Question about Russell Hobbs 14084 Iron
Russell hobbs steam force generator iron 14804 when you press steam trigger the steam only comes out when iron stood up when you lay iron flat to iron there is no steam, can you buy new trigger mechanism
SOURCE: Russel Hobbs iron: The element is ok, but the iron
maybe descaler needed the holes blocked limescale
Posted on Feb 10, 2011
caroldon
  • 17129 Answers
SOURCE: My Russell and Hobbs Professional
it is important to check the continuity of the coil as the power indicator is a neon and will show up as the power comes to the circuit. So what is required is to check if the coil or the thermostat control is defective and so does not heat.
If you can contact the Russell hobbs web site - support and post the part code of the set it will be traced to be under warranty and it is possible that you can get support for help...just in case the coil has opened.
Posted on Apr 01, 2011
heatman101
  • 43501 Answers
SOURCE: What is the best way
Here is a tip that will help you with cleaning the sole plate of your iron...
Cleaninga Steam Iron Soleplate
heatman101
Posted on Apr 02, 2011
caroldon
  • 17129 Answers
SOURCE: My russel hobbs iron is
This is a problem with the thermostat- possible that the bimetal is stuck or short or changed in alignment causing the power to be connected at all times and not cutting off.If you can remove the unit then this can be seen by checking the cut off of the control.
Posted on Jul 01, 2011
  • 244 Answers
SOURCE: The iron heats up, but when the steam generator
Chemicals and minerals in the water have probably clogged the vents. Empty the water. Pour 1/2 cup WHITE vinegar into the reservoir. Turn on your iron and let it heat. Then press the steam generator button several times until the vinegar is gone. Unplug the iron. As it is cooling, take acotton swab and gently wipe the surface of the vents. You can probe GENTLY with the swab, but don't push it into the vent or the cotton head may get stuck.
As you're pressing the steam button, keep the iron in the ironing position, not standing. If the vinegar just will not come out of the vents, use a wooden toothpick to loosen the build up.
This always works well for me and I hope it does for you.
If so, please come back to Fixya and rate my advice!
Posted on Jul 20, 2011
My Iron heats up but no steam comes out and no noise please help !! Russell Hobbs steam 2200
If the water used is hard it will build up with shale, and block the steam vents, best to flush with clean water after every second use . Best to take to the dealer and have it serviced .
Jul 10, 2015 | Russell Hobbs Irons
Lights come on when plugged in, doesn't heat up and has a beeping sound , colour panel is red thankyou
Read the operator's instructions. They are available of the Russell Hobbs site or by contacting Russell Hobbs UK on-line through the "Contact" link. In most cases, steam irons tend to clog with hard water deposits and need to be de-scaled from time to time. If that doesn't help you, buy a new iron. Rowenta's seem to perform best.
Apr 09, 2015 | Russell Hobbs Irons
No steam coming out of iron russell hobbs precision heat digit model14773
i know mine won't steam either unless you have the dial set to steam. not sure if your has the same set up but i thought it might help to offer the information
Jul 16, 2012 | Irons
I have so far seen 3 other people with the problem i have with my russell hobbs steam glide iron 13153. I have tried what was suggested to me but nothing has worked. the iron gets hot but no steam coming...
I would write to russell hobbs and complain, my friend bought one of these 18 months ago and hers got hot but no steam through. She sent it back to them and they sent her a new one as a gesture of goodwill.
Aug 04, 2011 | Russell Hobbs 13153 Iron
The iron heats up, but when the steam generator button is pressed no steam gets through at all.
Jul 20, 2011 | Russell Hobbs 13153 Iron
No steam from iron , is steam generator iron 12978 russel hobbs.Iron heats up ok.
check the dial is in steam position or maybe you may have build up in the line for the steam
Dec 13, 2009 | Irons
I have a Russell Hobbs Steam Generator iron - less than two years old. It has started to leak water - not really sure where it's coming from - it just pours out and eventually fuses the plug.
My Russel Hobbs Steamglide iron has stopped pumping steam , iron itself heats up but no steam...has the pump gone and can it be reapired
Oct 08, 2009 | Irons
Russell Hobbs Steamglide 2200.Iron and steam station seem to be heating correctly, but will not dispense steam when trigger on iron pressed.
is the water in your area heavy? it may have clogged your iron with stone. soak plate in something like clr .
Aug 10, 2009 | Irons
Russell Hobbs 14084 Iron Logo
51 people viewed this question
Top Russell Hobbs Irons Experts
Jim London
Jim London
AZBen
AZBen
richie46
Are you a Russell Hobbs Iron Expert? Answer questions, earn points and help others
