Question about Dryers
Not drying clothes or catching lint
My Maytag electric Centennial dryer is not drying clothes or catching lint. It is heating up and spinning but nothing else. I checked the vent hose and outside...all is secure and nothing is blocking the airway. HELP!!!
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
Hi Diane, You have 1 of 3 Problems. Either your 1. Heating element is bad 2. Thermal fuse is bad or 3 Your timer is out of wack.
Posted on Oct 12, 2013
4 Suggested Answers
  • 6 Answers
SOURCE: AMANA LEA60AW ELECTRIC DRYER, DOES NOT DRY CLOTHES FULLY
Your heating element is dying. A new element runs 'bout $40. It'san easy fix. Couple screws .
Posted on Apr 25, 2009
SOURCE: Bosch Dryer doesn't dry clothes
With the dryer not connect to the external venting turn the dryer on and see if there is air coming out ot the vent from the dryer. Is this flow of air strong or weak?
If weak then there could be a problem inside the dryer some where. Perhaps the fan is not operating properly. Just my thoughts.
You say you have check the beginning and end of the duck vent pipe. How about seeing if it venting duct is clear from one end to the other.
Good luck
Posted on Jun 11, 2009
iwillfixforu
  • 619 Answers
SOURCE: My maytag centennial dryer is getting too hot and
Exhaust problems are the only thing that will cause this. Check to make sure the exhaust behind the dryer is going straight out without alot of bends. Also no exhaust should be over 20 ft to the outside. Ther is a tip on how to clear house exhaust in the tips section. Just type dryer to long to dry and should take you there.
Posted on Jun 02, 2010
Our Maytag Centennial Electric dryer is not cycling in auto dry mode but will in timer mode. Any thoughts?
There is a sensor that the clothes have to touch when the drum spins. This sensor measures how wet the clothes are. If you don't have enough of a load in the dryer then the sensor wont detect the dryness. Or it could be a bad sensor or connection or main board.
Nov 02, 2015 | Maytag Centennial 7.0 Cu. Ft. Super...
Maytag Centennial Dryer (MEDC400VW) not drying properly
First of all, please make sure the vent is clear all the way through. Next the vent must be straight as possible. Next it can not be to long. People think that because they feel the air outside the vent is clear, not always true. The vent can be partially clogged. So make sure. Next, if the vent hose has sags or bows and even tight turns. It can accumulate the moisture in it from the drying proceed. If water has collected in the vent hose the clothes will not dry properly. If the vent is to long it can not dry properly either, the blower on the dryer can only move air so far. So the shorter the better. If all of these requirements are meet. Then, I would have to start checking the thermostats. I hope I have helped you. Please respond if you need further assistance.
Jan 29, 2014 | Maytag Dryers
Not catching lint or drying clothes
Hi Diane
Sounds like you have a clogged vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
Bud
Oct 12, 2013 | Maytag Dryers
CLOTHES WONT DRY. IT GETS REALLY HOT INSIDE. THEY SEEM WETTER AFTER IT RUNS FOR AWHILE. TAKES PROLLY 3 HRS TO DRY.
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
May 22, 2011 | Maytag Centennial 7.0 Cu. Ft. Super...
My maytag centennial dryer is getting too hot and not drying my clothes. I always empty the lint trap, and have checked the vent going outside. The airflow seems to come out fine, but the air is too hot...
May 31, 2010 | Maytag Centennial 7.0 Cu. Ft. Super...
Dryer is heating but clothes are not drying.
Judging by the increasing moisture, your dryer vent is not venting the moisture to the outside. Check your vent pipe for blockages. I had a person a while back with a similar problem, and this person had a lint trap on the connection that went to the exterior of their house, so check that out as well.
May 08, 2010 | Maytag Centennial 7.0 Cu. Ft. Super...
Brand new Maytag Centennial electric dryer does not dry clothes!
It may have shipping damage, such as a loose or broken connection or heating element.
But if it's brand new, it's under warranty, and they will fix it free.
You can find your nearest Maytag-authorized servicer here.
Jan 09, 2010 | Maytag Appliances Over-the-Range Microwave...
Dryers Logo
64 people viewed this question
Top Dryers Experts
