Question about Toshiba Satellite 15" Flat Panel LCD Monitor
Turning on issue
Will satellite 1415 laptop work with battery pack removed and just AC Adapter used?
    Sergeant:
  • 268 Answers
Yes it will work, just make sure you remove the battery when the computer is shutdown and unplugged.
Plug it back in after the removal and you should be good to go!
I do that with all of my laptops because they are usually on 24/7 and I don't want to beat up the battery life with the constant charge.
Posted on Apr 23, 2009
Dell latitude 610 AC adapter issue or battery pack issue or both?
It could possibly be the power jack that is inside the computer. This item is typically soldered onto the motherboard and it is what your ac adapter plugs into.
Dec 21, 2007 | Twinhead SlimNote N12PI Notebook PC
Medion MD 98200 My laptop will not turn on after my son removed the battery pack accidentally
Turn on the laptop without the battery, using only the AC adapter. If doesn't work remove the AC Adapter and battery. Hold down the power button for 30-45 seconds then plugged in the AC Adapter and put battery back in then [on]
Apr 11, 2013 | Computers & Internet
My Toshiba Satellite M65-S809 Laptop will not turn on! However it turns on randomly sometimes when i toy around with it, but that happens rarely. I tried removing battery, and cable to take out the static,...
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Sep 18, 2011 | Toshiba Satellite M65-S809 Notebook
My toshiba satellite series a135-s4656 laptop stopped charging for over two weeks now. Though the adapter (power pack) is functional. Please what do i do (cos the system has been down since)?
How do you know the ac adapter is working? Just because the light on the ac adapter is on doesn't mean it's working. Does it work with the ac adapter plugged in? Just not charging the battery. If in the first case just buy a new ac adapter and see if it works, most are affordable some not so much. If the battery isn't charging then you will have to shop for a new battery. If both of those are good then you have either a bad ac plug on your laptop, or motherboard issues. Hope this helps, if you have more questions just reply and I will try to help.
Aug 01, 2011 | Toshiba Computers & Internet
I have a Toshiba Satellite A135-S4527 and it will not turn on. I checked the AC adapter and I am getting 19 Volts and my laptop shows that i have power going to the laptop but yet it will not turn on.
Welcome to Fixya.
It seems like you are experiencing a "No power/no post" issue on your laptop, here are my recommendations :
  • Disconnect everything attached to your laptop (USB cables, etc)
  • Disconnect the ac adapter
  • Carefully remove the laptop's battery
  • Press and hold down on the power button for at least 10 seconds
  • Connect the ac adapter to laptop without the battery and turn it on
  • If this works, return the battery to the laptop and try it again with the ac adapter
If none of the above procedure works, then the laptop needs to be serviced. I've included Toshiba's support contacts below for your further reference :
Toshiba Support
Hope this helps and Thanks for using Fixya.
Jan 22, 2011 | Toshiba Satellite A135-S4527 Notebook
When i hit the power button the light comes on and then goes off. even if the power pack is used or the battery
1. Disconnect the ac adapter and remove the battery from the laptop.
2. Press and hold the power button for 30 seconds
3. replace the battery and connect the ac adapter
4. turn on the laptop
this should resolve the issue.
if the issue persists, remove and replace the memory modules and check for the issue.
if the issue persists, then the issue could be with the hardware malfunctioning of the notebook.
Jun 17, 2010 | Compaq Presario CQ60-212US Notebook
Toshiba satellite m55-s135 won't power on even when plugged in
When the AC adapter is plugged to the wall, if it has an LED make sure it is on, remove the battery and connect the adapter to the laptop, does it power up?
Install the battery after charging, see if your laptop powers up.
If the laptop does not power up, the motherboard needs replacing.
I hope this helps to resolve your issue.
Good Luck.
Mar 15, 2009 | Toshiba Satellite M55-S135 Notebook
Toshiba satelite A100 rejects AC... often.
Just to humor me, are you using any peripherals with your laptop when this happens, such as a wireless mouse, USB connections such as digital cameras? Try to take these away when recharging.
There seems to be 2 issues here.
1) Recharing batteries: To prepare the batteries for long-term use (I do not know how long you've had the batteries...try draining the batteries (both of them), and then recharging it to full 2x before using them without the AC Adapter. This should clear the problem.
2) AC Adapter only works every other day: When you swapped the power pack, was it with a new AC adapter, or another used one? Also, have you tried using a different outlet than the one you normally use? Let me know how this turns out.
Nov 17, 2008 | Toshiba Satellite A100-S8111TD Notebook
Not boot from factory CD -where is CMOS battery?
Appreciate the direct "Ask Me".
Based on your post/description:
  • Toshiba Satellite 1415-S173;
  • new HDD;
  • would install WinXP.
Your concerns are:
  • media/cable fault;
  • CMOS battery;
  • laptop battery.
  • will not complete format;
  • will not install OS (WinXP).
Proposed course of action and other ideas:
  1. double check the new HDD, verify that the pins are not bent and are seated correctly. If all else fails, return the new HDD and have it replaced;
  2. try partitioning/formatting the new HDD in another PC using a 2.5 IDE to USB external adapter;
  3. clean the lens of the DVD/CD ROM drive;
  4. remove the dead laptop battery and use only the AC power when installing;
  5. most current laptops do not use a CMOS battery;
  6. if you want to revert CMOS/BIOS settings to default, it could be done by pressing on ESC or F1 or as indicated in the display (depends on the version) and set all possible settings to default. Verify that it is set to boot from the CD drive.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 02, 2008 | Toshiba Satellite 1415-S173 Notebook
Toshiba Satellite 15" Flat Panel LCD Monitor Logo
74 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
