Question about Sharp UP-700 Cash Register
System closed entry inhibit Can't use register
System closed entry inhibit Can't use register .... what to do? I already unplug it.
Why alarm go off whin u turn on
try pressing keyless entry twice before opening door or with doors closed unlock drivers door with key even if it is already unlocked both of those will disable alarm system so the alarm will not sound upon that entry/start of truck
May 18, 2014 | 1999 Dodge Durango
Loose green wier ?
Apparently, you do not have a starter inhibit relay installed. If the loose green wire is part of the alarm, it is for the door trigger.
Aug 28, 2012 | 750i5 Car keyless entry and security...
Check engine light is on. Does replacing the oil filter fix the problem? The codes are: P171, P174
very Unlikely this will have any affect. sounds more like an air leak to me.
You will find all codes available at http://www.bluejag.co.uk/decode.php
Fault Code:- P0171 Indicates a Power-train fault
The fault is generally due to a problem in the Emission Management (Fuel or Air) area
Fault Description: Bank 1 combustion too lean
Action of ECM:- ECM Default:- Bank 1 catalyst warm-up ignition ****** inhibited- Bank 1 closed loop fuel metering inhibited- Canister purge inhibited- Maximum engine speed reduced
After clearing the DTC, complete the Start engine and bring to normal operating temperature> 82 °C (180 °F) Idle for 10 minutes
Check for a reoccurrence of fault DTC.
Possible Fault:- Engine misfire Air intake leak between MAF Sensor and throttle Fuel filter / system restriction Fuel injector restriction Low fuel pump output HO2 Sensor(s) (1/1, 1/2) harness wiring condition fault Exhaust leak (before catalyst) ECM receiving incorrect signal from one or more of the following components: ECT Sensor, MAF Sensor, IAT Sensor, TP Sensor
Fault Code:- P0174 Indicates a Power-train fault
Fault Description: Bank 2 combustion too lean
Action of ECM:- ECM Default:- Bank 2 catalyst warm-up ignition ****** inhibited- Bank 2 closed loop fuel metering inhibited- Canister purge inhibited- Maximum engine speed reduced
Possible Fault:- Engine misfire Air intake leak between MAF Sensor and throttle Fuel filter / system restriction Fuel injector restriction Low fuel pump output HO2 Sensor(s) (2/1, 2/2) harness wiring condition fault Exhaust leak (before catalyst) ECM receiving incorrect signal from one or more of the following components: ECT Sensor, MAF Sensor, IAT Sensor, TP Sensor
Sep 09, 2011 | 2004 Jaguar X-Type
I would like to know what the following codes represent for my 2002 jaguar x-type 3.0 Codes are P174, P175, P1111
P1110 Intake Air Temperature Sensor Signal (Dynamic Chamber) Circuit
The other DTC refer to mixture issues.
From http://www.bluejag.co.uk
Action of ECM:- ECM Default: - Bank 2 catalyst warm-up ignition ****** inhibited - Bank 2 closed loop fuel metering inhibited - Canister purge inhibited - Maximum engine speed reduced
Possible Fault:-
once again from http://www.bluejag.co.uk
Fault Code:- P0175 Indicates a Power-train fault
Fault Description: Bank 2 combustion too rich
After clearing the DTC, complete the Start engine and bring to normal operating temperature > 82 °C (180 °F) Idle for 10 minutes
Possible Fault:- Restricted air filter Leaking fuel injector(s) ECM receiving incorrect signal from one or more of the following components: ECT Sensor, MAF Sensor, IAT Sensor, TP Sensor
Apr 23, 2011 | 2003 Jaguar X-Type
I used csorb's instructions to reprogram a master key for my 2000 Lexus RX300. The ignition works perfectly, but the doors don't lock or unlock.
Hi!!
I believe your alarm is in the PASSIVE MODE, here is how it works.
PASSIVE MODE Setting (Arming) Anti-Theft System The system will automatically set 30 seconds after following methods are performed: Remove ignition key from ignition switch. Exit vehicle, and close all doors. After performing this, anti-theft indicator on left side of instrument panel will light continuously for about 30 seconds. After 30 seconds, anti-theft indicator will blink once per second. When system is set, doors cannot be locked or unlocked using door lock control switch.
CANCELING THE ALARM AND REPROGRAMING MAY SOLVE YOUR PROBLEM.
Canceling Anti-Theft System Setting (No Alarm) When system is set (armed), but alarm is not sounding, use one of following methods to cancel system setting:
  • Unlock left or right front door using key.
  • Unlock all doors using remote keyless entry system.
  • Insert key in ignition switch and turn to ON position (this is operative only when anti-theft system has not been triggered).
HERE IS HOW TO REPROGRAM THE ALARM IN CASE YOU NEED TO RESET IT.
PROGRAMMING
PASSIVE MODE NOTE:Initial mode is passive mode off. If there is a different signal in middle of programming, signal is invalid.
Programming Passive Mode Off
  • Remove ignition key from ignition key cylinder. Ensure all doors (including back door) and engine hood are closed and unlocked. Perform all of following methods within 30 seconds:
  • Lock or unlock any door with key or remote keyless entry system.
  • Open driver door.
  • Lock and unlock driver door lock knob 3 times.
  • After performing this, system should start force lock after 2 seconds. Perform all of following methods within 20 seconds:
  • Unlock driver door lock knob.
  • Close and open driver door 2 times.
  • Lock and unlock driver door lock knob.
  • After performing this, system should start force lock after 2 seconds. Passive mode should now be off.
Programming Passive Mode On
  • Remove ignition key from key cylinder. Ensure all doors, engine hood and luggage compartment door are closed and unlocked. Perform all of following methods within 30 seconds:
  • Open driver door.
  • Close and open driver door 4 times.
  • After performing this, system should start force lock after 2 seconds. Passive mode should now be on.
If you need further assistance, please provide an email address to send more info on your security system
Good Luck!! A 4 THUMBS UP rating would be greatly appreciated for this solution. Thank you for using FixYa!!
Mar 01, 2011 | Lexus RX 300 Cars & Trucks
Have a prestige remote start that was installed and only worked for one week. now the remote beeps but doesn't start or lock/unlock any doors. remote says inhibited . all doors are closed as is hood and...
If this is the Prestige 997C, there is a remote starter disable feature that can be activated through the programming switch. When it is active it will display "inhibit' on the screen. To deactivate this feature, press and hold programming switch, turn key on, off, on, off, on then off. When the hood pin switch is not making contact with the hood when closed, the screen will display inhibit. When the brake shutdown wire is active the screen will display inhibit.
Feb 27, 2011 | Prestige Remote Start
What does inh.unit pr mean
INH. UNIT PR. means "Inhibit unit price". It means there is no price preprogramed for that department or PLU. Each department can be left open-priced, or preset. Open price is how you usually think of using a cash register: you enter a price, then touch the button. Preset price requires programing a price for a department in advance, but saves time in operation. You touch the Coffee button, for instance, and it automatically rings up the price you've set for a cup of coffee.
If you touch a normal, non-preset department without entering the price first, the register will error with the INH. UNIT PR message.
Touch the CLear key, enter the price, then touch the department.
Many of the Sharp registers, and I think the XE-A402 is one, allow a department to be both open and preset. It can also be programed to be inhibited completely.
The Owners Manual can be downloaded from Sharp here.
Dec 03, 2010 | Sharp XE-A402 Electronic Cash Register
I have somehow lost my cd drive which was there already. HOW TO GET IT NOW PL ANSWER.
Click Start, then Run, then enter REGEDIT to open the Registry Editor
2. Navigate to the HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Control/Class entry
3. Under the Class entry, double click on {4D36E965-E325-11CE-BFC1-08002BE10318}
4. In the right-hand pane, click ONCE to select the UpperFilters entry
5. Make sure the UpperFilters entry is highlighted, press Delete, then Yes.
6. In the right-hand pane, click ONCE to select the LowerFilters entry
7. Make sure the LowerFilters entry is highlighted, press Delete, then Yes.
8. Close the Registry Editor by clicking File, Exit.
download reginout to solve ur issue easy way
Aug 27, 2010 | Acer Aspire One PC Notebook
Hey helpful people!! My Acer laptop has a similar problem:" Userinit logon application" This program is closing down. Now the laptop is on BUT the START MENU is NOT AVAILABLE. Can someone out there post a...
You've got the wrong entry in your registry.
Userinit string should be:
C:\WINDOWS\system32\userinit.exe,
Note the trailing comma which must be there.
Often this entry is damaged by malware.
Ways to deal with this:
  1. Install Windows on a second partition, load the damaged registry hive and fix it.
  2. Boot with a Bart's PE or ERD Commander and fix the registry entry.
Or if you manage to get the register editor running just fix the registry key.
In the register you have to go to:
HKEY_LOCAL_MACHINE/SOFTWARE/Microsoft/Windows NT/CurrentVersion/Winlogon
Find the line named: Userinit
Make sure it points to: C:\WINDOWS\system32\userinit.exe,
If it doesn't exist, make one, if it doesn't point to the same place, change it.
CHeers
Apr 14, 2009 | Microsoft Windows Vista Ultimate Edition
Sharp UP-700 Cash Register Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
