Question about Ovens
Kenmore built-in oven mod #C970-417757 :there is nothing lighted on led display ;nothing works ;there is power going to the pcb board;what could be the problem
  • 10 Answers
SOURCE: AEG Oven
try setting the clock, it may be automatic
Posted on Mar 22, 2008
  • 13433 Answers
SOURCE: OVEN BLACK-OUT!
Read this troubleshooting page, it may provide you with a solution to the problem.
http://www.repairclinic.com/0088_13_1.asp
Posted on Aug 03, 2008
docjohn174
  • 943 Answers
SOURCE: kenmore model c970-655632 LED Display is very dim
hi joe. thanks for the question . you replace the clock to repair your problem . i have seen this happen on a regular basis . thanks the appliance doc
Posted on Oct 05, 2008
localwonder
  • 6784 Answers
SOURCE: after self cleaning,i noticed the lock light blinking,the door opens but when i try to use the oven dr is displayed on the screen and nothing functions. (Kenmore warm and ready drawer-self cleaning ov
This is a Door lock malfunction. you will need to replace the door lock mechanism. it is faulty.
Test the door lock mech for its operational value to be sure.if the door mech test is good, replace the control(ERC/Clock)
Posted on Jun 03, 2009
  • 574 Answers
SOURCE: my kenmore oven's led display works, but will not heat
pull stove out and check the volts either on the plug or terminal block on the stove where the wires are terminated. check the terminals marked L or line at the same time should have 240 volts if not your breaker which probably is a 40amp will need replacing
Posted on Sep 01, 2009
Faulty lights and timer bleeper on neon clock display on front of electric oven.
It is very possible the control board is going bad. Before replaceing the control board pull the connectors and reinstall them. There could be a bad connection causing the display not to lioght up completly. If that doesn't work then it looks like control board time.
Nov 17, 2014 | Stoves 720EF Electric Double Oven
Display is dim
Hello Friends! This dimming vacuum display is either caused by a power supply failure with the control board, or a the filaments of the display themselves have started to wear-- similar to that of a bad light bulb. Either way, FixYourBoard.com can solve this problem. Contact them 512-355-1108 for more information. The photo below is from a double oven, but we repair single oven displays too.
Jan 16, 2013 | DCS WOS-227 Electric Double Oven
Where can I purchase a new LED display for my thermadour built in oven?
Welcome to FixYa.
The issue with these displays is they can lose their intensity over time, but also it can be contributed to the main control...specifically the transformer on the "C" series ovens, hence the only remedy is to replace the control/display kit.
I'd first suggest checking the main control if you feel you are capable, this is how...
1) Turn the breaker or power supply to the oven off while servicing...saferty first ( though you will need power to check the transformer, this is where an experienced tech may be necessary, you'll need to decide )
2) locate the control board behind the display ( this will require either moving the front panel or the top panel behind the display...in the plenum )
i.e.
Then identify the PCB/control board...
The large arrow identifies the main control, the small arrow is the transformer location on the board
3) Remove the control or place it at a vantage point you can perform the following voltage checks, this is where some experience or electrical knowledge comes in handy...
i.e.
If the values listed in the test chart all are o.k. then you need a display only...if not you'll need the control board. ( Before you ask, I don't know of any transformer supplier...but then you're gambling nothing else is defective on the control anyway, not worth it in my opinion, that's your call )
Now to answer your question about availability though, one can find these "display's" at "repairclinic.com" for around $225USD and includes what I've attached here...
The "PCB" or control as it is referred to as well is also available at said location for around $175USD, it will include this...
Hope this helps move you forward. Let me know if I can assist you further and good luck.
Regards,
Macmarkus :)
Dec 31, 2010 | Thermador C301U Electric Single Oven
We have a Kenmore electric range mod. C970-440732. We have 5b or 56 error code on each element display control and 5ab error code on temp display on the the control panel. Nothing work except the clock. ...
Sorry to read about your problem, I hope this helps you out.
I am going to assume it a F5 error code, which means your have a oven control failure. and may need replacement. electronic oven control (also called EOC or clock).
I suggest you contact a service company.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 26, 2010 | Kenmore Ovens
The led display lights have dimmed so much I can't read the. THis is a built in double oven - Kenmore. not sure of the model #
you will need the model # to get the correct control panel for this range . the display has failed and ony repair is to replace it . part # may be on control . and inside the control area there should be a tec sheet with this info .. mm hope this helped ..
Jul 11, 2010 | Kenmore Ovens
Our home has a Whirlpool Gold built-in convection oven. The home is @5 years old. We've lived here for one year. Today, the display had an error message (E6). After we cleared the error message, the...
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty.
GBD RBD Whirlpool Oven Problems Causes and Solutions
Apr 21, 2017 | Whirlpool GBD307PD Electric Double Oven
Kenmore model c970-655632 LED Display is very dim
Oct 05, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
LED FRROZEN
Sounds like you have a need for a circuit board. First, disconnect power for a few minutes and re-power. If that doesn't fix it, get a new board. Turn off power before working on your unit.
Dec 05, 2007 | Dacor ECS127 Epicure Stainless Steel...
Zanussi ZBQ 965(X) Built-in Oven
Sounds to like the oven element has gone, the red light indicates that power is going to your thermostat o/k.
Check the oven element.
Nov 16, 2007 | Zanussi ZBQ665 Electric Single Oven
Display doesn't work, but oven works
First turn the electricity off by locating the breaker to the oven and turn it off. Now wait for an hour or so and turn the breaker back on, if the display turned back on, you need a control board (other manufatures call it a clock, PCB or ECC but it's the main elctronic board with the diaplay built in). If it didn't come back on, turn the power off again and make sure all the wire harness's going to the board are connected good. Turn the power back on and it the display still doesn;t come back on you need to replace the main electronic control board. By the way double check the model number and brand because it might be wrong. Please post back.
Oct 04, 2006 | Whirlpool RBD275PD Electric Double Oven
Ovens Logo
80 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
