Question about D-Link AirPlus DI-524 Wireless Router
Slow connection the d-link router's lights are flashing all the time. Our ISP said the d-link is faultyand that this is the reason the service is slow and that we have trouble connecting. Is there anything troubleshooting I can do to correct this problem?
If your using terayon cable modem change it to thompson
Posted on Sep 25, 2007
  • 49 Answers
Router needs firmware upgrade. Call dlink for support or you can check their website for possible downloads (firmware). It is also possible that there are configurations on the router that has not been properly set.
Posted on Sep 29, 2007
SOURCE:
Slow connection
your internet may be slow due to following reasons
- Your ISP (internet service provider) may be having issues with routing signals to you.
- Your browser memory cache is so full, your browser has to slow down to allow for its limited hard drive space.
- You might have spyware/malware infecting your machine, and secretly using your Internet bandwidth.
So You need to optimize browsers and internet connection.
- First of all update the browser
- Disabling The Firewall
- Remove unwanted tool-bars and plug-ins
- clear temp files
- Deactivate background running services
If you are unable to perform above tasks then use a single utility tool like PC Fresher that will not only fix windows errors but will also optimize Internet
Sep 16, 2013 | D-Link DIR-600L Wireless N150 Cloud Router
No light only power light is on...
First, did you pay the bill? Unplug the IPS modem, remove battery, if applicable, unplug TP Link, shut down computer. Ckeck ALL cables reseat, Replace battery, plug in ISP modem, allow it to selftest, plug in TP Link, allow it to selftest, Reboot computer. If you connect ISP Modem directly to PC and it doesn't ID your IP address use this: http://helpdeskgeek.com/networking/release-and-renew-an-ip-address/ To assist you. If this doesn't work contact your ISP provider . Try another Wireless Access Point. My ISP, Xfinity, drops from time to time , for no appearent reason, due to a number of outside difficulties.
Dec 14, 2012 | TP-LINK TPLink Tp link Tl wr940n 300mbps...
I have attached my DI-524UP to a new modem but now I can not use the internet. the wireless is working as it conecets but the internet is not connected. The lights are flashing on the front of the unit...
Your D-Link DI-24UP needs to "log into" your ISP's network again - by switching it to a new
(DSL? cable?) modem, your router lost its "login" with the ISP.
Solution: power cycle the router. This will force it to log back into your ISP's network, at which
time you'll have to supply (probably manually), your account name and password that your account
has with your ISP.
Jul 20, 2011 | D-Link Computers & Internet
I installed the wifi router 3 days back. Had some initial problems which i solved using the books in kit. However, speed was very slow. Next afternoon, speed suddenly picked up. It was perfectly fine...
Hello Ahmed,
This may have nothing at all to do with your router, but may be associated with your modem, or cable connections inside and outside the home, or even your ISP.
I recommend you check with your ISP for a service visit to ensure all is working according to specifications.
Feb 14, 2018 | TP-LINK TPLink Tp link Tl wr940n 300mbps...
I restet my linsky wireless adapter and all i get is a flashing blue power light
The flashing blue light is absolutely normal!!! Please follow these steps to configure your computers to your wireless router
Here are the recommended steps to connect to a wireless base router 1. Check and remove power from both your router and the DSL ROUTER/CABLE ROUTER MODEM 2. Wait one complete minute until applying power to modem then wait one minute before applying power to wireless router. 3. Ensure you have green lights across both devices, specifically, the recieved and sent lights. These same lights will tend to blink rapidly when there is active data, at times this will still blink, and a DNS error will prevent you from connecting to the internet. If this is the case, call your ISP Internet service provider 4. Check your authentication Security key on your router first, then check all your wireless devices to ensure they are on the same network name, key, and channel with the same type of encryption as the router 5. Start one device at a time and check for connectivity, if your still experiencing a problem, check the settings on all your wireless adapters, device drivers, internet browser settings, firewalls and proceed. 6. still have problems, connect a rj45 cable from the router directly to your computer to at least see if your wireless settings are bad or if the router may be bad. 7. Contact your ISP to determine if your receiving singal 8. Avoid using a splitter or parital power backup for yours routers 9. Still having problems, change your wireless router only after your ISP changes their faulty modem 10.Attempt the same process when setting up your new wireless router and or modem
Jan 20, 2011 | Linksys E3000 Wireless Router
After a power outage, I have no wireless connectability.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jul 13, 2010 | D-Link AirPlus DI-524 Wireless Router
Drops connection
1. Your router may have lost the IP address from the ISP (Internet Service Provider)
2. go into the router using the 192.168.0.1 IP address to check the status of the router. This will tell you if you have lost connection with the service provider.
3. Call your ISP to verify connectivity. There may have been a line interruption.
4. check with the router manufacturer for router firmware updates.
5. If your router is older it may be at what is call "end- of - life" and may longer be serviceable by the manufacturer.
6. You also may want to try moving the router to a spot away from electronic devices such as TV'S, cell phone, cordless phone bases, and microwave ovens. These device send signal that are on the same frequency as the router and may have an affect on your connectivty. This also may account for connectivity drops.
May 15, 2010 | D-Link AirPlus DI-524 Wireless Router
I connected everything properly followed the instructions and the interney indicator light keeps flashing and wont connect is the router broken?
maybe..did you call your ISP(Internet Service Providor) and ensure your getting a connection. You can also connect your puter to the net, through modem, to ensure that net connection is valid.
Dec 01, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
TP LINK MODEN ROUTER ADSL2 PROBLEM
If the PPP LED is flashing all the time then you have not got a connection to your ISP's server.
Have you contacted your ISP?
The ISP can test the ADSL connection to the your ADSL2 modem and advise whether it is a fault or not..
Sep 17, 2009 | Computers & Internet
Blinking lights on Belkin F5D7632-4
Check out with ISP Service provider and speed of your internet
Dec 17, 2008 | Belkin (F5D7230-4) Router (587009)
D-Link AirPlus DI-524 Wireless Router Logo
313 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
