I tried to reinstall windows xp and it says no hard drives installed
    Sergeant:
  • 252 Answers
Your Hard drive is not detecting. Need to check the laptop by the service center.
Posted on Oct 12, 2013
4 Suggested Answers
Shayna
  • 64 Answers
SOURCE: reinstalling windows xp on a new hard drive - Thinkpad t30
If you can get your hands on a Windows XP cd, it will partition and format the drive for you allowing you to install from scratch. You would then just plug in the license key from the sticker on your laptop. As far as the recovery disk on the original CD, there might be an option on bootup that would have you push an F key to access it. Or you can usually order them online. It's not too hard to get the drivers you need from online so I would just go with any XP disk you can get your hands on. You'll be using your own license so you can even borrow one.
Posted on Mar 28, 2007
  • 298 Answers
SOURCE: Replaced hard drive in Toshiba Tecra M9. Laptop.now refuses to re
Look on the back edge of your old HDD where all the gold pins are and on one side there is a group of 4 pins in two rows of two... and see if there is a tiny jumper installed across two of them (white or black about 1/8" tall and 1/16th wide).
Now look on the new HDD and see if there is one there. The NEW HDD must be set up exactly like the OLD one or it won't be detected by BIOS or Windows.
I am beginning to think your LT has the CD as MASTER and the HDD as SLAVE, which may require adding or removing a jumper. Some new ones come with, some without ;-) I didn't think of this earlier
Check that. Email me the result
Posted on Mar 27, 2009
fredtmccoyjr
  • 380 Answers
SOURCE: Dell inspiron 1721 hard drive not recognized for Vista reinstall
ok, theres a small issue with the raid controller. You have to install a 3rd party raid driver (its on the dell cd) to continue, OR, you can set that BIOS's hard drive controls to ATA or LEGACY (legacy would likely work best, but youd have no 'raid' functions, but who sets up raid drives on a notebook?). Your last option is use the dell discs to restore, and inssert the windws disc when prompted
Posted on Nov 05, 2009
Testimonial: "Thank you so much! It didn't have a option for Legacy, but only RAID and ATA. But it's working!! You are super awesome!! Thank you!!!"
Missing or corrupted system 32 wont install off windows xp disk
try going to the bios and change the boot sequence for hard drive to cd
put the copy of xp in the external hard drive and reboot the computer
when it powers up it should boot up off the external hard drive
if that works go to computer --device manager and find recovery section
you may also go restore to a previous date and try for a fix from there
go google and get to microsoft and find that file download for xp and install it
if all that works shut the computer down and reboot back to bios and change back to reboot from hard drive
remove the disc from the external hard drive
Mar 13, 2017 | Compaq Mini 110c-1001NR Notebook
Pavillion P6000 won't recognize any drives
If you are trying to install Windows XP then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Jun 15, 2012 | HP Computers & Internet
Compaq presario 1630 wont install chipset
Hello,Is this the same version of windows you had installed prior to the reinstall? the 1630 is an older laptop and shipped with small hard drives and preloaded with windows 98. Windows XP is much larger than 98 and therefore using all of your hard drive space. Are you able to go to click "my computer" and click on c drive and see how much disk space is left?
Nov 17, 2011 | Computers & Internet
I HAVE MSI NETBOOK WITH window xp installed on it but it is not working (window xp) and i can,t reinstall or recover window pls help me
USING THE Installer of your XP installer to portable dvd drive it still not working to reinstall the windows. the problem of your msi netbook is the hard drive. may sulotion for that. used desktop CPU and put the harddrive of your msi and into the CPU of desktop. then Checkdisk your hard drive.
and after that finish the checkdisk. get your hard drive and put again to your netbook. and try to reinstall then XP.
thnx i hope am i share my knowlage
Jan 20, 2011 | MSI Wind U123-002US Netbook
I needed to format my harddisk. How do I get my windows XP reinstalled. I have windows product key number. I also have Compaq (pressario) product and serial numbers. Any hints?
Reinstall Windows XP loadTOCNode(2, 'moreinformation'); To reinstall Windows XP, try either of the following methods. If the first method does not work, try the second.
Note You may want to disconnect from the Internet during the installation. This helps protect you from malicious users. Start the reinstallation from Windows XP loadTOCNode(3, 'moreinformation'); To reinstall Windows XP by using Windows XP CD, follow these steps:
  1. Start your computer.
  2. Insert the Windows XP CD in your computer's CD drive or DVD drive.
  3. On the Welcome to Windows XP page, click Install Windows XP.
  4. On the Welcome to Windows Setup page, click Upgrade (Recommended) in the Installation Type box (if it is not already selected), and then click Next.
  5. On the License Agreement page, click I accept this agreement, and then click Next.
  6. On the Your Product Key page, type the 25-character product key in the Product key boxes, and then click Next.
  7. On the Get Updated Setup Files page, select the option that you want, and then click Next.
  8. Follow the instructions that appear on the screen to reinstall Windows XP.
If you successfully completed the reinstallation, congratulations. You are almost done. Please continue to the "After you reinstall Windows XP" section to finish.
Method 2: Repair install of Windows XP by starting your computer from the Windows XP CD loadTOCNode(3, 'moreinformation'); Note If Windows XP was preinstalled on your computer, you may need the installation CD to reinstall. Contact your computer manufacturer to make sure that you have the installation CD for a repair installation.
To reinstall Windows XP by starting your computer from the Windows XP CD, follow these steps:
  1. Insert the Windows XP CD into your computer's CD drive or DVD drive, and then restart your computer.
  2. When you receive the "Press any key to boot from CD" message on the screen, press a key to start your computer from the Windows XP CD.
  3. The following message on the Welcome to Setup screen will appear: This portion of the Setup program prepares Microsoft Windows XP to run on your computer: To setup Windows XP now, press ENTER. To repair a Windows XP installation by using Recovery Console, press R. To quit Setup without installing Windows XP, press F3.
  4. Press ENTER to set up Windows XP.
  5. On the Windows XP Licensing Agreement screen, press F8 to agree to the license agreement.
  6. Make sure that your current installation of Windows XP is selected in the box, and then press R to repair Windows XP.
  7. Follow the instructions that appear on the screen to reinstall Windows XP. After you repair Windows XP, you may have to reactivate your copy of Windows XP. For more information, click the following article number to view the article in the Microsoft Knowledge Base: 310064 (http://support.microsoft.com/kb/310064/ ) How to troubleshoot Windows XP Setup problems when you upgrade from Windows 98 or Windows Millennium Edition.
Hope this helps.
Dec 28, 2010 | HP Computers & Internet
Error "Setup didn't find HDD"
Well, first of all XP is not the latest supported operating system from Microsoft.
That being said, I have not had a garbled screen followed by an error message 'setup didn't find any hard disk drive installed' on a laptop, in my limited experience with laptops (i.e. Acer One, Acer Aspire, Sony Vaio, etc.)
If you have an unexpected garbled screen it points to the pc board or mother board or the video card, but more likely the motherboard.
And, if you couple this with the hard disk drive not being detected, it reminds me of a situation where I had a no hard disk drive detected on a SCSI drive connected to my Windows 95 computer in the 1990s when I had heat related issues with the circuitry on the hard drive getting burnt out capacitors.
If the drive is not recognized, it might mean the boot sector is wiped, and essentially it needs to be reformatted and the operating system needs to be reinstalled (which you evidently tried to do).
To my memory, I never had this problem on Windows XP with a laptop, so I am thinking it's not Windows that is at fault, but the physical hardware is giving you problems.
If you boot from the CD for Windows XP and it doesn't find the drive, it's a big problem for this laptop.
I wish you luck in finding an answer to that one, seeing that it's out of warranty and XP is no longer supported by Microsoft.com.
Jul 19, 2010 | Fujitsu Siemens AMILO Pro V2000 Notebook
Can't install OEM Windows XP on fresh hard disk
please check the consistancy of hard drive or try to run a zero format first and then reinstall the win
Apr 15, 2009 | Computers & Internet
Foxconn sound card drivers
same problem
I formatted my hard drive and reinstall windows xp but no sound comes from speakers I tried to install audio drivers from the motherboard CD "foxconn" but PCI driver can not be installed what should i do?
Apr 07, 2008 | Intel Frontier Design Dakota 24-Bit PCI...
Windows xp Install
First make sure the hard drive is reconogized in the BIO's, then do a clean install of XP choosing to delete the existing partition and install into the undefined space. choose to format the drive NTFS. if it still fails after this, sounds like you will need to replace the hard drive. Also the CPU speed will need to be at least 700 mhz for XP to work correctly but a higher mhz is all ways better. BPCS
Dec 29, 2007 | Compaq Presario 7594 PC Desktop
Hard disk not recognized when reinstalling xp
try formating the drive using fdisk in fat32, you can find this program in windows 98/98se and Me them try instaling windows xp
Nov 10, 2007 | Compaq Pentium 4 , 1.5 GHz (244318-B21)...
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
