Question about Black & Decker SpaceMaker ODC325 Coffee Maker
Filter basket makers
I need a white filter basket and coffee carafe for my ODC325 Coffee Maker
  • 30 Answers
SOURCE: Black & Decker Spacemaker ODC325 Coffee Maker
You can find them on ebay from time to time. One went for $25 last week and there's one there now for $50, which is steep for a used unit, but if that's all that will fit then it's worth the price. A reviewer on another site suggested second hand stores as being a good source for these as well. Good luck!
Posted on Mar 29, 2008
  • 30 Answers
SOURCE: odc325
I haven't been able to find the base heating element for sale anymore. Best I can suggest is finding one on ebay that still has a working base heater but the water heater no longer works.
Posted on Jun 26, 2008
SOURCE: Coffee Maker Model CM1010B Carafe spills when pouring
Solved the problem by taking it back to retailer..
Posted on Jan 06, 2010
  • 30 Answers
SOURCE: Cracked Water Reservoir, need replacement for my
I can get one for you. Contact me offline.
Posted on Jan 09, 2010
lmmuresan
  • 131 Answers
SOURCE: I need a new complete
Often there are hard-to-find Black & Decker Spacemaker coffee maker parts here, and as of right now, the sneak-a-cup valve is in stock: http://stores.ebay.com/Lauras-Last-Ditch/_i.html?_nkw=black+decker+spacemaker&submit=Search&_sid=93311479
Posted on Sep 13, 2010
Cleaning the coffee maker
Cleaning a coffee maker is simple.
Fill the carafe with 9-10 cups of Water and 1 cup drain cleaner.
Put a paper filter in the basket. Run the cycle. You will see lots of garbage in the carafe. Repeat with the same water.
Next dump the water into the sink and refill the carafe with fresh water.
Run again, several times to flush out the acid. remove the basket and scrub it clean. Your coffee maker should run like new.
Jan 30, 2014 | Rival Programmable 12-Cup Coffee Maker
Black and decker coffee maker - water pools in coffee filter
Be sure the carafe is pushed all the way back. It must push the lever on the back of the machine in order to open the valve on the filter holder
Mar 20, 2012 | Black & Decker SpaceMaker ODC325 Coffee...
Will not process the water to make coffee
the coffe maker might be clogged up so here' what to do: Look through the clear plastic panel on the side of the coffee maker's water tank to make sure that it has water in it.
  • Clean your Sunbeam coffee maker, You can wash the removable filter basket and carafe in hot, soapy water and pour 4 cups of white vinegar into the water reservoir of your coffee maker. Start the brewing cycle with no coffee grounds to allow the vinegar to clean the inside of the coffee maker. Rinse away the vinegar by running the brewing cycle twice with only clean, fresh water.
  • 8 Check the removable filter basket to see if the filter has collapsed if you find coffee grounds in your brewed coffee. If the paper filters collapse often you can wet them before you place them inside the filter basket so that they will stick to the basket and stay in place. or check this link because it might need a new hose. Coffeemaker Sparepartswww.coffeemaker-spareparts.
  • Jun 12, 2011 | Sunbeam COFFEEMAKER 10C BLACK DR13
    The coffee will go all over the counter. We did not get a manual with the coffee maker. Could I possibly be setting the pot incorrectly on the plate?
    Check the following:
    1. Make sure that you are using the correct size coffee filter in the basket. Only one filter is needed to allow proper drainage.
    2. Check the spring loaded button on the bottom of the coffee basket. Remove the basket, put some water in the basket, push the button up to make sure the water is released from the basket.
    3. Put the basket back in place, insert the carafe and check to make sure that the top of the carafe cover pushes up the button on the basket to release brewing coffee.
    If all these check out, then there is an internal leak and the unit need to be repaired or replaced.
    Aug 11, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
    My coffee maker, Cuisinart dcc 1400 only boils water, does not make coffee. It is one week old. I have a water filter in the plastic filter holder filled with coffee.
    The two most common reasons for overflow or underflow have to do with the carafe lid and the filter basket - they key to smooth flow with this coffee maker is making sure the filter basket and carafe lid are making the proper contact with each other so that the center knob on the carafe lid pushes slightly up on the filter basket spring. Make sure the carafe lid is completely closed. Make sure the filter basket is pushed all the way down. Make sure you are not using the gold tone filter and a paper filter at the same time. For some reason, I get better results when the handle of the carafe is resting against the right side wall. If everything is in place, I would suspect a problem with either the filter basket being clogged or some problem with the carafe lid - call Cuisinart as they should be able to order these parts for you.
    Aug 10, 2009 | Cuisinart Coffee Makers & Espresso...
    I clean it everynight but it still leaks coffee grins and coffee all over the place...this is the second coffee maker of its kind that i have had and they both have done the same thing. This only happens...
    Jul 30, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
    Need coffee pot for ODC325
    I can find one for you. Please contact me offline.
    Jul 02, 2009 | Black & Decker SpaceMaker ODC325 Coffee...
    Black & Decker SpaceMaker ODC325 Coffee Maker Logo
    13 people viewed this question
    Top Black & Decker Coffee Makers & Espresso Machines Experts
    eyecam
    Lyle Siemens
    Lyle Siemens
    Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
