Question about GE 24 in. GSD3630Z Built-in Dishwasher
GE Nautilus Dishwasher Model GSD3630F00WW starts but doesn't complete washing
SOURCE: soap door latch won't latch close
Make sure the dial that you turn to start the dishwasher is all the way to the beginning. Sometimes my little grandson comes by and plays with it, turning it. I load, add soap and the dispenser won't close. I check the outside dial, and sure enough, set it to the very beginning and the dispenser locks in place!
Posted on Dec 28, 2007
SOURCE: GE Dishwasher Problem
Here is a link with solutions that for the water draining issue. http://www.myhomestyle.info/how-to-repair-your-dishwasher/
Posted on Apr 26, 2008
SOURCE: GE Nautilus dishwasher wont run
Thank you! Our dishwasher hasn't been working for so long. I've tried spinning the fan to get it unstuck a long time ago but I thought that wasn't the problem. The fan was stuck real tight and i couldn't turn it more than a quarter turn each time. This time it worked!
-Turned off power to dishwasher on circuit breaker
-Removed kick panel
-Used two screw drivers, one to turn the fan till I couldn't any more and the other one to hold the blades in place so that it wouldnt "unwind". Then I would turn the fan some more. It turned less and less each but after repeating about 5 times the fan got un-stuck.
-Turned the power back on to the dishwasher and turned the dishwasher back on and IT WORKS!
THANK YOU!!
Posted on Nov 09, 2008
  • 276 Answers
SOURCE: GE Nautilus GSD4200 Dishwasher will not wash/drain
If your dishwasher is cleaning poorly, check these:
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Step 1. Disconnect the dishwasher from its power source.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Step 2. Turn off the water supply to the dishwasher. This is usually underneath the kitchen sink or in the basement or crawlspace near the location of the dishwasher. Pliers may be helpful here.
Note: If there are no shut-off valves, you must shut the water off at the main water supply valve for your home.
Step 3. Remove the lower panel(s) of the dishwasher. These are usually held by 2 to 4 screws at the upper and lower corners of the panel(s).
The inlet valve is usually near the front of the dishwasher. Attached to the valve you’ll see: 2 or 4 wires, the water supply line from the house and the water feed line that goes to the dishwasher.
Step 4. Remove the household water supply line from the valve. The line is usually secured with a brass compression nut. The water supply line is usually copper or braided stainless steel.
CAUTION: Water supply line may be hot.
Step 5. Remove the fitting from the valve the water supply line was attached to. This fitting may be very difficult to remove. It may help to put the valve into a vice in order to remove the fitting. If you cannot remove it, replace it. The fitting is not an appliance part but a plumbing part that is available at most hardware stores.
Step 6. Remove the screws holding the valve to the dishwasher frame.
Step 7. Label the wires to the valve so you’ll be sure to reattach them correctly.
Step 8. Remove the wires from the valve.
Step 9. Remove the clamp on the black rubber water discharge tube and pull the tube off of the valve.
Step 10. Reinstall the old fitting (or a replacement fitting if necessary) onto the new valve the water supply line was attached to. Use Teflon tape or pipe joint compound as a thread sealant. Make this fitting tight to prevent leaks. Make sure that the fitting points in the same direction as the old one so that the water supply line will meet up with it properly.
Step 11. Install the new valve in the reverse order of the removal instructions.
Note: The water supply line is under high pressure. Be sure to tighten the fittings properly.
Step 12. Turn on the water to the machine, and check for and correct any leaks.
Step 13. Reinstall the access panel(s). Restore the power to the dishwasher and test.
Note: You may have to let the dishwasher run a few minutes before it reaches the next water fill cycle.
Internal filters Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Water temperature To get the best cleaning results, the water entering your dishwasher needs to be hot enough. Try running the hot water in your kitchen sink for about 30 seconds before starting the dishwasher, to pre-heat it. Also, if your dishwasher lets you select a higher wash or rinse temperature, try that to see if it helps.
To check the temperature of the hot water that comes from your kitchen faucet use a waterproof thermometer. If the water isn't 120 degrees Fahrenheit, your dishwasher may have trouble getting your dishes clean. You could increase the temperature of the hot water to the whole house--and therefore the dishwasher--by adjusting the hot water heater thermostat.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Detergent cup Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
Posted on Nov 19, 2008
whytfang
  • 170 Answers
SOURCE: GE Nautilus Dishwasher Start Problem (no water filling)
Model # should be on inside of tub wall....but any way...
This is a typical GE problem which I have seen many times...When a DW sets for a while not being used...the motor often freezes up....Take the front (lower panel off....find the motor assembly...(with the DW unplugged!!...very important)reach in with you hand or a screw driver...preferably your hand...at the back of the motor...there should be a impeller blade...you should be able to reach in with a finger and pull it down..it may be resistant so find a way to hold it in place as you reach up to the next impller blade and pull down further...finally it will all of a sudden free up....after which you plug it back in and start it up...I am also including a step by step (no drain problem check list as you may run into an issue like this if it has not been operated for a while ....notice article # 5).
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
I hope this helps...it is always useful to include the Model #...more specific instructions can then be provided
Good Luck and good day.....please rate my effort...the Fang
Posted on Mar 28, 2009
GE Nautilus dishwasher won't continue through cycle unless pressure is applied on door.
Hi, In reading about your dw problem, you are in need of a complete door switch assembly. You will need the full model number, and then find your nearest ge supply house to purchase the part. Hope this helps.
Jan 20, 2011 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus- model GSD3400G00WW. Why is there standing water after the dishwasher has completed it's cycle?
i won,t too buy a g.e. dish washer model.gsd3400g00ww where can i find this model and how much it cost.
Nov 10, 2010 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus dishwasher. Doesnt seem like motor is working
Dishwasher (Nautilus) not draining into sink but leaks onto floor.
Nov 10, 2009 | GE Nautilus 24" Built-in Dishwasher
Our Nautilus dishwasher won't turn on. I can hear a buzzing noise, but nothing is happening. Does anyone now what I should do?
The same thing happens with my dishwasher. I have made it work by doing the following. When you start up the cycle, turn the dial to just a tick before "start." If you hear the buzzing, but no water is running, unlock and then lock the dishwasher door again. This usually gets it running. If it's still not running water, unlock, advance the dial a little bit, and lock again. This should work. You need to be around for the early parts of the dishwashing cycle because this machine tends to stop up and buzz without running water until it gets past "short wash." Every time this happens, do the same thing, unlock and lock, and advance the dial a little when necessary. Once you get past "short wash," it should complete the wash without intervention.
Feb 22, 2009 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus Drain Problem
I had the same problem (water remaining in the bottom) after the rinse cycle. FYI my GE Nautilus is 7-years old.
(1) I disconnected the drain tube at the garbage disposal unit (in the sink) and, using a wire coat hangar freed a 'plug' of sludge located at the spot where the drain tube clamps onto the garbage disposal. I blew into the drainage tube to further clear other 'plugs' I observed but could not reach w/the coat hangar.
(2) I unscrewed the Filter/Strainer on the inside (bottom) of the dishwasher; and further removed the inner filter; cleaned both out.
(3) Re-ran the dishwasher thru complete wash/rinse cycles (to check for leaks. There were none.
Finally, upon completion of the w/r cycles there will always be a small pool of water (residing in the filter area). However my dishes are clean and (after 7-years) checking the drain tube and filters was a breeze.
Hope this helps
Jul 04, 2008 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus Soap does not dissolve
What is happening, is that your dishes are washing dry. Start the dishwasher and slowly turn the timer till it starts to fill. Let it go and see how they are after
Jun 20, 2008 | GE Nautilus 24" Built-in Dishwasher
GE NAUTILUS DISHWASHER
The pump motor may be stuck. If this is the case, as it often is with a GE dishwasher, you can break it loose (e.g. spin the impeller until it doesn't spring back any more). If it's not stuck, it may have something inside of the pump motor and it may need to be replaced.
Mar 25, 2008 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
GE Nautilus Dishwasher - NO water coming in at beginning
Normally,if water doesn't come in, cycle should not go on ! Add water by hand to tub and operate the dishwasher. Let us know with your results and we will see how could we assist you.
Aug 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
GE 24 in. GSD3630Z Built-in Dishwasher Logo
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
