Question about VillaWare 5000-NS Prima¿ Pizzelle Baker
Repair parts pizzelle baker shorted out
I have a pizzelle maker when do I know the right time to open & pour batter and when it is ready to be removed without burning
Some irons have one light that indicates that the heating element is on. I think that the Saulton iron has two lights. One light indicates that the iron is plugged in. The second light indicates that the heating element is on. You should wait until the second light goes off before trying to bake the first pizzelle. The second light will turn on and off as the thermostat regulates the heat. The cooking time depends on the pizzelle iron that you use. A good iron can bake a pizzelle in 30 seconds. The Salton iron WM8PZL takes up to 90 seconds for each cycle. Check the pizzelles after 30 seconds. The first pizzelles are seldom good. Experiment with the baking times to get the baking time right. After that keep up a steady pace to produce consistent results.
Early pizzelle irons were heated over open fires and made good pizzelles so with some practice you will be able to make pizzelles too.
Link to Recipe http://allrecipes.com/recipe/pizzelles-iii/
Jul 19, 2014 | Salton Pizzelle MasterWM-6Non Stick...
Find a leg for toastmaster waffle maker model 270 or 290
http://www.searspartsdirect.com/partsdirect/part-model/Toastmaster-Parts/Waffle-maker-Parts/Model-270/1097/0213700/00039364/00001?blt=06&prst=&shdMod=
Jun 18, 2014 | VillaWare 3600 Prego Pizzelle Baker
Lost pizzelle recipe from toastmaster please help .
Pizzelles were made before toastmaster ever existed and there is very little difference in pizzelle recipes.
Try this link.
Pizzelle Recipe Top Viewed Italian Cookie Recipe
Or this.
How to Make Homemade Italian Pizzelle Cookies
Dec 24, 2013 | Toastmaster Kitchen Appliances - Others
I lost my recipe booklet for my Berarducci "Dolce" pizzelle iron. Can you find one online for me?
There are 8 recipes in the manual available here: fantes.com/manuals/dolce-pizzelle-manual.pdf . Note: you will need Adobe Reader or a similar program to read the manual.
I hope this helps.
Dec 02, 2012 | VillaWare Electric Prego Pizzelle Baker...
Broken leg on Villaware pizzelle maker
You might try putting a screw of about the length of the original leg into the underside of the casing (drill it a little with a power-drill or a Dremel, then carefully insert the screw with a handheld screwdriver, testing it at intervals to make sure it's the length of the leg,) and then cover the screw in some Sugru. www.sugru.com should be able to sell you a few packets of the stuff; it's heat-resistant, very strong, and I've used it in several kitchen-gadget fixes.
Aug 29, 2012 | VillaWare 3600 Prego Pizzelle Baker
Manual for Toastmaster Pizzelle maker Model 208
what is the part # for the 208 pizzelle Thermal Control Module, and where can I purchase one?
Oct 01, 2011 | Kitchen Appliances - Others
Lost my manual/guide for villaware 5000-ns prima pizelle baker
go to villaware.com all manuals are .pdf format and free download
Dec 05, 2008 | VillaWare 5000-NS Prima¿ Pizzelle...
VillaWare 5000-NS Prima¿ Pizzelle Baker Logo
Top VillaWare Kitchen Appliances - Others Experts
Jerry Greenberg
Jerry Greenberg
Michael Vincent Cruz
Angel Joseph Jr.
Angel Joseph Jr.
Are you a VillaWare Kitchen Appliances - Other Expert? Answer questions, earn points and help others
