, 2011 | Sony Computers & Internet
When booting up the devise, only the GPX logo appears. seems stuck and won't shut down unless i remove the battery. switch to off position does not work. I can load and delete mp3 files from the computer...
or you might try
hope this helps
Apr 10, 2011 | Computers & Internet
Shuts down on boot up
hi sir,
Does it just shuts down or it reboots?
If it shuts down this type of problems can be resolved by scanning the computer for a virus or
using the Windows Repair Disks. During boot if you can hit F8 and use safemode with command and prompt.
1 Type CHKDSK/F then hit enter
2 Press Y then hit Enter then reboot to see if this works.
If it reboots while booting up then.
Other things that might be preventing the computer to boot up most likely is the memory.
Take out the memory put it on a different slot or try a new memory.
Also make sure that the power supply fans are not dirty this prevents the computer to bootup.
Jan 24, 2011 | E-Machines T5212 PC Desktop
When powering from full shut-down, takes about 30
whenever you want to turn it off, put it on hibernate.
Jan 02, 2010 | Toshiba Satellite M35X-S161 Notebook
Machine shutsdown hard shortly after boot
OK, i experience this before, i think your situation is mostly like mine, and this problem may cause by the your laptop power adapter, please replace a new adapter and see how is the result. Hope this help.
YBC (/\)
Oct 07, 2009 | E-Machines 6809 Notebook
During loading of window drivers the machine shut off.
go into systen bios and set the default leave it there for a good duration doing notheing. see if the machine dies if not save the setting and reinstall using the Boot from CD.
DO not Boot from HD
try a different CD drive unit too.
Jul 27, 2009 | Computers & Internet
Dell XPS 600 turns itself on to solid amber
Hi. the mother board seems to be having some initialization issues during boot up. this is common when the mother board is failing. i would check to make sure the battery on this board is working. if it is, the board my be ruined.
power board seems to be fine.
please rate and god bless.
Mar 17, 2009 | Dell XPS 600 PC Desktop
Asus a8v-vm se fans always run
Hi jderek4, try this. locate the toggle switch on the back of the power supply. Just find it do not flip it.
Plug the PSU's power cord into the PC. Just as you got a good connection & the PC begains to power up move the toggle switch to it's other position. The PC should power off that very second.
If the PC does not shut off than the PSU is bad. If it did shut down wait a few seconds. Press the cases power on button. The PC should start to boot up. Let it finish loading. Click the start button & choose to shut down windows. The PC should shut off.
Yes? If not than your back to (bad power supply). Swap it out.
Mike
Mar 29, 2008 | ASUS A8V-VM Motherboard
Dell (PS-5251-2DS) (M0148) 250-Watt Power Supply Logo
308 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
