Question about Garden
Kubota ZD326S won't stay running after replacing the inner and outer air filters, the two inline fuel filters...still won't run for very long before the RPM's drop unless I put it into neutral.
SOURCE: 15 HP Kohler Engine RIding mower wont stay on
What's the gap setting between the coil and flywheel 15 hp kohler motor?
Posted on Aug 03, 2008
mighty thor
  • 51 Answers
SOURCE: Sputters & quits at proper RPM for engaging trans or mowing deck
If the choke has an adjustment point, then adjust the choke to a good overall working powerband. If it still doesn't act correctly, look for vacuum leaks. If it is an option, you may want to install a manually operated choke lever.
Posted on Nov 24, 2008
  • 78 Answers
SOURCE: Runs good for about an hour, then needs 15-30 minute rest period
When it's about to quit, quickly undo the gas cap. If it roars back to life, you have a vacuum problem, where the vents aren't letting air into the gas tank to replace the used fuel, so after a while, gravity isn't sufficient enough to pull gas from the tank until is sits and equalizes for a while.
Posted on Jun 30, 2009
  • 28 Answers
SOURCE: 07 gsxr 600 cuts out at 10,000 rpm drops suddenly
chech side stand swich
Posted on Aug 23, 2009
SOURCE: craftsman lt 1000 wont stay running
Take a paperclip and clean out the small hole on your gas cap. And yes I am being serious.
Posted on Aug 25, 2009
Car won't stay running
did you give it a tune up change plugs fuel filter
Feb 17, 2013 | 1987 Oldsmobile Toronado
Car starts but won't stay running
Check on your inline fuel filter. If this clogged the fuel pump cannot pump gas through it to get to motor.
Jan 01, 2013 | 2003 Ford Focus
Replaced all fuel lines and pickup fuel filter. but won't stay running without choke.
Take the carburetor off and clean it and check and replace any air filters you may have. Can't say that this will fix it ,but it is a starting point for you. Hope it works and good luck.
Dec 01, 2012 | Poulan P3416 16Inch 34cc 2Cycle Gas...
I have a husqvarna 4623 zero turn and when I would pull up the pto the mower would die. I replaced the fuel filter and now it won't even stay running
Most likely the battery isn't holding enough charge which is why the PTO won't engage.
Likely you have air in the fuel line/fuel filter which lets it run for awhile then it fuel starves.
Oct 30, 2012 | Husqvarna Garden
2002 ford escort zx2 replaced fuel filter, air filter, plugs, and MAS...why won't it stay running?
it could be down to your spark plug leads take the leads out one by one and get somebody to hold the lead to the engine [to earth it] NOT WITH YOUR HAND with something thats not conductive like something plastic then try starting the engine to see if a spark jumps from the lead and repeat this please dont do this with your hand its very dangerous enouf voltage to knock you out!
Aug 06, 2012 | 2002 Ford ZX2
Won't stay running. its like its starving for fuel
REPLACE FUEL FILTER AND AIR FILTER, FIRST.IF ENGINE STILL WONT STAY RUNNING COULD BE FAULTY FUEL PUMP.CLOGGED FUEL INJECTORS.
Jul 10, 2011 | 1990 Chrysler New Yorker
Diesel engine, grey market kubota, the turqouise
yes there is a low pressure pump and a high pressure(incjector pump) if your no getting fuel to engine check for low pressure pump to be working may also have air in system which is very hard to get out and a diesel wont run untill most or all air is gone
Sep 05, 2009 | 1984 Dodge Caravan
My Toro lawn mower (Tecumseh engine) is quitting on me.
defective check valve pull the tank and remove the fuel line replace the small inline filter on hose.
May 24, 2009 | Garden
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
