Question about TORK Mechanical Hardwired Timer 1101-O
Tork timer is making buzzing noise. Is there a repair, or do I replace it?
2 Suggested Answers
  • 5245 Answers
SOURCE: Tork Timer 1101 Noisey!!
Spray gears with WD40. And blow out timer with air. Turn off power: WD40 vapor is highly flammable accelerant.
Do not spray WD40 on live electric connections or hot surface.
Install timer on non-wood surface so sound does not resonate sound like a wood violin.
You can also buy replacement clock motor #101 for about $48.
http://waterheatertimer.org/Tork-timers-and-manuals.html#1101
Or buy the T1101M replacement mechanism for $59 and screw into current box, or buy whole new T1101 with the box for about $53 and just use the new mechanism.
Or replace with new Intermatic T101 timer for $45 at Smarthome.
Crossover wiring:
Tork L&1 to Intermatic 1
Tork 2 to Intermatic 2
Tork x to Intermatic A
Posted on Sep 04, 2012
The TORK 1001 Timer stops at the end of the cycle? and do not advance after it stops the lights. Any solution?
Hello Tarsem
To repair this problem, replace and install new Tork 101 clock motor on back of timer:
Also order new trippers.
Add comment
Gene
Aug 06, 2013 | TORK Timer 1 Channel Signal Timer Dgs100
Danfoss 103 timer is making a constant buzzing noise!!...everything's works fine but I want to stop this buzzing noise. Any actions I should take or advice would be much appreciated. Thanks.
How much wattage is going through the timer and what is its rated load max? try unplugging whatever is plugged into it and see if it stops but if you exceeded the max load might be damage to the internals which can cause that buzz.
Feb 05, 2013 | Hardware & Accessories
Crossover wiring:
Sep 03, 2012 | TORK Hardware & Accessories
No display stop working. it controls a fan lite, the lite is on in a dimmed mode, no fan function.
Question posted under Tork SS720 timer.
I don't have repair for defective timer that worked before and stopped working.
If this is new timer, then add a comment and explain wiring in exact detail, and include what you mean by 'dimmed' mode.
Timers have 1 year limited warranty.
Timers are affected by line noise, and generally cannot be connected to a dimmer.
SS720A timer is robust 120Volt single-pole 7-day programmable timer, rated for 15Amp up to 1 HP.
The larger the amp load, the shorter the lifespan for electrical devices.
Last step troubleshoot for programmable timer is to reset timer and reprogram.
Reset timer by pushing in reset button for several seconds.
If functionality is not restored, then timer has gone bad.
Tork SS720 is identical to GE15071 timer sold at Home Depot.
Buy another timer, and return defect in new package.
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html
http://waterheatertimer.org/pdf/SS720A-Tork-In-wall-manual.pdf
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
Aug 19, 2011 | TORK SS720A 7 Day In Wall Digital Timer
I noticed the Tork 1104 timer box was not working. It does not make a sound. And the clock does not move. I measured the incoming and outgoing wires with a multimeter and both measure at 240V. I'm...
13 years is good run for clock motor. Timer will last longer than clock motor.
Open following link to identify timer
Tork 1104 has 240Volt clock motor
Frontier lighting sells the >> 120V Tork motor: List price 40.33/ your price 45.49
So 120Volt replacement motor costs as much as new replacement timer
http://www.frontierlighting.com/product.jsp?part=10431&process=search&show=&&gdftrk=gdfV22514_a_7c834_a_7c3267_a_7c10431
Intermatic replacement is240 volt T104 timer for $49.62 with 'free' shipping:
Also Intermatic trippers and clock motors are cheap and easily available
http://www.amazon.com/Intermatic-T104-208-277-Volt-Mechanical-Switch/dp/B000BQOX88
Crossover wiring from 1104 to T104.
Tork L goes to Intermatic 1
Tork 1 goes to Intermatic 3
Tork x goes to Intermatic 2
Tork 2 goes to Intermatic 4
Intermatic A is not used unless you have neutral wire or 277V
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
GE sells the same 240Volt Tork timer under GE model 15307 in indoor-outdoor enclosure available at Home Depot for $59.00. Year 2011, GE does not pay US income tax, but takes US profits and pays tax in foreign nations. No replacement clock motor is available, but crossover wiring is same.
http://waterheatertimer.org/GE-timers-and-manuals.html#15306
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 09, 2011 | TORK Variable Cycling Timer 8601
I have a Tork 1101. Please advise how to set the OFF time.
Tork 1101 is 24-hour 120Volt mechanical dial timer
ON-OFF trippers are placed on outer edge of dial to set on-off times.
These tripper click on-off lever back and forth.
Trippers wear out since they are intentionally made of softer metal than on-off lever
Frontier lighting carries P47 tork 1101 replacement trippers
http://www.frontierlighting.com/product.jsp?part=3495&process=search&show=&
Make sure these trippers match yours before ordering
Dec 09, 2010 | TORK Hardware & Accessories
Is there an instruction booklet available?
Instructions for tork timers:
Tork makes several timers that look similar.
Link above has photos of each type with manuals.
Dec 02, 2010 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
I have a noisy TORK model1101 24hrtime switch there is a broken spring in there and it won't switch OFF is it repairable or do I scrap it and Hunt for a new one? If you cant give me and answer with...
Fixya answers questions.
NSI is responsible for Tork.
http://tork.com/tork/elecmech.aspx
Electro-mechanical timers make audible click noise when timer turns on-off.
T1101 spring is the time-carryover for power outage.
Buy another Tork T1101 and swap out insides without changing box:
Take photo of wiring before making changeover.
http://www.weisd.com/store2/tork/torktimer1.php
Replace Tork with Intermatic T-101 120V timer
T101R for weathertight
Amazon for T101
Aplus sells T101R
For help wiring T101
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Nov 13, 2010 | Hardware & Accessories
How to set a tork timer?
Tork makes a page-full of timers.
Rotate dial until current time lines up with arrow, then set the pins as shown in photo below
1) If timer plugs into wall receptacle, it has pins around the dial.
2) If timer replaced a wall switch it also has pins around dial.
GE and Woods and Tork and Intermatic each make similar timers.
Pull and push the pins to set times.
The wall-switch type timer also has a switch >>> move switch to Timer
Up-vote if this information helped. Thanks for the feedback.
Oct 15, 2010 | TORK 401A 24 Hr Mechanical PlugIn Timer ...
I have a 15 yr old tork 1101 pool timer. I misplaced the tripper pins the replacements P-47 dont fit. What do I do
1) Tork P47 tripper is correct tripper for 1101 timer.
Trippers are brass-colored and black-colored.
If they do not fit timer dial you might need new timer.
http://www.frontierlighting.com/find.jsp?a=1&ID=,Photo.Cells...Time.Controls,Replacement.Trippers
2) Buy new 120Volt indoor/non-weathertight Tork T1011
To identify timer for sure:
3) Google search Tork 1101 shows timer cost $83
4) Intermatic cross reference shows replacement is T-101 indoor/non-weathertight
Amaxon sells T101 for 43$:
http://www.amazon.com/Intermatic-T101-Hour-Dial-Timer/dp/B00002N5FN
5) Raintight/outdoor: Aplus and Lowes sell raintight outdoor T-101R for $71
http://www.lowes.com/pd_29405-251-T101RD89_0_
http://www.aplussupply.com/intermatic/timer.htm
6) Cross over wiring.
Tork terminal X is T101 terminal A
Tork terminal 1&L are T101 terminal 1
Tork terminal 2 is T101 terminal 2
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jul 11, 2010 | TORK Digital Interval Timer Ssa100r-24
TORK Mechanical Hardwired Timer 1101-O Logo
119 people viewed this question
Top TORK Home Experts
john h
Tom Chichester
Are you a TORK Home Expert? Answer questions, earn points and help others
