Question about HP LaserJet Pro 400 M401DN Laser Printer
Unexpected paper size in tray 2 need to print
  • 744 Answers
SOURCE: I want to print from
Assuming the printer is otherwise working ok and we are talking about a Windows operating system....
When you choose the Print command from the drop-down menu in your application, instead of just proceeding, choose "Properties" or "Preferences" in that window. This should open up another dialog window from which you can choose additional printing options. It may be under Advanced or Tray Select, etc.
You can also get to the printer dialog windows by clicking on the Start button, then Settings, then Printers and Faxes, then double-clicking on the printer icon in that window for your printer and proceeding from there.
Posted on Jan 02, 2010
  • 150 Answers
SOURCE: hp 4000N 41.3 unexpected paper size
Clean the sep. rollers one in the paper tray and one inside the paper tray port. Then clean the feed roller. Its behind the sep roller in the paper tray port. You must look close with a flash light. It has 4 D feed rollers. It will rotate down to clean them do not knock the spring off. Use only water on a cloth no alcohol. Steven 818-888-0006
Posted on Mar 11, 2010
SOURCE: I want to print from Tray 2 where I have letter
You cannot do that it is "Hardwired" in the printer.
Posted on Mar 20, 2010
  • 24 Answers
SOURCE: after it prints two pages
This is most likely the paper pickup or registration solenoid sticking open.you can remove the solenoid, clean the mating surfaces and install a dampener, (we use a small strip of cloth tape) if one is starting to stick I would do the carousel solenoid (at the top of the machine near the laser scanner) at the same time to avoid a second problem
Posted on Aug 15, 2011
  • 7 Answers
SOURCE: unexpected paper size in tray 2.the paper in tray
Papers come in different standards across the world. This size is neither US nor metric. You will need to set the printer for custom-size paper and enter the dimensions.
Posted on Nov 11, 2011
HP 2840 unexpexted paper size
You must properly configure your paper size from the menu.
If you can not configure it with the default sizes, try to do it manually by adjusting thedimensions of the paper.
Apr 30, 2012 | HP LaserJet Office Equipment & Supplies
Unexpected paper size in tray 2.the paper in tray 2 is legal size..8.5 x 13 custom size in philippines..
Oct 13, 2011 | HP LJ 4100 Series Black toner 6K Printer
41.3 unexpected size in tray 2.my printer is hp laserjet 4200.can you solve this
Thank you for contacting FixYa with your printer Inquiry.
41.3 Unexpected Paper Size Explanation
  • The printer detected a paper size different than what it was expecting.
  • This is typically caused if two or more sheets stick together in the printer, or if the paper tray is not properly adjusted.
Recommended action
  1. Reload the tray with the correct paper size.
  2. Ensure that paper in the tray is loaded under the front and back tabs.
  3. When printing from tray 1, verify that the correct paper size is selected in the control panel (see the Paper Handling Menu section in the User Guide ).
  4. When printing from tray 2, 3, or 4, verify that the three paper size adjustments on the paper tray have been made correctly (see the description of adjustments in the section on Loading Trays 2, 3, and 4 in the User Guide ).
  5. After performing the actions above, press GO. The page containing the error will automatically be reprinted if jam recovery is enabled. Or, press CANCEL JOB to clear the print job from the printer's memory.
    Hope this helps. Please keep us updated and remember to rate this answer.
Feb 07, 2011 | HP LaserJet 2420 Printer
Printer says 41.3 unexpected size in tray 2. How do I fix this?
A couple of things to check.
1) Make sure the paper guides in the tray are adjusted correctly for width and in particular the length. 2) Remove the tray completely check guides. 3) Make sure the tray is fully seated into the printer. 4) Make sure the paper in the tray matches the size of the guides.
If the guides and paper seem OK, the printer may need servicing by authorized service center.
41.3 UNEXPECTED SIZE IN TRAY [xx] alternates with LOAD TRAY [xx]: [type] [size] Description This is typically caused if two or more sheets stick together in the printer or if the tray is not properly adjusted.
Jan 14, 2011 | HP LaserJet 2420 Printer
Hp 4000N 41.3 unexpected paper size
Mar 11, 2010 | HP Office Equipment & Supplies
Papper gets stuck while printing,shows on the scren paper size,41.3 unexpected paper size.
Make sure the paper stops in the paper tray are set to the correct paper size. If one of them is not in the correct location the printer thinks it is a different size of paper. Also make sure the selector on the tray is set to the correct size. If all these are good you should reset all the settings to default.
Mar 08, 2010 | HP LaserJet 4100 Printer
I want to print from Tray 2 where I have letter size paper. The printer is telling me to load paper into tray 1 -Error message is 41.3 Unexpected Paper size. I need the printer to select from tray 2 unless...
Jan 02, 2010 | HP LaserJet 4050n Printer
HP COLOR LASREJET 3500 41.3 ERROR
hi ray, it's chris. i called your cell phone, but figured you might see this. replace the registration clutch. after some research, this seems to be the solution given that should solve the issue in that printer, and it's an independant part from the paper pickup assembly...
RK2-0247-000CN
chris
May 27, 2009 | HP Color LaserJet 3500 Printer
Unexpected size in tray 2
whenever i took printout of a multipage file of Powerpoint. Everytime i have to preses the ok button to proceed with the print. because every page an eror comes displaying on screen of printer "UNEXPECTED SIZE IN TRAY 2" when i press the OK button it start printing the page. everytime i have to press the ok button to take print out. For example if i give a print command to a file that is having 15 pages. i have to press 14 times the ok button to complete the printing of 15 pages. pls help me in this
May 14, 2009 | HP LaserJet 2840 Printer
HP LaserJet Pro 400 M401DN Laser Printer Logo
1,390 people viewed this question
Seeker5211
Seeker5211
