Question about Skagen 355LGSC Wrist Watch
Skagen 284LTX remove the bezel - Skagen 355LGSC Wrist Watch
Who is qualified to replace battery in Skagen watch in Edinburgh Scotland
Go to any jeweller of department store. They carry all the batteries, and the tools to remove the back. Costs about £10.
T. Paterson Jeweller ' Skagen watches ' Perth ' Scotland
www.patersonjewellers.co.uk/skagen-watches-perth.html
  1. Cached
  2. Similar
Sleek, minimalist Scandinavian design defines the Skagen watch brand. A distinctive range of watches for those wanting something a little different.
Skagen watch Google Search
Jun 07, 2017 | Skagen Watches
How to replace battery in Skagen 585XLTMXB watch ?
  • Remove back
  • Find battery and identify type. Note mounting arrangement
  • Obtain replacement of correct type
  • Remove old battery. Install new battery
  • Check operation
  • Install back
Aug 09, 2016 | Skagen Watches
The crystal of my wife's skagen watch popped out and the nylon ring surrounding the crystal seems too big to get back in, or perhaps I just don't have the right tools. Help!
Watch crystals are pressure fitted to their cases so that they are resistant to popping out. Think of a champagne cork, and how it expands when it comes out of its bottle.
Crystals are set into cases in one of several basic methods. First, a crystal may be installed from the back--watch cases are commonly assembled before the movement is installed. So, one potential way of reinstalling your crystal is to remove the watch movement from the case (if it isn't already) and try pushing the crystal from the back forwards. If this is indeed the way it was installed, the crystal should pop into position with a noticeable click or light thump to let you know that the other edge of the crystal has found the shallow groove in which it's supposed to sit.
Second, some crystals can be installed from the front using a tool called a "crystal lift." This tool has many little fingers that compress the edge of the watch crystal so that it can be slid into the case. Pressure is then gradually removed from the crystal, permitting it to expand into the shallow groove into which it's supposed to sit. Crystal lifts are easy to use in theory but somewhat finicky in real life; the crystal must be grabbed equally by all the lift prongs or else the crystal will have a tendency to squirt out of the tool before it's been completely set.
Looking at pictures of your wife's watch, it doesn't look to me like a crystal lift would do any good. I think instead that your crystal might have been installed using a third method. Looking at the pictures, it looks like the bezel--the metal top of the watch--separates from the watch body. If this is the case, gently pop off the bezel and push the crystal into it from behind. Then, push the bezel back onto the watch movement. It's possible that the crystal is kept in place by being squeezed between the bezel and the rest of the watch case.
If all of this sounds daunting, putting the crystal back in--assuming it's not cracked--is a minor job for a watch repair technician. It literally might only take 5-10 minutes to complete the job. If you're concerned about the appearance of the watch, it might be safest to pay someone the small amount of money to get this done right. Replacing a watch crystal with a new one usually runs about $15-25, around where I live. Replacing an undamaged crystal that's popped out should cost appreciably less, since a new crystal costs a jeweler between $5-25 for most standard sizes (diver's watches and strange specialty shapes will cost more).
May 16, 2011 | Skagen 358SSSD Wristwatch
Skagen watch band pins I've remove/changed spring pins other watches several times before but for this watch nothing happening How is it done?
they are very tough they have more pressure on them than most spring pins also on your watch they are tucked into the leather very well. the best way is with a spring tool apply quite a bit of pressure. a normal watch band will not fit this watch. it will only take skagen replacement bands.
http://www.skagen.com/service/home.fx
Jun 24, 2010 | Skagen Titanium Rectangle Watch Dial...
Inability to remove link segment from skagen watch
I finally found instructions at: http://emea.skagen.com/service/watchBandSizingChart.fx and was able to remove the links.
Mar 07, 2010 | Watches
I removed the back of my Skagen watch to replace the battery and cannot get it to snap back on.
you need a special tool to press the back back on. you should take it to a watch repair shop or send it into skagen to be repaired. it wont cost much if anything.
Dec 27, 2009 | Skagen Slimline Mesh 358SGS Wrist Watch
Skagen Model 433 LSX How do I remove links?
good afternoon ! you need a puncher pin to remove the pin ,just push the pin to releas and full the other side,be verry careful ! good luck !
Jun 27, 2008 | Skagen 355LGSC Wrist Watch
Removing back from Skagen 32LGQ watch
send it to skagen they can do any work necessary for a pretty low price and it will not void your lifetime warranty
Jun 10, 2008 | Skagen 355LGSC Wrist Watch
Skagen 433LSLB Watch Battery
If you take the watch to any jeweller they will be able to identify the battery type required - also they should be able to replace the seals, which are always worth replacing when a battery goes. Here is the link for contact with Skagen if you need it; http://www.skagen.com/service.asp Hope this helps :)
Mar 10, 2007 | Skagen 433LSLB Wrist Watch
Skagen 355LGSC Wrist Watch Logo
50 people viewed this question
Top Skagen Watches Experts
Jimmy Accardi
Gary Nitowski
Are you a Skagen Watch Expert? Answer questions, earn points and help others
